Old 01-31-2013, 08:49 PM   #1
SE Steve OP
Super Noob
SE Steve's Avatar
Oddometer: 225
Raid design vacuum fuel pump
So I finally got around to installing vacuum pump kit from raid deigns and it's leaking from the gaskets. looks like they get taken apart and vacuum side turned 90%.
Anyone have any ideas on how to fix it.
SE Steve is offline   Reply With Quote
Old 01-31-2013, 10:15 PM   #2
Qwik
Adrenaline Addict
Oddometer: 6,545
Call Raid Designs. They will make it good
Speed bumps never seem to make me go any faster
Qwik is online now   Reply With Quote
Old 02-01-2013, 06:08 AM   #3
KTMbageera
Oddometer: 89
Raid Fuel pump on 990R
Is this a workable, reliable alternative to the OEM in the tank masterpiece? With this can we dump the in tank due filter headaches and go for external inline fuel filters?
KTMbageera is offline   Reply With Quote
Old 02-01-2013, 08:12 AM   #4
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
I think this only vvorks for the carbed bikes. To lovv pressure for the EFI.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 02-01-2013, 02:17 PM   #5
Qwik
Adrenaline Addict
Oddometer: 6,545
Carb'd bike pump only
Old 02-02-2013, 10:46 AM   #6
Hipster
Hipster's Avatar
Oddometer: 1,775
That fuel pump looks vary similar to my 640 LC4 pump, which is a low pressure vacuum pump to feed the carb.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 02-08-2013, 11:34 PM   #7
SE Steve OP
Super Noob
SE Steve's Avatar
Oddometer: 225
Wink
Emailed Raid they sent a gasket set for the pump. Installed it still leaking. I just want to go for a ride
Old 02-09-2013, 09:12 AM   #8
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,752
Be more specific where is it leaking from.
The gasket between the two plates.
From a bolt hole
Petcock etc.
Take a pic and point to where the leak is in the pic.
If between the plates take them off and check to see if they are warped, use a glass plate to check this.
The gasket should accommodate a small gap but too big and it could be a casting issue. Is the pump new or was it in use for a while before it leaked.
See....need more details than "It leaks"
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 02-09-2013, 01:15 PM   #9
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,313
I consider this pump to be undersized for the application...
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 02-09-2013, 06:37 PM   #10
SE Steve OP
Super Noob
SE Steve's Avatar
Oddometer: 225
Why do you say that ? Raid design says that this pump cures the flooding problem when in whoops and pumps enough for top speed.
Old 02-09-2013, 06:58 PM   #11
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 730
Its about the same physical size as the same type of pump on a large outboard motor... Seems ok for a dual carb bike.. Surge volume might be a issue...
I found on boats the rubber in these last 1 season.. Les if they are allowed to dry out...
Dave
pdxmotorhead is offline   Reply With Quote
Old 02-10-2013, 03:45 AM   #12
jm65
jm65's Avatar
Oddometer: 177
if my memory is good , it's the same pump than ;640RR, 690RR..................... , and the flow is 35 Litres/hour
for gasket set ????? :
http://www.mikuni.com/fs-distributors.html
KTM 690 R 2014
jm65 screwed with this post 02-10-2013 at 03:51 AM
jm65 is offline   Reply With Quote
Old 02-10-2013, 11:27 PM   #13
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,709
Thought the woops issue was due to the CV carbs shutting down??? Not flooding???
Pete
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 02-13-2013, 04:39 AM   #14
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,832
i've had the pump on my SER for a good 12 mths or more & has been faultless
as for the pump leak make sure your hose clamps are tight Especially the infeed to the carbs off the pump. my first fire up with the vac pump leaked there & i thought the clamp was tight enough so a little more & was good. there some pressure there.
gasket sets are cheap - i bought 3 sets when i got mine on ebay
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 02-13-2013, 05:55 AM   #15
skuikka
Oddometer: 91
I believe this is similar 38liters/hourMikuni pump as I had in my SE. If the engine consumes less than 370 grams/kWh, which it should do on WOT, the pump Is big enough. Also my experience backs the theory. I used the bike also on racetrack with half a minute full throttle straight without any indications on going lean. I Agree there is not too much overflow, though I measured the pump flow to be approx 44L/h with crankcase vacuum. The pressure on the other hand was so high, that the engine Flooded on the motocross track, so I had to use a regulator.
skuikka is offline   Reply With Quote
Times are GMT -7.   It's 11:54 PM.
