Old 03-24-2013, 03:35 PM   #16
SE Steve OP
Super Noob
SE Steve's Avatar
Oddometer: 251
So I finally figured out the leaking problem. The pump is a dual outlet pump and the outlet pointing down was not sealed off good enough. Pulled the block off bolt put some sealant on it problem solved. Next problem forgot to turn off gas flooded cylinders. Fixed that. Next problem had a plastic fuel filter between tank and pump. It got to hot and the hose clamps closed off the filter so no gas. Need to find a metal filter.
SE Steve is offline   Reply With Quote
Times are GMT -7.   It's 02:19 PM.
