Old 02-01-2013, 10:08 AM   #1
35xj OP
Oddometer: 913
what have i done now?
well, had my 04 950 pretty far apart in the last week.. New parts
water pump
oil pressure relief spring
all jetting etc
to get the oil pressure valve back together, i pulleed tthe clutch apart as i couldnt get the snap ring back apart.out it back together as this forum suggested. i believe all the torque settings were correct.
Finally fired it up. runs great!
However, went to put it into gear...
lever pull felt normal, didnt feel quite right at the pedal, pushed it as hard as i would normally, BANG into gear
pulled the clutch, couldnt get it back out of gear.
with the bike shut off, the shifting feels a little notchy, but not terrible.
What the hell?
ANY suggestions would be great at this point! thanks guys!
35xj is offline   Reply With Quote
Old 02-01-2013, 10:29 AM   #2
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,335
are all clutchplates securely in the basket? If not it all may be in some pressure. Have you bled all the air out of the clutch?
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 02-01-2013, 10:43 AM   #3
35xj OP
Oddometer: 913
shouldnt be any air in the clutch. it was working great, until i pulled the basket etc out of it to replace the oil pressure valve.
ill check the plates again.
Old 02-01-2013, 01:21 PM   #4
crofrog
Oddometer: 1,455
Was the clutch stuck engaged or disengaged did you line up the arrow on the pressure cap?
crofrog is offline   Reply With Quote
Old 02-01-2013, 01:30 PM   #5
35xj OP
Oddometer: 913
i pulled the stack back apart, didnt notice anything wrong. put it back together, works fine!
Old 02-01-2013, 06:26 PM   #6
Katoom72
Katoom72's Avatar
Oddometer: 902
My guess: You turned the shiftshaft(8) a bit. So the pushing mechanism of the shaft meets the arrester(16) (that is connected to the roller) under an angle. That makes shifting very rough and close to impossible. (depending on the angle). The picture is for illustration, the damaged arrester in that pic is also a common issue with shifting problems. But irrelevant to your problem. (I hope )
Katoom72 is online now   Reply With Quote
Times are GMT -7.   It's 10:28 PM.
