Old 01-04-2015, 03:09 PM   #1
AB13 OP
Oddometer: 1,111
2012 990 radiator leak
Took the tanks off of my 990 today and found the radiator leaking around the tank seals, anyone else ever seen this? If I end up buying a new one does anyone know of a upgrade or am I stuck with buying a OEM one. Thanks AB:-)
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 01-05-2015, 09:36 AM   #2
Rharr
Rharr's Avatar
Oddometer: 184
you could contact
http://www.fluidyne.com/high-performance-radiators.html
about a custom radiator, you would just need to send them the old one so they could build you a new one. You could also get crazy and have them add a built in oil cooler into it if you wanted to really go nuts.
or a easier and cheaper solution is to pull the radiator off and take it to a local radiator shop and see if they can seal it back up.
2010 KTM 990 Adv R
2005 Honda Crf450x
2005 Suzuki SV1000 sport touring setup for sale
Old Suzuki GS stuff
Rharr is offline   Reply With Quote
Old 01-05-2015, 02:13 PM   #3
AB13 OP
Oddometer: 1,111
Called them and they said they no longer will make or repair motorcycle radiator's so I Guess I will get a new KTM one. Thanks AB
Old 01-05-2015, 03:00 PM   #4
BT4Stroke
Oddometer: 86
Try www.motorcycleradiators.com
Known as Myler's in Utah they do great work.
BT4Stroke is offline   Reply With Quote
Old 01-05-2015, 03:40 PM   #5
AB13 OP
Oddometer: 1,111
They look like they have there act together I will call them tomorrow. Thanks. AB:-)
Times are GMT -7.   It's 09:22 AM.
