Old 02-01-2013, 10:11 AM   #1
twwhitey OP
twwhitey's Avatar
Oddometer: 93
GSA OEM Fog Light to Dually D2's conversion
Edit: I found the connector type (Deutsch DT06-2s) which I plan to solder up to an H11 connector to create my own adapter and swap out the OEM fog lights....
So I just purchased a set of Rigid Dually D2's from Black Dog Cycle Works and I'm interesting in installing them as a replacement for the Stock/OEM fog lights on my '12 GSA. The kicker is I'd optimally like to install them WITHOUT cutting either the BMW stock harness (so as to retain the ability to put the OEM ones back on for resale, etc.) and I really don't want to cut the leads leading to each Dually D2. I'm trying to find out what connector type is used on the Dually D2 and/or the standard Dually wiring harness included in the packaging?
I know the BMW OEM Fog light harness has an H11 bulb connector so if I can figure out what type of connector the Dually's use on the LED's I figure I may be able to build/solder a simple adapter (H11 Female to a Male Dually connector) and job done? At least that's the plan in theory... dumb idea?
I spent an hour + last night searching this forum and it appears that MANY people have replaced the OEM's with D2's AND used the stock fog lamp switch to activate... the problem is I couldn't find a single thread where anyone describes "how" they did it (and I'm not an expert in such things)
Any help regarding the connector specs OR (even better) any other guidance how to integrate these guys w/o cutting these pretty... and expensive wires... would be fantastic! Either way I can't wait to get these guys in use
Here's the connector leading to the Dually D2.
twwhitey screwed with this post 02-01-2013 at 01:36 PM
twwhitey is offline   Reply With Quote
Old 02-01-2013, 03:32 PM   #2
Disco Dean
Disco Dean's Avatar
Oddometer: 1,265
Ditto
Looking for the same info... bump this baby up and lets get some answers...
D
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 02-01-2013, 04:34 PM   #3
Yellow Iron
Yellow Iron's Avatar
Oddometer: 3,067
Duestec connectors. They can be had at a catapiller dealer
Bigger Better Faster More----4 non blondes
Feel the Power of the Wheel
Yellow Iron is offline   Reply With Quote
Old 02-01-2013, 07:43 PM   #4
Hayden
Oddometer: 25
Question
So, if I purchase two female connectors it will be a no-cut, plug-and-play connection? What gauge?
Hayden is offline   Reply With Quote
Old 02-01-2013, 10:42 PM   #5
Multiplicity
Oddometer: 172
Why not just mount them separately ?
Multiplicity is offline   Reply With Quote
Old 02-01-2013, 11:19 PM   #6
twwhitey OP
twwhitey's Avatar
Oddometer: 93
Not sure about the others but I plan on mounting the duallys on the 1" crash bar above and behind the OEM Fog light mounts... The OEM's are mounted in a laughable location IMO and made of the plastic to boot, I've snapped a mounting ring on one in an Anza Borrego sand wash already so I'm done with them. From what I understand the duallys are plenty bright enough so the stock ones can sit in a box until I'm ready to swap em back for trade in or sale... (hence why I don't want to go chopping those fine BMW wiring harnesses)
Old 02-02-2013, 05:38 AM   #7
Yellow Iron
Oddometer: 3,067
I had to go back and re-read what your trying to do?
I guess you can get a set of female Duestec connecters with what ever gauge wire you want (14 or 16) then assemble the plug'.
this will give you the plug to plug into your new lights leaving you wires to the other for the oem plug wich you will have to get??
Old 02-02-2013, 06:24 AM   #8
Hayden
Oddometer: 25
My goal is to remove the originals, and mount the new ones using the existing wiring harness. When the bike is sold, put the originals fog lights back on and use Duallys on the next GSA.
Old 02-02-2013, 08:27 AM   #9
twwhitey OP
twwhitey's Avatar
Oddometer: 93
Yep ditto. Turns out rigid industries sells an extension wire with the correct connector on it
http://www.RigidIndustries.com/produ...rnsextlopo.htm
I plan to solder a female H11 connector to it which I'll cut from one of these Im getting off of fleabay
http://www.ebay.com/itm/360557478883...S:3160&vxp=mtr
They're both 18AWG wire I believe so I'm hoping it'll work. Either way it's reasonably inexpensive to try
Times are GMT -7.   It's 07:51 PM.
