Old 02-01-2013, 11:32 PM   #1
touser OP
canned fruit
Oddometer: 358
690 braintrust help
hey Guys, can someone help me please. I have an 08 690 with 20,000 trouble free K's. Now it has died, wouldn't start for a while then started ok, did this again a few times and now won't start at all. any thoughts?
dave
I know the voices arn't real, but they do have good ideas.
touser screwed with this post 02-02-2013 at 01:26 AM
touser is offline   Reply With Quote
Old 02-02-2013, 03:31 AM   #2
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,001
I dont consider myself part of the brains trust but I hope this is some help to you:
Your problem could be any number of things from fuel pump/filter, sidestand switch or simply the battery is on the way out. Do you have it serviced regularly? When were the valve cleareances last checked?
It is most likely an electrical or fuel problem; what I did on mine once when I had a simaler problem was whip out the fuel injector turn on the key and see if theres any gas squirting out. there was so next I checked the spark, there wasn't any. from there it was a matter of checking and eliminating possible causes...turned out the coil lead had come loose. Easy fix chopped 10mm off the end of it and refitted.
I don't know how mechanical you are but my standard check list for this type of problem is the basic FACTS rule of thumb, namely check the following:
Fuel
Air
Compression
Timing
Spark
If you can determine which of these is not your problem then that should at least point you in the right direction.... and give us some more clues
Hope this helps
Good luck
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is online now   Reply With Quote
Times are GMT -7.   It's 09:12 PM.
