02-02-2013, 01:26 AM
#1 |
Oddometer: 21
Best crash bar for R1150GS?
Wich is the best crashbar for the BMW R1150GS? I have found the SW-Motech crashbar for my BMW R1150GS and it looks great. Any other suggestions?
Thanks a lot! |
02-02-2013, 01:40 AM
#2 |
Oddometer: 595
I have the SW bars . They suit me .
BMWMOA ABC Pikes Peak BMW Riders 2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72 1955 CJ-5 1975 F-250 Highboy |
02-02-2013, 04:26 AM
#3 |
long strange tripper
Oddometer: 1,755
factory bmw adv bars
"The liberties of a people never were, nor ever will be, secure when the transactions of their rulers may be concealed from them." - Patrick Henry |
02-02-2013, 05:05 AM
#4 |
I Like Tractor
Oddometer: 522
+1 on the factory adv bars. great for putting your legs up on longer rides, easy to remove for servicing, strong.
02-02-2013, 05:20 AM
#5 |
El Adventurero Solitario
Oddometer: 3,047
I'm on my 3rd set of Wunderlich bars (98k miles). They work and don't block any maintenance access.
eap '01 R1150GS, Chesapeake Bay Watershed, Surf Your Watershed Save the Bewbies "Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm |
02-02-2013, 09:07 AM
#6 |
Oddometer: 4,136
![]() i made these in my garage. |
02-02-2013, 09:08 AM
#7 |
Oddometer: 4,136
![]() front pic |
02-02-2013, 11:22 AM
#8 |
Oddometer: 256
None?
Put some good Head guards on and call it good.
Josh "Integrity, justice, courage, and action - without these, a person is of no consequence." Don Nelson my friend gone from us, 06/06/04. |
02-02-2013, 11:33 AM
#9 |
JockeyfullofBourbon
Oddometer: 5,636
I have the Hepco-Becker bars, do a great job of protecting the cylinder heads and the injectors, etc.
![]() ![]() They are not the easiest to install and they have to be loosened (in front, under the tank-- NOT in the rear) so they can be spread a little in order to remove the valve covers. They are extremely robust. I use both head guards and crash bars, as they protect in different ways. My valve cover is rashed to prove it.
"So what makes this protest different is that you're set to die, Bobby?" --May well come to that. "You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?" -- It's in their hands. Our message is clear. They're seeing our determination. |
02-02-2013, 03:13 PM
#10 |
Oddometer: 52
I have the SW Motech bars and I'm very satisfied. Great access for maintenance and quite robust. One negative point is if you ride serious offroad , the steel bracket that crosses under the engine can get snagged on roots or rocks etc.
02-02-2013, 04:47 PM
#11 |
Ride Far - Ride Fast
Oddometer: 4,777
I like the wunderlich the best. not too many bars, a nice spot to mount some aftermarket lights and they have plastic corner protectors that can be changed when scratched up.
http://www.wunderlich-bmw.com/shopar...-Adventure.htm http://www.wunderlich-bmw.com/shopar...01150-GS-R.htm
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS, 99 R1100S, 2002 R1150GS, 2005 F650 Dakar Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander screwed with this post 02-02-2013 at 04:56 PM |
02-05-2013, 11:40 AM
#12 |
Oddometer: 21
Thanks all of you, folks!
I have chosen the SW-Motech. It has a distributor in my country (Spain), and it looks like great, like you say. So, tomorrow it will arrive at home. Nice to meet you! I will post the pictures once installed! |
02-06-2013, 03:55 AM
#13 | |
steptoe
Oddometer: 2,149
Here's two examples i've had in the workshop. And there have been many more. Slow speed slide, shoud've been able to pick it up and ride away with minimal scratches - bars flipped the bike over onto the petrol tank and screen. ![]() Another example of exactly the same thing. ![]()
www.gsshop.co.uk |
02-06-2013, 04:07 AM
#14 | |
Oddometer: 1,755
02-06-2013, 04:35 AM
#15 | |
steptoe
Oddometer: 2,149
www.gsshop.co.uk |
