02-02-2013, 06:32 AM
#1 |
No neck tie, Ti neck
Oddometer: 571
Welding on frame
Need to do a little welding on my frame, will be using a mig. Should I unplug CDI or does it matter?
02-02-2013, 06:57 AM
#2 |
ceiling unlimited
Oddometer: 1,806
better safe than sorry.
unplug cdi/ecu, battery, plugs or ignition coils and set your ground clamp as close to where your welding as possible.
sideways and smiling |
02-02-2013, 07:41 AM
#3 |
Oddometer: 40
Definately agree with the above
Sent from my Sony Ericsson arc s using Tapatalk 2 |
02-02-2013, 10:42 AM
#4 |
Oddometer: 267
If your frame is Cromoly make sure you have the right wire for your mig,,, not the standard iron wire..
And if its Chromoly make sure you read up about normalizing welds.. Cheers. Dave |
02-02-2013, 03:21 PM
#5 |
Oddometer: 1,333
Yes BSTS but I have had my bike welded on all across the americas with only the battery disconnected.
02-02-2013, 03:39 PM
#6 |
Big Nasty
Oddometer: 502
Better safe then sorry for sure. i
Dr350, XR650R Dual Sport,XR600R,KTM ADV990R |
02-02-2013, 04:26 PM
#7 |
Oddometer: 193
Chromoly welds just fine with mild steel wire... Now I only use tig for anything motorcycle related for a number of reasons but you should be just fine. I have welded lots and lots of 4130 tubing with ER70S2 and a tig.
1989 KLR 650 |
02-02-2013, 05:06 PM
#8 |
Oddometer: 571
Thanks guys
Going to load it in my truck( with every thing un plugged) and go to work early to do it. I was happy to hear mild steel wire will be ok. All I'm welding is my center stand stop brackets,a whooping 2 inches of weld. With out them the chain rubs the stand when up.
02-02-2013, 09:04 PM
#9 | |
Oddometer: 267
I've seen many cracked frames and roll cages when chromoly was welded with the wrong alloy and not normalized after.. BTW std off the shelf wire from say home depot is very high carbon iron (At least in my local store) and he was talking mig not tig right? All I suggested was verifying the alloy and read up on chromoly weld normalization so he understand the potential issues.. Dave |
