Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 02-03-2013, 01:08 AM   #16
fallingoff
Oddometer: 3,677
ur a great bloke
i have seen a few outfits where the wheel chair goes up a ramp
and into the chair sect
maybe take the chair carcass off
knock up a special ride up chair with removable ramp
maybe out of marine ply.
then you just belt/bolt the wheelchair in
maybe a intercom system as well
good luck
cheers
fallingoff is offline   Reply With Quote
Old 02-03-2013, 10:15 AM   #17
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,619
Originally Posted by doc4216 View Post
So just a quick suggestion from my friend who is an OT/AT but what about having his OT/PT meet you at his house to help or consult with you to secure him in correctly? Without having control of his body, the shift in his body weight may have a drastic effect on your control. Apparently, Texas has a great Assistive Technology program and you may be able to find someone willing to donate their time to adapt something for you. It is worth a shot to ensure such a great friend security and safety.
PS I love what you are doing and think it's a great thing! More friends should be like you!
Originally Posted by XR4EVER View Post
It may sound like more work than you want to put into it, but Summit Racing sells light-weight plastic racing seats that already have the holes for 5-point harnesses for $35. They have 6 threaded inserts molded into the bottom for easy install. I've had a set in my old jeep for 15 years now. Link: Plastic Racing Seats
2 great ideas, reading this thread the first thing that came to mind was a 5 point harness, I can check with a few friends from my Portland Speedway days to see if I can get you a loaner.
Good onya for doing this Mr. Cob
"A man can never have too many motorcycles, like any good craftsman you need the proper tool for the job at hand. A man needs more tools than a hammer, the same goes for bikes." ~Mr. Cob~
My Ride Through Roatan
Road Rash is offline   Reply With Quote
Old 02-03-2013, 10:49 AM   #18
MillCreek
ADV Risk Manager
Oddometer: 1,927
So my first thought, from my old paramedic days, would be to cut a backboard down to fit and use the side slots to rig up some sort of straps/harness to hold him upright. We used such devices to do car extrications, for example. You could do the same with a piece of plywood and run some buckled straps around the patient and backboard. It is my thought here that the major issue is holding the patient upright. Once he is in the sidecar, he won't be going anywhere, so holding him upright is key.
Regards,
MillCreek
Snohomish County, Washington USA
2012 Suzuki DL650A as the current bike
Whole bunch of bikes in the past
MillCreek is offline   Reply With Quote
Old 02-03-2013, 10:49 AM   #19
Mr. Cob OP
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 9,350
Howdy Tom,
Thanks, that would be great. So many good ideas have been put forth but many involve taking the tub off the frame which for this trip I can't do, I have to come up with something that will work with what I have.
Dave, aka "Mr. Cob"
My photos, http://mr-cob.smugmug.com/ Join Smugmug, use this coupon ( https://secure.smugmug.com/signup?Coupon=geyYbNZwLLrl6 )
Mr. Cob is offline   Reply With Quote
Old 02-03-2013, 11:25 AM   #20
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,619
I didn't even think of this
I wonder if a 4 point harness would work? if so I can loan you one WITH a padded seat.............only thing is I need it back by June.
http://www.summitracing.com/search/d...points/4-point
Old 02-03-2013, 11:39 AM   #21
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,350
Howdy Tom,
Could you send me a photo of the seat, how wide is the seat? If the seat will fit into the sidecar I am sure I could make it work, how many mounting points does the seat belt have, does the back of the seat go up high enough to be used as a head support?
I'll be home from this trip in plenty of time to get it back to you well before June.
Dave, aka "Mr. Cob"
Old 02-03-2013, 01:26 PM   #22
pHelix
Eternal n00b
pHelix's Avatar
Oddometer: 1,234
How long a ride are you thinking?
Keep in mind that your friend probably has no sensation in his seating area or his feet, and so won't be able to tell if there's a pressure point or similar issue. For a short, around the neighborhood ride, this probably isn't a problem. If you're thinking of a muti-hour ride, he will need to shift position from time to time to avoid pressure sores.
Pressure sores can develop in less than two hours. They can take an eternity and a lot of sacrifice to heal. Pressure points and other irritaints below the level of his spinal cord injury can lead to a potentially fatal condition known as autonomic dysreflexia. Even something as simple and minor as a wrinkle under his butt can trigger AD.
As a retired physical rehabilitation nurse, here's my advice: Your friend probably has a very special seating pad. Consider making use of that under his butt. His heels, knees, ankles and other bony protuberances where he has limited or no sensation will need to be protected. Start with a short ride, haul him back out of the rig and check his skin to make sure no issues are developing. Build up gradually to longer rides. He probably sees a PT from time to time. See if you can get a seating consult.
You can make this work! It will take some careful thought and planning. Good on ya for taking this on.
Kevin
just beneath the surface of the mud, there's more mud here... Surprise.
'07 R1200GS, '03 DR-Z400
pHelix is online now   Reply With Quote
Old 02-03-2013, 01:31 PM   #23
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,350
Howdy V-Duck,
Thanks for your post, lots of information I was not aware of and of importance. I'll have to talk to Rick some more but I am hoping we can take the pads from his powered wheel chair and use them on top of the sidecar seat. I doubt that the ride will be a long one, simply because of the stress it will cause to Rick, if we could just ride for a few miles I know it would bring him great joy and fulfill our long ago made plan.
Dave, aka "Mr. Cob"
Old 02-03-2013, 11:28 PM   #24
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,619
Originally Posted by Mr. Cob View Post
Howdy Tom,
Here is the seat, I only measured the inside, but overall it's about 20in
Here is the mounting, just 4 bolts on the bottom for the seat, and the lap belt on the side, didn't get a pic of the shoulder harness, but it loops around the square bar that is next to where the lap belt mounts, right behind the seat, I can get more pics tomorrow if you'd like.
Road Rash screwed with this post 02-03-2013 at 11:38 PM
Old 02-04-2013, 10:08 AM   #25
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,350
Howdy Tom,
The sidecar is only 17 inches wide at the top of the bottom seat cover and it tapers slightly the rest of the way to the floor of the tub. So the seat you have offered will not work. Thanks for trying to help.
Dave, aka "Mr. Cob"
Old 02-04-2013, 12:46 PM   #26
what broke now
Petroleum Brother
Oddometer: 1,342
Here's a tutorial on how to make a flotation bag out of pvc fabric and glue that looks adaptable to filling in an odd shape. A little googling brings up the materials mentioned pretty readily, too.
Maybe Mr. T-Edison knows something about this stuff, he is a paddler.
http://www.yostwerks.com/FloatbagA.html
what broke now is offline   Reply With Quote
Old 02-04-2013, 04:15 PM   #27
Uller
Uller's Avatar
Oddometer: 1,672
How about a "spaceframe" made out of 1" pvc pipe. It is close to $1.50 for a 10' stick and doesn't take up much space. You don't need to bend it. Just cut and connect.
Get some couplers, tee's and 90's to connect the different sections. Build it then take apart for travel. You can number the pieces to aid in reassemby after you get there to speed up the process. Use some webbing to secure the spaceframe to the sidecar.
Uller is offline   Reply With Quote
Old 02-04-2013, 05:21 PM   #28
Mr. Cob OP
Mr. Cob's Avatar
Oddometer: 9,350
Howdy All,
Thanks for the suggestions, I think between a combination of some of your ideas I'll come up with something simple, yet strong and easy to make.
Dave, aka "Mr. Cob"
Old 02-04-2013, 11:06 PM   #29
Road Rash
Infamous
Road Rash's Avatar
Oddometer: 18,619
Howdy Tom,
Damn, sorry, I even double checked it tonight, exactly 20in.
There are a lot of other good ideas, and I know you'll make something work.
Old 02-05-2013, 10:49 AM   #30
thetourist
Just passing thru
Oddometer: 4,160
When I read your initial post I flashed onto my stock car seat. Fully captive, head supports, shoulder supports, easy to bolt. Then I read the rest of the posts. Sidecar is just too small for the seat.
But, that means the car can become the lower seat. Maybe some plain old foam for stabilization.
In the pics he appears to have good control of his head. How about his arms? Does he have at least gross control (large movements)? It looks like he contols the chair with hand controls.
Get a sheet of aluminum and put a couple of bends to replicate a stock car seat. Check Butler Built seats. Sides running forward enough to stabilize his torso and arms. Then wedge it into the hack. I've never been in a hack. how far down into the car body do you sit. Shoulders are wider than the seat, etc. Lots of fabrrcation problems.
I'm also thinking something like a lawn chair back wedged into the hack. Maybe a chaise lounge back, which is longer. Or a conduit frame with some webbing, like you originally were thinking. Then wedge something along the sides to hold his arms and torso from falling sideways.
Maybe a thin plywood box affair. Built something like my afformentioned stock car seat. You can bolt ply together with piano hinge. Nuts to the outside. BTDT. Aluminum could be done similar.
This actually sounds like a great project. Good Luck.
thetourist
The gate guard glares at me. "It's after curfew." He looks me up and down, "What do you think you are, some kind of ****** tourist?" ..Phu Loi 1969
My Idaho =7893
thetourist is offline   Reply With Quote
Times are GMT -7.   It's 02:01 PM.
