Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 12-30-2013, 08:26 AM   #511
rechenagucia
Ride Safe
Oddometer: 4
Originally Posted by Smop View Post
Hi -
I got mine a week ago and took a few pictures.
I'm still waiting for a couple of things to be delivered (skied plate, chain lube system, additional lights, roadbook holder).
Georges
Very Nice set up, Congrats. Can you tell me the part number for the clutch cover? Thanks.
rechenagucia is offline   Reply With Quote
Old 12-30-2013, 08:37 AM   #512
Smop
Smooth Operator
Smop's Avatar
Oddometer: 15
Hi -
Sure I can ;-)
KTM product #SXS.09.450.210.
Georges
No gods, no masters.
Smop is offline   Reply With Quote
Old 12-30-2013, 09:38 AM   #513
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 370
Originally Posted by nikoktm View Post
I have these Clearwater waiting to go on when I get my bike when it ever comes! I hope to get this horn in where the stock horn is and use a 3 way with a relay to trip the lights on high during the day with the horn.
Is that the SwMotech crash bars you added that they are mounted too? Do you like them there?
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral is online now   Reply With Quote
Old 12-30-2013, 11:59 AM   #514
vasculopath
You're not your bike
vasculopath's Avatar
Oddometer: 366
Orange skidplate is growing on me...Color match is not bad, even in full daylight.
vasculopath is offline   Reply With Quote
Old 12-30-2013, 01:26 PM   #515
LAKEMONSTER
Oddometer: 35
Is that Paint, or Powdercoat, and how is it holding up to the Temps of the Exhuast Header ? Am just about Finished a Design for Skid Plates for the 1190's, and choosing whether to Finish, or to leave them raw ? Thanks !
LAKEMONSTER is offline   Reply With Quote
Old 12-30-2013, 01:55 PM   #516
vasculopath
Oddometer: 366
Blaze Orange Plasti-dip. Time will tell re: Temps. I had it in the garage so did it mostly as a trial. If it goes bad, I'll have it blasted and powdercoated.
Old 12-31-2013, 02:23 PM   #517
Espada
Oddometer: 94
With the orange skid plate, your 1190 ADV R reminds me of an Oriole.
The thing is, I am digging the look too.
Espada is offline   Reply With Quote
Old 01-02-2014, 12:39 PM   #518
PatSmith
Oddometer: 391
Color.
[Agreed. This color has grown on me, so much that mine is here now. Just waiting on heated grips to come in.
QUOTE=umitc;21016622]Still I like the look
[IMG][/IMG][/QUOTE]
PatSmith is offline   Reply With Quote
Old 01-02-2014, 06:51 PM   #519
DirtJack
DirtJack's Avatar
Oddometer: 1,456
I've had my 1190 R for about a week and now have setup the HDB hand guards which used to be on my 990.
I'm having a bit of a problem getting the controls on the left side of the bar rotated to suit me. Is the menu switch pinned to the bar like the controls on the 990? The right side can be rotated on the bar by just loosening the bolts/screws. The left side does not rotate when loosened. Also, the 1190 R appears to have some sort of damper mounted to the bottom triple clamp similar to Honda's damper on a CR450R. Is this, in fact, a steering damper? No mention of it in the manual.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 01-03-2014 at 07:43 AM
DirtJack is offline   Reply With Quote
Old 01-02-2014, 08:19 PM   #520
paturoa
paturoa's Avatar
Oddometer: 250
Yes, both models have a steering damper as standard.
paturoa is offline   Reply With Quote
Old 01-02-2014, 08:35 PM   #521
ChrisK7
ChrisK7's Avatar
Oddometer: 249
Check the lower rear engine to frame bolt on the right side of the bike to see if it is there. Mine is missing and I have to tap it out (.150) and install a 30mm bolt from what I'm told.
Guess there are others like this too.
'14 KTM Adventure 1190R 12 KTM 990 SMT ,09 KTM 530 EXC (plated), 09 Kawasaki Brute Force 750
ChrisK7 is online now   Reply With Quote
Old 01-03-2014, 07:40 AM   #522
DirtJack
DirtJack's Avatar
Oddometer: 1,456
Mine has no bolt, but the hole in the engine case is tapped.
2008 KTM 690 Enduro
Old 01-03-2014, 08:54 AM   #523
The "OC"
The "OC"'s Avatar
Oddometer: 136
Put some sand through the 1190's tyres today. Hot sunny South Africa. 1190 performing well at 6500km.
Unifilter in for that fine dust.
The "OC" is offline   Reply With Quote
Old 01-03-2014, 11:39 AM   #524
Paulev
Oddometer: 39
DirtJack
"I'm having a bit of a problem getting the controls on the left side of the bar rotated to suit me. Is the menu switch pinned to the bar like the controls on the 990? The right side can be rotated on the bar by just loosening the bolts/screws. The left side does not rotate when loosened."
The left side handlebar controls are located by a small steel pin which is bonded into the lower half of the switchgear. It locates into a small hole in the handlebars. The only way to move the switchgear around would be to drill a new hole in the bars, not recommended ! I fitted new bars to mine to give a bit more height and to rotate the switchgear but you still end up guessing where to drill the hole.
There are two screws in the bottom of the switchgear which hold the halves together but you still have to pry it apart even with those removed.
Be careful as the there are quite a few button pads in there which are a nightmare to get relocated when you try and put it all back together.
Paulev is offline   Reply With Quote
Old 01-03-2014, 11:53 AM   #525
PatSmith
Oddometer: 391
Looking good.
What are the tires and how do they work on the road?
Times are GMT -7.   It's 07:58 AM.
