Old 07-28-2013, 12:14 PM   #1
victorlaszlo OP
Oddometer: 205
Vibrating dashboard
Wanted to check what you guys think about this...
Approaching 85-90 mph my dashboard vibrates quite a lot, and it's difficult figuring out if I do 90 mph or 95 mph.
The rest of the bike doesn't vibrate very much besides the mirrors, but is this normal? The dashboard seems to be fitted well enough in its rubber mountings - do your bikes do the same or should I start to worry?
Cheers V
victorlaszlo is offline   Reply With Quote
Old 07-28-2013, 02:28 PM   #2
Plaka
Brevis illi vita est
Oddometer: 4,609
Cheers V
You might say what bike it is (model and year)and what modifications, if any, it has.
Old 07-28-2013, 03:22 PM   #3
victorlaszlo OP
Oddometer: 205
Thought it was in my profile but not - it's a 1983 R100RS :)
Old 07-28-2013, 03:49 PM   #4
Plaka
Oddometer: 4,609
Why should I have to go clicking and looking? Put that info in your title and people with that bike will notice. For example, I also have an '83 RS
Are you talking the dashboard as in the fairing with some instruments and the ignition switch, or the dashboard pad thing clipped to the bars, or the pod with the speedo and tach in it?
it sounds like you're talking the instrument pod.
Plaka screwed with this post 07-28-2013 at 03:56 PM
Old 07-29-2013, 02:23 AM   #5
victorlaszlo OP
Oddometer: 205
Yes indeed, the pod with speedo, tacho and warning lights. Fairing is fairly non vibrating although the mirrors are.
Only very very light vibration in the footpegs similar to what I experienced 13 years ago when driving another -83 RS...
Cheers Victor
PS I wrote "profile" above but meant "signature". Turns out it's not visible so apologise any inconvenience caused :)
Old 07-29-2013, 03:54 AM   #6
Ron Bernert
hiding in plain sight
Ron Bernert's Avatar
Oddometer: 309
I would suspect a tire imbalance.
Got it! Got it! Got it! Don't got it.
'77 BMW R100RS euro, '94 BMW R1100RS, '95 BMW R1100GS, '71 BMW R75/5 SWB, '68 BMW R60/2 (in boxes), '82 Suzuki GS450, '?? Yammer XT 350.
Ron Bernert is offline   Reply With Quote
Old 07-29-2013, 04:03 AM   #7
victorlaszlo OP
Oddometer: 205
This was actually testing the rear tyre which had just been fitted. Before with the worn out and probably oval rear tyre I had severely vibrating instruments from 70mph, now it's much less vibrating and at much higher speed.
The front tyre is new as well, around 500 miles on it I reckon...
Whit the old tyre the entire bake was shaking/vibrating, now it feels fine besides the instruments vibrating so I didn't think it depended on the tyres... Could it be the front one possibly?
Old 07-29-2013, 06:21 AM   #8
airsmith
airhead wrench?
Oddometer: 181
fork sticksion could be a cause, almost all r100's will feel better if the fork tubes are perfectly aligned.. carb balance under full load could be coming into play and a look at the diaphrams unless known to be good may be needed, also look to make sure all the pod mounting hardware is correct,, (spacers washers, rubber bits)..
LOUD PAINT SAVES LIVES
airsmith is offline   Reply With Quote
Old 07-29-2013, 06:52 AM   #9
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,576
Cheers V
Not to be an ass, but why are you riding at such high speeds? Is it a race bike or do you routinely commute on the autobahn?? Surprised no one asked
Have you trued your wheels lately? Plastic and rubber does shrink when it ages
hardwaregrrl screwed with this post 07-29-2013 at 12:50 PM
hardwaregrrl is online now   Reply With Quote
Old 07-29-2013, 08:00 AM   #10
LouDiamond
Oddometer: 51
rubber washer maybe?
On my R90, there are rubber washers on the top and bottom of each screw holding it in place and on top of each of those sits a slightly curved metal washer that completely covers the rubber below (or above if you're on the bottom side). Mine was vibrating a lot as well, turned out that i was missing one of the rubber washers
LouDiamond is offline   Reply With Quote
Old 07-29-2013, 09:43 AM   #11
victorlaszlo OP
Oddometer: 205
Well, the bike is made for these speeds, and das Autobahn :) Even has a sticker on the inside of the fairing saying "For travelling above 160 mph increase tyre pressure with...".
Front wheel was just fitted when I bought it a couple of months ago, by Motoliner or Motoworks, can't remember which.
Rear tyre I changed last Friday so was balanced then... Not saying the operator couldn't have made a mistake though...
Old 07-29-2013, 09:44 AM   #12
victorlaszlo OP
Oddometer: 205
Interesting, will check that out immediately. That is bracket-handlebars only and not bracket-instruments, right?
Old 07-29-2013, 09:49 AM   #13
victorlaszlo OP
Oddometer: 205
This is interesting too, could the forks while travelling over good tarmac on the motorway cause these kind of vibrations?
The carbs have been balanced properly, even took her for a longer drive to make sure there were no inconsistencies between the carbs also under load and higher revs and it is all fine.
It doesnt feel as if the engine is vibrating, and there are no nasty vibrations in the footpegs, some vibrations in the grips but the bike feels good enough, only the instruments vibrate at this speed only (not at the same revs in say 2nd gear)...
I suppose it could be normal too but would expect someone to mention it in that case...
Old 07-29-2013, 09:51 AM   #14
victorlaszlo OP
Oddometer: 205
The old rear tyre was extremely imbalanced and caused vibrations in the entire bike, and the instruments vibrated too.
Having fitted the new rear tyre the issue is cured, besides the vibrating instruments at the mentioned speeds.
What would be the symptoms of imbalance in the front wheel, also if only slight?
Old 07-29-2013, 10:19 AM   #15
LouDiamond
Oddometer: 51
i believe it's instrument-triple-tree, if i recall correctly. I could reach down and just grab the tach/spedo and it would stop immediately. the vibration wasnt visible, but you could hear it.
Times are GMT -7.   It's 05:56 AM.
