02-03-2013, 08:06 PM
#1 |
Oddometer: 423
Garmin installation and pannier question
I have a few questions that are very dissimilar but both about the 800. I'm installing the Garmin 665 and looking at the length of cable they give you to hook to the battery, I was wondering if any of you had installation pics or tips to get me through.
Second part is pannier accessories, what have you got and where did you get them. I'm looking for ideas on making them even more useful...
1980 XR80s Deceased, first ever teardown. 1987 XL185s Deceased, at the bottom of the ocean. 1985 750 Interceptor Sold still alive somewhere. 2006 XR650L heavily farklefied Tendering in the garage. 2012 F800GS Triple Black Let the mods begin. |
02-04-2013, 12:19 PM
#2 |
Oddometer: 68
I have yet to install my Zumo 660 on my F800GS, but I can provide you some tips as I done it on countless bikes. You don't necessarily have to wire the GPS to the battery, you can connect it to a switched power supply in the front (ignition, lower beam, etc) so that the GPS turns off/on automatically with the ignition.
I purchased the following accessories for my panniers: 1. Inner bags: Extremely useful when you just want to leave the panniers on the bike and instead take out all the stuff and bring it to your hotel room. The bags usually are made of pretty heavy duty Cordura. 2. Net for the top lid: You can easily put your rain coat or towel to the inside of the pannier or can put your map into the net for easy access. You'll always access any important items instantly when you open the lid. For both of the above, you'll need to contact your pannier manufacturer to find out if they make something specifically for your panniers. 3. Reflectors: I have two plastic reflectors on both my panniers, they shine really bright at night and makes me more visible. You can get these in any color (I have white) from eBay. Most of them have an adhesive backing.
Currently - 2013 BMW F800GS, 2010 BMW S1000RR (track only) Previously - '13 MV Agusta F3, '04 Royal Enfield 500, '97 Yamaha RX135, '90 Yamaha RD350 |
02-04-2013, 08:24 PM
#3 |
Oddometer: 423
What are those square shaped loops called for strapping things to the top of panniers.
02-04-2013, 09:16 PM
#4 |
Oddometer: 68
I use the pannier carry handles (manufacturer accessory - nylon straps with a plastic handle) or Rok straps to strap things on top of the panniers.
02-04-2013, 11:34 PM
#5 |
Wannabe
Oddometer: 929
Garmin
There is actually a plug in the battery compartment that is switched and you can plug the Garmin into that with the BMW switched power cable. That's what I did with my Zumo 350LM.
Here is one place that sells it http://f800depot.com/bmw-switched-power-cable.html I doubt you will find it cheaper, but you can search around if you want. If you don't want to buy the switched power cable, you can splice into the cable of the plug in the battery compartment and still have it switched off when you turn key off. |
02-05-2013, 08:23 AM
#6 |
engage!
Oddometer: 672
You can order this cable from any BMW dealer also. When I bought mine 2 years back it was about $17. I use it to switch a fuzebox - might think about something like that in case you want to add more powered farkles in the future (like additional lights, etc.). The cable length on the GPS cradle is plenty long to go either to the battery or to the power plug.
Mind you, the switched power will turn off about 30-60 seconds after shutting off the bike, but the GPS can than stay on if you want, running on its internal battery.
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard) |
02-05-2013, 01:02 PM
#7 |
know nothing all
Oddometer: 211
This how mine is set up
I used the BMW power cable, trimmed the cable from the 665 and shrink wrapped it. I like that it powers on and off with the ignition. Used this thread as reference
http://www.advrider.com/forums/showthread.php?t=260497 ![]()
02-06-2013, 11:27 AM
#8 | |
The Chameleon
Oddometer: 749
Digging in with a new Shorai battery, fuse block, this pigtail, etc. this weekend.
Gumbeaux |
02-06-2013, 12:21 PM
#9 |
engage!
Oddometer: 672
You only attach the +12V trigger wire, the other two wires just heat shrink or tape off with electrical tape and tuck them away somewhere. The Fuzebox is already grounded through the negative battery (power) connection. All the same ground.
The wire from the BMW connector does not power the fuzeblock, it just activates the relay in it (aka "turns the power on"). The power comes directly from the battery and so does the ground.
02-06-2013, 12:35 PM
#10 | |
Oddometer: 1,786
Footman? ![]() http://www.eberhard.com/series/footman-loops |
02-06-2013, 12:49 PM
#11 |
Oddometer: 26
I used the touratech locking mount off of the handle bar clamp. It's secure and works well. For power I put a Centech AP-2 fuse block right on the air box. My gps is hot all the time and aux lights/heated clothing is on/off with the ignition. I used the BMW GPS plug for a trigger for the fuse block relay. It works well. I'm not a very good electrician so no pics of my crummy wire routing.
I do cling to my Bible and Guns! |
