Old 07-01-2013, 10:29 PM   #286
Tin Woodman OP
Mike
Tin Woodman's Avatar
Oddometer: 197
Originally Posted by blaine.hale View Post
Mind sharing that wire routing diagram? Been looking for one for a while.
Sure -
http://www.stephenbottcher.net/BMW/R...ion/wiring.htm
I found Stephen's site to be quite helpful. He gives credit to the respective authors on his website. He may be an ADV inmate. Stephen, if you're watching, thank you.
One measly toaster
Tin Woodman is offline   Reply With Quote
Old 07-02-2013, 05:18 AM   #287
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
You're welcome ... working on a R60/5 engine myself that started with an completety empty block so this thread is subscribed. One never knows what one might learn!
Stephen
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
StephenB screwed with this post 07-02-2013 at 08:53 AM
StephenB is offline   Reply With Quote
Old 07-02-2013, 06:33 AM   #288
blaine.hale
blaine.hale's Avatar
Oddometer: 3,070
Originally Posted by Tin Woodman View Post
Sure -
You're the jam! Finally!
Stephen, you're my hero.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale screwed with this post 07-02-2013 at 07:20 AM
blaine.hale is offline   Reply With Quote
Old 07-02-2013, 07:06 AM   #289
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,483
Whoa. That has to be some of the neatest headlight bucket wiring I've eve seen. And a good diagram.
--Bill
'73 R60/5 Toaster
Old 07-02-2013, 09:01 AM   #290
StephenB
StephenB's Avatar
Oddometer: 2,044
I have the diagrams and pictures in higher resolution, just go here:
http://www.stephenbottcher.net/BMW/R.../wiring_files/
I included links to the higher resolution pictures in the original document as well.
Glad the information is of use. The guys at 5united are awesome!
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
StephenB screwed with this post 07-02-2013 at 11:00 AM
Old 07-07-2013, 11:01 PM   #291
Tin Woodman OP
Mike
Oddometer: 197
Boy, do I know how to waste time. . .
The wiring in the headlight bucket seems to be the final hurdle but of course instead of focusing on that, I chose to play with the gas tank which had a couple of minor chips that were really bugging me. Didn't have any more black paint so I shot the tank with some metallic silver I found in my shop. A couple of coats of clear and it looks like this -
Purists will not be pleased.
I'm debating whether I should do the fenders the same colour. Still no plans to pin stripe. Your opinions always welcome.
One measly toaster
Old 07-08-2013, 03:05 AM   #292
Plaka
Brevis illi vita est
Oddometer: 4,588
Mmm...no, We are not pleased.
You should be doing ride reports by now. The bucket wiring is easy, getting it neat is not. So go light on the neat.
Chipping on the extreme front edge of the tank is always a problem. A small trip of plastic edging (Dunno what to call the stuff, it's folded over metal filled plastic edging to trim panels) can be applied temporarily when removing and replacing the tank. Or use a rag.
Old 07-08-2013, 07:02 AM   #293
blaine.hale
Oddometer: 3,070
You're doing exactly what I am. I keep putting off the headlight wiring crap and messing with the tank.
At least you probably still have your fuse assembly. I have to hunt one down.
1974 BMW R90 /6
Old 07-09-2013, 10:35 PM   #294
Tin Woodman OP
Mike
Oddometer: 197
But at least many have gone this way before - and some had the sense to take pictures. (I didn't but that was in 1984 when film was expensive.)
Almost done and I substituted new fuse mounts - way better. Very messy so will make Plaka happy (he's a little down on himself today.)
One measly toaster
Old 07-10-2013, 11:59 AM   #295
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 893
In 1973, in europe and Canada, these tanks came with knee pads and badges with striping and no chrome panels. The rubber mount under the badge had beveled edges that enclosed the badge and hid the bump on the tank that the badge is mounted on. These rubbers would look really good on your tank. Only problem is these were a one year only part and I can't locate any parts books that have them listed. Sadly, I only have one, not a pair.
Pokie is online now   Reply With Quote
Old 07-10-2013, 02:34 PM   #296
Tin Woodman OP
Mike
Oddometer: 197
Pokie, you may have inadvertently solved one puzzle but created another.
I seem to recall the bike having the toaster panels on the tank but maybe it's just a phantom memory. I know that tanks with panels have small mounting brackets spot welded to them - I thought I must have done a remarkable job of grinding them off years ago because there was no trace of them. Here's the kicker, though - even though I still have the original rubber spacers, the mounting screws for the roundels are too long. They are definitely the original screws.
If you have a chance, can you take a pic of the part you described? Thanks.
One measly toaster
Old 07-10-2013, 03:51 PM   #297
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 893
Here are some close-ups of the rubber "gasket".
The longer screws were for the chrome side panels. This gasket takes the regular, short screws.
Pokie screwed with this post 07-10-2013 at 04:09 PM
Old 07-11-2013, 12:29 AM   #298
Tin Woodman OP
Mike
Oddometer: 197
Thanks for the pics, Pokie. I'm betting they call those things 'bezels' . You're right - they do make for a neater installation. Will try scaring a couple up as a future project. Wonder why BMW lumped Canada with Europe in '73 - strange, isn't it?
Only a couple more connections in the headlight bucket and I can button it up. Time for a new battery - is there consensus out there? Mine is the SWB.
One measly toaster
Tin Woodman screwed with this post 07-11-2013 at 01:55 PM
Old 07-11-2013, 06:55 AM   #299
blaine.hale
Oddometer: 3,070
Odyssey battery is the cream of the crop. Or if you're feeling like you want to shed some weight, research some Lithium Ion batteries.
1974 BMW R90 /6
Old 07-11-2013, 01:58 PM   #300
Tin Woodman OP
Mike
Oddometer: 197
Thanks Blaine for cutting to the chase - I didn't want to set off a firestorm. By the way, what oil do you think I should use?
One measly toaster
Times are GMT -7.   It's 11:36 AM.
