03-06-2013, 09:10 AM
#121 | |
Oddometer: 2,146
My view of human nature is not doing well...
Airhead stuff, tools, camping stuff, riding gear for sale/trade. http://www.eskimo.com/~newowl/BMWPARTS.htm |
03-06-2013, 01:04 PM
#122 |
ShadeTreeExpert
Oddometer: 4,992
Agree Bill. The Teflon seal may not have the same profile or contact patch.
I think everybody has behaved rather well. I try, or maybe should say I don't have to try. I give it my best shot and if somebody shows me the errors of my reasoning then I learn something. I didn't see any name calling. I think in the end we all do a better job because we have looked at the problem from another's stand point. Use a socket or a block of wood or tool made from unobtainium, The next time any of us puts a rear oil seal in we will look at it with new eyes. I think that is truly priceless. Did anybody else think Plaka's Super Glue idea was really funny? I'm afraid he may not of been joking though.
Never memorize something you can look up. ---Albert Einstein |
03-06-2013, 04:21 PM
#123 | |
because I can
Oddometer: 6,054
I couldn't tell you how many times I am asked for the basis of my opinion and when I give it I am then accused of daring deeds blah blah. It's as if most of us can't see a bait and switch when one is right in front of us. |
03-06-2013, 04:34 PM
#124 | |
because I can
Oddometer: 6,054
The later seal has a completely different contact pattern on the flywheel. It contacts a much, much wider area than the typical rubber seal. That's probably the reason why they work so much better. Most of the time it will be impossible to miss a groove in the flywheel left by a rubber seal. The newer seal's contact area is too wide to miss the groove by setting the seal shallow or deep. I know it's just more blah blah but I have noticed this from installing a great deal them. |
03-06-2013, 05:36 PM
#125 | |
Confirmed Curmudgeon
Oddometer: 3,865
For sure. Oil seal technology has changed so much in the past few years. And I'm accustomed to the old-school lipped seal with the garter spring and the little spiral grooves to persuade oil to go back in. This filled teflon seal is much akin to magick, but I'll have to get used ot it.
![]() --Bill Quote:
'73 R60/5 Toaster |
03-06-2013, 06:06 PM
#126 | |
because I can
Oddometer: 6,054
03-07-2013, 06:36 AM
#127 | |
upside down parker
Oddometer: 3,238
glad it's working out for you.
03-08-2013, 09:26 PM
#128 |
Mike
Oddometer: 126
Oops!
Just coming up for air and have to share this with you. Apparently I have to learn everything the hard way. Tonight I planned to install the new duplex chain and crank sprocket. Remember how paranoid I was about blocking the crank? Because if you don't and something goes wrong, the results can be nasty? Well. . .
I thought I had everything figured out - while heating the new sprocket in the oven at 280F, I practiced with the old sprocket. I slipped it onto the shaft with just enough force to center it. I tried to pull it off but it was cocked on the shaft. I tugged on it just a little too hard I guess. That's when I heard a soft 'clunk'. Uh oh. Not fully believing the obvious, I tried gently turning the crankshaft - bad idea. Completely seized. Sh*t!!!!!!!! Next to the $3000 o-ring hazard, this is the one to avoid at all costs and I had stepped right in it. With rising blood pressure, I scanned the manual, the web, anything that could offer hope. Finally found a short reference by Snowbum that said there is a TINY chance to get the thrust washer back on its pins by accessing through the right side of the engine case. He said it probably wouldn't work but it was worth a try. He didn't offer any details. I'll cut to the chase. After half an hour of gentle prodding with a thick copper wire (so that I didn't scratch anything), I managed to get it back on the pins. Disaster averted.
'73 BMW R60/5 Toaster, '87 BMW K100 RT, '74 Norton Commando 850, '69 Triumph Trident, '69 BSA 250 Starfire |
03-09-2013, 01:48 AM
#129 |
Oddometer: 3,865
Ah, so the transmission and flywheel are off? Don't feel bad, I would be hard-pressed to remember to "block the crank" from the back when doing a crank pulley replacement. Good public announcement there...
Glad it went back on the pins (eventually), --Bill
'73 R60/5 Toaster |
03-09-2013, 08:38 PM
#130 |
Mike
Oddometer: 126
Some progress today - installed 'modern' rear main seal today thanks to borrowed tool (much obliged James!) Also installed oil pump with new o-ring, flywheel, camshaft, crank sprocket (very tricky) and duplex chain (trickier). Read other inmates' accounts about the tiny e-clips releasing and dropping into the oil pan. Has anyone had recent problems with these IWIS clips? Maybe it was a bad batch circa 2009.
My idea of a dental mirror - ![]() No wonder the chain was sloppy -
03-11-2013, 11:10 PM
#131 |
Mike
Oddometer: 126
Continuing down the rabbit hole
Torqued flywheel tonight with fresh bolts - should have used the old bolts because when fully torqued, crank had set like concrete (had formerly turned freely). Pulled off flywheel and noticed spalling of outer thrust washer I hadn't seen before.
![]() Had to have a better look. Goodbye new stretch bolts, teflon seal - ![]() Thought for a moment it might be related to crank slipping off journals but unlikely. Here's a closeup - ![]() Flywheel mating surfaces seem OK. Suddenly, I'm learning about crank end float. BTW, I put the flywheel back on without the main seal and everything spun effortlessly. I'm confused.
03-12-2013, 03:00 AM
#132 |
Oddometer: 3,865
Darn, now that is puzzling. That spalling wasn't caused by the washer slipping off of the pins, or anything I can think of offhand. And odd that the crank turns OK with the flywheel (and this thrust washer??) installed but w/o the seal. And odd also because typically a used thrust washer will have a coppery-appearance since the top layer of the bearing material will wear off. Did you have that thrust washer out for any reason? What does the other side look like-- could you have had it out and flipped it, and had a flake of grit get under the washer? No corresponding marks that I can see on the flywheel surface. Was there any "swarf" in the seal cavity?
The only other explanation is prankish spririts (poltergeists, if ya will)... ![]() --Bill
'73 R60/5 Toaster |
03-12-2013, 04:56 AM
#133 |
Mike
Oddometer: 126
I agree,Bill - kinda creepy. But to answer your questions, no, never had the thrust washer off before and, yes, crank turns freely with this thrust washer on, without the seal and fully torqued. No swarf or debris in the cavity. Here's the other side of the washer -
![]() And, for what it's worth -
03-12-2013, 08:02 AM
#134 |
ShadeTreeExpert
Oddometer: 4,992
Fortunately these are not very expensive as I remember. Since the engine wasn't run it is debatable if the bolts need to be replaced. The safe bet is to replace them.
Is it possible that any mysterious liquid got spilt onto the bearing? There are some things that eat the Bronze material a bearing is made from. Anti-Freeze comes to mind but I don't know how this or anything else got to the bearing? Very strange indeed.
03-12-2013, 08:42 AM
#135 |
Oddometer: 3,865
Mysterious. That thrust washer has been in that position forever-- see the oil drain hole "shadows". The damage doesn't look recent or like an impact or gouge-- almost like a manufacturing defect. This washer may be reusable, or to be safe, order one the same thickness and another the next thickness smaller.
I be puzzled. --Bill
'73 R60/5 Toaster |
