02-04-2013, 01:24 PM
#1 |
Oddometer: 68
How to look after the chain (offroad)
Hi,
I would like to receive some advices about how to look after the chain if I plan about 2500miles mid-extreme trip through mud, rubble, sand... (Morocco) I have heard two opinions: 1. off road designed spray (never believed in that). 2. dry chain all the time as it is causing less damages to the chain. |
02-04-2013, 01:59 PM
#2 |
Oddometer: 51
In your case I'd start with a new one (x ring?).
Go for a couple of short rides to wear off factory oil/grease. 1) Adjust to specification. 2) Lube chain via inside links with o-ring compatible oil (no fling is what I prefer...don't much like something that can get on my wheel/tire especially if riding on pavement). Don't like the wax types either due to the residue they leave. Motul is what I have been using. 3) Wipe excess off to clean exterior of chain so that dirt does not accumulate on links. Go on your ride and repeat steps 1-3 as necessary. Take along rivet chain breaker and extra master link/clip. Don't forget to take a can of chain lube with you. Sounds like an exciting ride! |
02-04-2013, 02:10 PM
#3 | |
Oddometer: 345
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?) |
02-04-2013, 02:32 PM
#4 |
Oddometer: 68
I have a DID Xring chain (just fitted)... slack is ok.
I have somewhere a can of Motul Off-road chain spray but not sure about it... it is like a gel... Thats why I have heard opinion that if you keep chain totally dry then all mud and sand goes off from between the links... if you keep chain wet then all that shit will stay between the links together with a lube... So I'm very confused. |
02-04-2013, 02:37 PM
#5 |
AWD please!!
Oddometer: 3,867
I run my plated DID X ring chains dry. I've noticed no difference in life over lubing. 15,000 miles is good enough for me.
After a sloppy, muddy ride, I hose the bike and chain down. Spray it WD-40 and wipe it clean with a rag. Chain lube is a pain if you plan to travel any where and it takes up too much room on the luggage. That's just me though. Maybe I'm just lazy.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
02-04-2013, 03:25 PM
#6 | |
Ride more, BS less!
Oddometer: 8,448
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150 Hi/low beam conversions for: Trail Tech, Baja Designs |
02-04-2013, 04:10 PM
#7 |
In my old Honda Africa Twin I used a Scottoiler, and when I went off road in the Chilean Atacama desert I just opened a little more the regulation, this way the oil was cleaning the chain continuously. Each chain kit lasted 60.000 km. I used just 2 kits before sell the bike.
The same on the rain.
DiasDePlaya "Ya veras como quieren en Chile al amigo cuando es forastero" Traditional song |
02-04-2013, 04:17 PM
#8 | |
AWD please!!
Oddometer: 3,867
Bike HP might play a roll in that longer life too??? 55 HP, vs 100 HP. 1/2 the HP = 2x the miles. I would agree with that. Those oilers sound great for road riders, but also sound like a constant mess. I'd hate to see what the swing arm, sprocket area would look like in my off road use.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! cjracer screwed with this post 02-04-2013 at 06:01 PM |
02-04-2013, 04:29 PM
#9 |
bikaholic
Oddometer: 1,540
I've always done the same with wd 40 on all my off road bikes and have had no issues.
02-04-2013, 04:45 PM
#10 |
Oddometer: 300
Keep it adjusted and run it dry. Works for me as well.
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo- 2006 KTM 950 ADV S http://www.mdfeditions.com/ http://www.cjdesignsllc.com/ |
02-04-2013, 06:41 PM
#11 |
Zoob
Oddometer: 1,019
40 years of experience with chains here.. They used to be real crap. The new X-Ring chains are great, they last longer than a GS drive shaft. The O-ring chains are so-so, the extra 20% in cost will more than double the miles.
Get a Grunge Brush, cut the handle down to pack better. $13 Fill a Squirt bottle full of cheap 90 wt gear oil. $2-4 On the road, just drain the dregs from a few bottles at a service station. Put the bike on the centerstand, start it, 2nd gear idle, brush off all the dirt and lube it with the gear oil. Do it when you end your ride and the chain is still hot. In the morning wipe up any excess from the bike and chain. Good for 500 road miles. Repeat it when you leave the dirt and are to ride on pavement for a while. It will look like new after a few miles. It's messy below the front sprocket, but it's just oil and dirt. Not chain glue and dirt, so it wipes off. Never use the chain wax, you'll get about 10k miles. Dry, you may get 12k miles. Lots of WD40, maybe 13k miles. I got 45,000 miles from my original 950 chain. It still was mostly ok, but had a few loose links. I inspect the chain every tire change, go through and inspect each link. These typically fail by a few loose links, usually at the master link. I replace the chain and front sprocket only, the rear doesn't wear. I've never bought a rear sprocket for my ADV bikes. Never run it too tight, that's a recipe for toast.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
02-04-2013, 06:43 PM
#12 |
Destination unknown
Oddometer: 475
"Keep it adjusted and run it dry. Works for me as well."
and I as well.... 26k miles on the oe chain with a little wd40 now and then to keep the rust off.
__________________ 2004 KTM 950 ADV 2001 Duc ST4 1973 trail90 2006 CBR600RR Track only |
02-04-2013, 07:00 PM
#13 |
Team Lurker
Oddometer: 103
I read 950, but I hear a KLR owner
![]() Put the brush in a toothbrush holder for easy clean packing, and I've used a ketchup squeeze bottle well on the road. I also find that gear oil mess is far easier to clean off your bike then any the residue from spray waxes or non-fling spray lubes. Tried spray grease a few years ago, and found them to be the most useless - that was the least mileage I got out of a chain. Pet peeve of most mechanics in SE Asia; they will tighten your chain crazy tight. Anyone have experience with those chain lubes that penetrate o and x rings, with just one tiny drops needed for each link? |
02-04-2013, 07:14 PM
#14 | |
Oddometer: 97
Not worth it...Just roll the damn tire with your hand.
Craig A. '09 990 ADV |
02-05-2013, 03:38 AM
#15 |
Oddometer: 35
I fitted a large capacity Scottoiler behind the rear registration plate. The large capacity unit holds sufficient oil for 5,000 miles of riding . To make the system robust when off-road I simply drilled a small hole in the top of the front sprocket cover and drop the oil onto the chain inside the plastic cover. Its clean (as any fling happens inside the sprocket cover) and the oil line is out of the way of off-road debris and rocks, flailing feet etc.
When I rode from UK to Morocco I rode with it on normal setting through France, Spain and the first tarmac in Morocco . In the south, in deep sand I turned off the oil flow and wiped off excess oil from the chain. When getting back into highway I just turned it up high for 25 miles and flushed all the sand off. I run my chain a little looser that specified, especially in the rough with luggage on the bike where the swinging arm movement is close to maximum. The last chain lasted more that 25,000 miles, during this time I only adjusted it 5 or 6 times. |
