Old 02-10-2013, 03:29 PM   #16
wrk2surf
BITD/Rallye
wrk2surf's Avatar
Oddometer: 5,312
Originally Posted by stickit View Post
TPS ?? Makes me wonder why replace , as carbies are far as I now reliable to the death, just keep it clean and jetted I have been having a heap of trouble with the trip and speedo ; can;t get it to find -1 on the trip diameter . It won't run thru the number + or - . , this makes the speedo go off the scales for speed . This is not the last of my questions !!
battery needs replacing more than likely on the speedo
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle
wrk2surf is offline   Reply With Quote
Old 02-10-2013, 09:29 PM   #17
bmwktmbill
Traveler
Oddometer: 4,015
Stickit,
Carbs need to be rebuilt either because to prolonged use or old age...yours is senile.
http://www.google.com/search?sourcei...US495&q=senile
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 02-12-2013, 12:15 AM   #18
stickit OP
Oddometer: 32
Done it twice ! First time went go for 48hrs riding then turned it on and had to reset but it won't show the -1 wheel diameter so went all wonky again . New battery again and same thing . New bat again and kept hitting the scroll button and it finally came up , have not had a chance to test it on the road yet . Someone said it might have to be sent away and be reprogrammed ; no idea .
stickit is offline   Reply With Quote
Old 02-12-2013, 01:33 PM   #19
bisbonian
bisbonian's Avatar
Oddometer: 893
My IMO unit was scrap.
I know there are plenty out there who had their IMO fail from this era.
I replaced it with a Trail Tech Vector.
This has worked well for me for almost two years now.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 02-12-2013, 03:22 PM   #20
biensur22
biensur22's Avatar
Oddometer: 182
I had this same issue when i bought my '98. Your tripmaster battery is going bad. It is located deep within the tripmaster unit, and needs to be replaced. It's coated in several layers of hot glue and spot-welded to the terminals. Open her up to find the proper battery # and purchase a replacement. They're $5US.
As for the circumference adjustment, you must hit the down arrow many times. It will cycle through several times with erratic numbers and eventually display a declining sequence in numerical order. But you have to press the down arrow nearly 100 times. PM me if you have other questions. I may be able to find photos. Very easy fix.
biensur22 is offline   Reply With Quote
Times are GMT -7.   It's 01:20 AM.
