Old 02-04-2013, 06:22 AM   #1
efria OP
Oddometer: 17
Used KTM buying advice
I'm thinking about getting a used KTM 400 XC-W. I found one locally that seems to be in good shape (although I've only given it a cursory look). Are there anythings specifically that I should be looking for?
Frame and other obvious mechancial issues are easy enough, but what about the things I cannot see visually? The bike has 100 hours on it (as advertised) - what maintenance should I expect the bike to have at that point (other than standard oil changes).
The listing price is $4,995 - general opinions on that? If all of the mechanicals seem up and up, I'm thinking of offering i $4,500.
Thanks in advance!
efria is offline   Reply With Quote
Old 02-04-2013, 06:48 AM   #2
jar944
jar944's Avatar
Oddometer: 710
What year? The 08's had some issues, better in 09 and fixed by 2010.
jar944 is offline   Reply With Quote
Old 02-04-2013, 06:50 AM   #3
efria OP
Oddometer: 17
Sorry-the bike is a 2009 model year.
Old 02-04-2013, 09:24 AM   #4
everetto
everetto's Avatar
Oddometer: 333
Drink the Kool-Aid man!
everetto is offline   Reply With Quote
Old 02-04-2013, 09:29 AM   #5
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,389
Ditto great bike. great motor. If it is in good condition and motor runs well got for it.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 02-04-2013, 06:06 PM   #6
efria OP
Oddometer: 17
Going to see the bike tomorrow - very excited. Really would appreciate some feedback on any subtleties that I should be looking for...
Old 02-04-2013, 06:10 PM   #7
zeroblah
Snot nosed kid
zeroblah's Avatar
Oddometer: 342
There is a broke down 2001 ktm 300 in my garage. (And its not mine), that tells me everything i need to know.
Sent from portable brain.
zeroblah is offline   Reply With Quote
Old 02-04-2013, 07:12 PM   #8
SRG
SRG
SRG's Avatar
Oddometer: 1,287
Quiz the owner on maintenance - how often was the oil changed, always w/ filter? And the air filter?
Does the owner seem knowledgeable about the bike? Strike you as someone who takes care of their stuff? What does their garage/house/yard/the rest of their stuff look like? Well cared for?
Looking the bike over - Is it cleaned up ready to sell? Look at the brake pads - good thickness? Rotors look good (no deep grooves/scratches). Spokes all there and not loose or corroded? Rims straight? If you can, get the wheels off the ground and spin them - everything look true, no weird noises? If you lift on the front wheel, is there movement in the headstock? Any sign of oil leaks? - look at the countershaft sprocket area and around the gear shift shaft for weepage. Chain and sprockets look good/run smoothly. Is the chain adjusted properly/not too tight? What about the fasteners - any rounded heads? are they rusty? any missing? Is the oil drain plug buggered up? Air filter clean and properly oiled? Is there a bead of grease on the rim (of the air filter, where it sits in the airbox)? If you pulled the airfilter to look - is the intake beyond clean? All the electrics work?
A couple of minor fails on the above may be OK, a repeating pattern of fails is not.
Lazy Traveler
SRG is offline   Reply With Quote
Old 02-04-2013, 07:29 PM   #9
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,257
You can tell a lot about the bike by talking to the owner and looking at his shop.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Times are GMT -7.   It's 01:16 AM.
