Old 02-04-2013, 11:34 AM   #1
FredRydr OP
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,462
BMW topcase and Jesse rack?
Will the Jesse rack for Odyssey panniers preclude use of the F800GS Vario top case?
Fred
FredRydr is offline   Reply With Quote
Old 02-04-2013, 11:53 AM   #2
nytrashman
old and in the way
Oddometer: 593
i have jesse boxes on my 650 twin and a givi top box. i had to use some shims to move the rack out approx 1/2" so the jesse boxes would open without hitting the top box. i am sure you will have to do the same thing when using the BMW top case.
you can see in this pic the unpainted shims on the left that move the jesse rack out enough to allow the boxes to open.
2007 R1200R
2009 G650GS
20011 F650GS
nytrashman is offline   Reply With Quote
Old 02-04-2013, 12:12 PM   #3
FredRydr OP
FredRydr's Avatar
Oddometer: 2,462
Thanks, but will the Jesse rack preclude re-installation of the mounting plate for the Vario top case?
Fred
FredRydr screwed with this post 02-04-2013 at 12:53 PM
Old 02-05-2013, 01:36 PM   #4
GH41
Oddometer: 822
Fred
You will have to either cut the rear post on the Vario plate down or shim the front post up and buy 4 longer bolts. I chose to cut the rear post and use the supplied bolts. GH
GH41 is offline   Reply With Quote
Old 02-16-2013, 11:12 AM   #5
FredRydr OP
FredRydr's Avatar
Oddometer: 2,462
Is that the steel part or the plastic part that you cut? I can buy the steel part from a fellow inmate.
Fred
FredRydr screwed with this post 02-16-2013 at 11:27 AM
Old 02-17-2013, 03:44 AM   #6
GH41
Oddometer: 822
The plastic Vario base plate has a steel core. You have to cut down the rear post by the height of the Jesse crossover piece. I'll put up a picture later. GH
GH41 screwed with this post 02-17-2013 at 03:52 AM
Old 02-25-2013, 05:22 AM   #7
FredRydr OP
FredRydr's Avatar
Oddometer: 2,462
Thanks, GH. That should help.
Fred
Old 03-30-2013, 12:07 PM   #8
FredRydr OP
FredRydr's Avatar
Oddometer: 2,462
GH,
I pulled the steel plate under the topcase bracket. Which posts did you cut down, and by how much?
Fred
Old 03-30-2013, 03:43 PM   #9
GH41
Oddometer: 822
The rear post. Think about it... You have to remove the material that the Jesse cross piece now occupies. I am not able to check right now but I remember cutting the post almost down to the plate. If you cut too much or too little it's no big deal as long as you can start the bolts. GH
Old 03-31-2013, 06:30 PM   #10
RheinGold
Weniger aber besser.
RheinGold's Avatar
Oddometer: 36
I have the Jesse bags and the Vario top case (on the OEM rack). You are correct they don't work together...adding the Jesse case racks places the BMW top case rack at an angle so you can't get all four bolts in.
However, Al Jesse has a simple solution...he sent me two spacers and longer bolts and it goes together perfectly, although the Vario case/rack does end up about 3/4" higher than it would otherwise be. But, it really makes no difference...works great.
www.irahaskellphotography.com
RheinGold is offline   Reply With Quote
Times are GMT -7.   It's 05:06 AM.
