Old 02-05-2013, 06:58 PM   #16
craydds
craydds's Avatar
Oddometer: 1,167
Originally Posted by One Less Harley View Post
get the after market brass one from Hucky's, the OEM will leak in a year or less. Epoxy may or may not work, so take a chance on using it and having it leak.
I have gone through 2-3 OEM ones, and have had the brass one in for a 1.5 years of leak free operation.
Thanks for the advice; will get a neutral switch from Hucky's if I ever need one. I would advise LandLeftBehind not to repair an old switch - just get a new one, like One Less says.
p.s. My neutral switch is original, no leaks! How old is that, 38 years?
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 02-05-2013, 07:27 PM   #17
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,233
Do use a high pressure grease! It needs to be something that doesn't squish away under high pressure. It's usually pretty stringy stuff and doesn't clean up easily by wiping with a rag.
As for the neutral switch - just get the brass one from Motobins. Not expensive and they're not supposed to leak. The new BMW switches seem to not last longer than a year. And since you're pulling the trans, or moving it back, there's no need to pull the rear engine mount tube in the block. I would recommend just pulling the trans rather than only pulling it back.
Well done finding a place to work on the old girl! She's got a bit more 'character' than this time last year, huh?
Old 02-05-2013, 07:55 PM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,568
+1 on this. Sliding the trans back doesn't really save you much time at all and guarantees that you won't do a great job of cleaning and lubing the splines. Plus with all the disassembly work you'll need to do, you might as well just do the last step and get it apart so you can get a good luck at everything else inside, not just the splines.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 02-05-2013, 07:56 PM   #19
LandLeftBehind OP
Oddometer: 155
My main concern with fully removing the transmission is unfastening the drive shaft u-joint. My bike is in my shop space, and Im having trouble visualizing the parts from the fiche, but would it simply be a matter of rolling back the rubber boot and unfastening the special bolts (reversing for reassembly)? If so its probably not as big of a deal as im making it out to be.
Btw the Honda moly 60 is on its way via mail. Ill be sure to get a switch in the mail and pick up some wheel bearing grease for the throwout parts this week!
We have left the land, and have embarked...
LandLeftBehind screwed with this post 02-05-2013 at 08:01 PM
LandLeftBehind is offline   Reply With Quote
Old 02-05-2013, 07:59 PM   #20
LandLeftBehind OP
Oddometer: 155
You can say that! Sometimes I look at the pictures I took when I first got the bike.
Old 02-06-2013, 11:32 AM   #21
craydds
craydds's Avatar
Oddometer: 1,167
LLB, there are some pics of driveshaft installation in post #140 here http://www.advrider.com/forums/showt...848159&page=10 ; you may need to move your swingarm backwards to have room to remove the trans - there are a some pics of swingarm install in post #118, same thread. just do the removal in reverse steps.
1. loosen and remove the clamps on the swingarm boot, pull back the boot off of the trans.
2. lock the rear brake and remove 1 driveshaft bolt; unlock brake, rotate rear wheel to next bolt, lock brake and repeat.
3. bolts are all out. you can re-use the bolts if they do NOT have lock washers. the new, short bolts do NOT use locks and can be used again. the old bolts with locks have to be replaced.
4. now remove the swingarm locknuts and bolts so you can pull the swingarm backwards.
5. take that transmission OFF.
ABC #12947
'75 R90S
craydds screwed with this post 02-06-2013 at 05:04 PM Reason: same
Old 02-06-2013, 12:07 PM   #22
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,926
Yes the drive shaft rubber boot pulls back and the four 10mm bolts are undone. I use the tool kit box end wrench but another 12 point box end wrench will fit, most of the time. There is a limited amount of space to get the wrench in but you probably have one that will fit.
Be careful with the skinny clamps on the boot. There are available at the dealers as I remember but I thought they weren't exactly cheap.
---Albert Einstein
disston is online now   Reply With Quote
Old 02-06-2013, 01:34 PM   #23
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,904
Is it interchangeable? ..... same thread length? 'cuz the brass one is listed for pre-'76 (i.e. Slash 5's and early Slash 6's)....
I hope that the "new" aluminum one that I just put in (MAX BMW part) isn't crapola.......
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 02-06-2013, 01:44 PM   #24
Mugwest
Mugwest's Avatar
Oddometer: 6,734
My question as well. I somehow missed that there was now a brass aftermarket N switch
Mugwest is offline   Reply With Quote
Old 02-06-2013, 04:51 PM   #25
sigpe57
Oddometer: 341
Put the Crasftsman crowbar here and push down the crowbar. You will be able to push the aluminum tube up and out.
sigpe57 is offline   Reply With Quote
Old 02-06-2013, 05:16 PM   #26
LandLeftBehind OP
Oddometer: 155
Great, that sounds simple enough. I dont have to mess with the suspension do I? Im hoping it will not get in the way of removing the trans while simulteously keeping the rear wheel supported...
LandLeftBehind screwed with this post 02-06-2013 at 05:25 PM
Old 02-06-2013, 05:25 PM   #27
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,926
LLB,
I discovered several years ago that sometimes short cuts are just not what we think they are. I tried to remove the rear end of the bike by taking it all off as one piece. It was cumbersome and hard to handle. When It came time to put everything back together it was rather impossible to handle it. So I still had to take it all apart.
Now when I take the trans out any time, I take the rear wheel off and the sub frame and shocks come off. Oh, I have bags so the racks come off. I take the final drive off and I take the swing arm off. I take each and every one of these parts off the bike as an individual piece. And then I put them all back the same way. I know this goes contrary to anybody that thinks shortcuts work but for me it is faster this way.
Good luck.
---Albert Einstein
Old 02-06-2013, 06:49 PM   #28
ME 109
ME 109's Avatar
Oddometer: 3,022
Originally Posted by disston View Post
LLB,
Good luck.
There is a difference between a short cut, and the quickest way to do a job.
I can have my tranny on the floor in about 45 minutes. It must take you a long time disston?
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 02-06-2013, 06:51 PM   #29
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,809
there are two different types of brass replacement switches, early and late.
The OEM- I've been through three and they have all leaked in less than a year. The bras replacement has been in there of 1.5 to 2 years and is dry as a bone.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-06-2013, 07:18 PM   #30
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,926
I think I used to be faster but I am working outside and on the ground. I can have the trannie out in not more than an hour I'm sure. If I was trying to hurry, much less.
I don't think most shortcuts are a savings of time or energy. Leaving the final drive attached to the swing arm makes the whole thing cumbersome and difficult to handle. And all for the sake of removing four nuts.
---Albert Einstein
Times are GMT -7.   It's 07:08 AM.
