Old 02-25-2013, 08:06 AM   #151
alpster87
alpster87's Avatar
Oddometer: 7
You are correct in your technique which is the next step in the manuel ,however both should be done as it gives a better look at the strength and or remaining spring tension left in the Rings ...
sometimes making a wrong turn, Makes the ride better
alpster87 is offline   Reply With Quote
Old 02-25-2013, 08:57 AM   #152
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,799
Originally Posted by alpster87 View Post
... Note; Before installing piston rings measure the free end gap of each ring using vernier calipers Therefore putting no blame on anyone in the Forum for his own misfortunes..
free end gap doesn't really tell you anything with regards to installing a new piston/ring set... ring gap in the bore is all that really matters unless you're thinking of re-using old rings and checking for service limits..
dang OP, i just read this thread by recommendation of a buddy. i was a little skeptical during some of your build posts, and then ecstatic for you when you got 'er fired. and now share everyone else's sentiments that you learned a hard lesson. but hell, it wouldn't be fun if it was easy. now you've got a good story to tell in 30yrs when some kid tells you how he's going to build the baddest engine on the block!
good luck on getting her back on the road!
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 02-25-2013, 01:58 PM   #153
alpster87
alpster87's Avatar
Oddometer: 7
I was making the point that the op had read the manuel from cover to cover and that all the information he needed to install his new and super cool parts was there in the text ... yes maybe the manufactures specs may have been slightly different ,but even the factory specs probably would have stopped him from having this problem... I too hpoe to here that he is on the road soon
Old 02-25-2013, 03:45 PM   #154
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Originally Posted by desmodab View Post
Interesting that not one of these guys happened to mention it or suggest it to to the OP in the first several pages of his posts as he was doing the installation.
Pg. 5, post #65
VooDooDaddy is offline   Reply With Quote
Old 02-25-2013, 03:53 PM   #155
VooDooDaddy
Oddometer: 163
Sorry to here about OP`S misfortunes as well ,however in his first posting he states how he has read the service manuel from cover to cover ...and in the manuel it says to check ring end gap before installling piston in a step by step instruction for cyl and piston install... Note; Before installing piston rings measure the free end gap of each ring using vernier calipers Therefore putting no blame on anyone in the Forum for his own misfortunes..
Can I get an Amen?
While I do feel for Planemanx,...this is no one else's falt. As many have said, if anything this is a very valuable learning experience for him as well as many others watching this thread. In an attempt to be pragmatic, what it will take to fix this problem, in the grand scheme of things is peanuts. Compare the cost of this fix in relation to the amount of $$$ most of us will and should earn in a lifetime and the percentage is almost insignificant.
The knowledge gained will pay for itself later on, although it's tough to see it that way now for Planemanx, I would assume. Gapping the rings properly is the owner's responsibility. Nobody elses.
I gotta say, IMHO, our society has done a great job of convincing a great majority of us that we are not responsible for our actions, decisions, and futures.
Old 02-25-2013, 04:27 PM   #156
procycle
procycle's Avatar
Oddometer: 2,412
Originally Posted by Xcuvator View Post
There should have been a bold notice in the directions.
It's all laid out in the ring fitting instruction sheet that comes in the kit. There's a formula and an example of how to calculate the ring gap based on the bore size and the kind of application where the motor will be used.
It's the engine builders responsibility not only to gap rings but to make sure the proper fit for any critical parts.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-25-2013, 04:43 PM   #157
procycle
procycle's Avatar
Oddometer: 2,412
Originally Posted by Rob.G View Post
Jeff has some great points on the pre-gapped stuff. Hey Jeff... any thoughts on doing up a page on the ProCycle site that has step by step instructions on gapping rings? The ones you have on the fork and shock builds are great.
Yeah, next opportunity I'll do a little pictorial.
Old 02-25-2013, 04:47 PM   #158
procycle
procycle's Avatar
Oddometer: 2,412
Originally Posted by Rustycage View Post
This kinda leads into my question, is there a next size overbore piston available? Or does cylinder need to be resleeved, say if it goes out of spec due to wear?
No overbore
Old 02-25-2013, 07:56 PM   #159
planemanx15 OP
planemanx15's Avatar
Oddometer: 1,009
Alright, I've been quiet lately, lets get this back on track. I understand this is completely my fault, and no others. I should have researched more. This was my first time doing anything of this magnitude. I love working on my motorcycle, and things sometimes go wrong. Shit happens, deal with it, learn from it, and move on.
My cylinder is on its merry way back across the country to procycle, where Jeff graciously offered to hone it and check that it is still in spec. If so, it will come back; if not, I guess I'll be buying another...
My piston is in my garage as a friendly reminder to check over my work all the time.
After work today, i cleaned up my work area. As somebody said in either this thread or the big DR thread, I should organize my area better.
It still looks messy, but all the parts are now laid out, and all the tools away, ready for use next time. I checked my feeler gauge, and I have all the correct sizes for the ring gaping process (Top ring: .020" 2nd ring: .024-.028" Oil ring: .015") I'll try to remember to gap them on the next installation
Out or curiosity I ripped open the oil filter... WARNING: Some of you might cry at what your about to see:
That's a lot of metal. I peeked into the gears through the cylinder hole in the engine, and didn't see any flakes, but I will still flush the engine out anyway. Glad I bought that 10 pack of oil filters from Procycle.
For now, i guess Ill be riding my other horse, a 2009 Piaggio BV-250. Its actually a load of fun (if your a scooter nerd like me). I get more looks on it than the DR:
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 screwed with this post 02-27-2013 at 06:42 PM
planemanx15 is offline   Reply With Quote
Old 02-25-2013, 08:20 PM   #160
alpster87
alpster87's Avatar
Oddometer: 7
Well I dont want to be the grump in the crowd but with that much crud in the filter i dont believe flushing it out is going to do the job .All that aluminum has gone straight to the lower con rod and the main brg`s it may last for quite some time but my guess is you will have a premature failure of this engine in the future if crank and mains and oil pump are not addressed ,just my opinion. I am sure others will say differently
Old 02-25-2013, 08:39 PM   #161
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,219
Welp, looks like you have some more work to do while waiting for the new parts to arrive. I'd build one of those case-splitting tools like Jeff has and plan to split it. Might as well. It doesn't look all that hard from reading Jeff's thread on DRRiders where he's assembling his 900 stroker motor (if you haven't seen that thread yet, go find it, it's awesome, tons of great photos).
If it's in your budget, you might wanna go ahead and do what I was going to do -- replace all the bearings and the timing chain while it's apart. From the photos in that thread, it looks pretty straightforward, especially if you have a service manual.
At the very least, pull everything out and clean it good like the others suggested.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-25-2013, 08:40 PM   #162
xlcc
Oddometer: 137
790 big mess
planemanx15,it looks like more than an engine flush job to me.When you see a filter that looks like that don't ignore the warning signs,it is time to organize a clean work space and get some more tools out and get at 'er!
xlcc is offline   Reply With Quote
Old 02-25-2013, 09:02 PM   #163
desmodab
Oversized Canuck
desmodab's Avatar
Oddometer: 356
Best to check it now. Better safe than sorry...
Victoria to San Francisco and SoCal Ride Report
2011 Multistrada 1200 S Touring, Red
desmodab screwed with this post 02-25-2013 at 09:15 PM
desmodab is offline   Reply With Quote
Old 02-25-2013, 10:01 PM   #164
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,787
+1
Sent from my SGH-I747M using Tapatalk 2
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 02-26-2013, 05:35 AM   #165
davesupreme
grand poobah
Oddometer: 1,643
i just read all this at the DR site...
http://drriders.com/topic6662.html
ProCycle, truly.... you 'da man!!! that's some really bad shizzit!... i like my KTM, but now i feel i really shouldn't have read that....
some really excellent work, dooder!... no shortcuts, excellent machine work and attention to detail... god, i wanna ride that thing!...
davesupreme is offline   Reply With Quote
Times are GMT -7.   It's 06:36 AM.
