Old 02-26-2013, 06:11 AM   #166
planemanx15 OP
planemanx15's Avatar
Oddometer: 1,009
Originally Posted by davesupreme View Post
i just read all this at the DR site...
http://drriders.com/topic6662.html
ProCycle, truly.... you 'da man!!! that's some really bad shizzit!... i like my KTM, but now i feel i really shouldn't have read that....
some really excellent work, dooder!... no shortcuts, excellent machine work and attention to detail... god, i wanna ride that thing!...
Just read that as well, wow! Can't wait to see that thing move.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-26-2013, 08:52 PM   #167
Tech23
Tech23's Avatar
Oddometer: 470
Those aluminum fragments went through the sump filter and pump before ending up in the filer media. The whole lubrication circuit should be looked at and flushed, it doesn't take much debris to clog or restrict oil galleries and flow.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 03-01-2013, 12:47 PM   #168
procycle
procycle's Avatar
Oddometer: 2,412
Originally Posted by Rob.G View Post
Hey Jeff... any thoughts on doing up a page on the ProCycle site that has step by step instructions on gapping rings? The ones you have on the fork and shock builds are great.
While I had Planemanx's cylinder here I went ahead and set the ring gaps for him and took a few pics along the way.
You can find it here --> http://www.procycle.us/info/articles...ring-gaps.html
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 03-01-2013, 01:01 PM   #169
shoein
Oddometer: 186
Thank you procycle. That's an excellent tutorial.
shoein is offline   Reply With Quote
Old 03-01-2013, 01:06 PM   #170
MADurstewitz
MADMark
Oddometer: 159
Split the cases. Replace the bearings. The crank assembly you can probably flush out if you do it thoroughly. Worked when I did mine.
Simplybearings in the UK has great bearings at great prices. I replaced everything in my lower end (except the crank) with SKF. Much, much better bearings. Size yours carefully and note which sides are sealed before you remove them. Take pictures! Use your oven to remove and replace the bearings. 20 minutes or so at 350F. They drop right out.
The bearing on the input shaft behind the clutch has a pin in it (mine was also chinese). Bearing retaining compound will keep that in place without the pin. My bike has 11k miles on the 790 kit and rebuild and runs as smooth as a babies ass.
Do it right and ride it a lot. Break in per motoman. Very effective.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 03-01-2013, 02:00 PM   #171
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,551
Great read.
PlanemanX, Sorry you had to learn from a mistake the hard way, but if you ever make it out to AZ the beers on me for letting me potentially learn from your mistake.
The bike looks awesome, and I can't wait to see it completely done.
ProCycle, as always, top notch.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 03-01-2013, 07:23 PM   #172
road_apple
Hit the Trail
road_apple's Avatar
Oddometer: 156
Down the road
Planemanx15 and Procycle are my heros. In the face of 'internet blowby' by others not gapped properly these two continue to go to it. Although not a DR person I will make it a point to order items from Procycle for my spring work. Here is a related info link for some:
http://www.enginebuildermag.com/Arti...orsepower.aspx
road_apple is offline   Reply With Quote
Old 03-02-2013, 06:27 AM   #173
bkoz
bkoz's Avatar
Oddometer: 331
Excellent tutorial.
bkoz is offline   Reply With Quote
Old 03-02-2013, 09:44 AM   #174
planemanx15 OP
Oddometer: 1,009
Alright guys, just an update. The new piston and my honed out cylinder should be arriving back on my door step on Monday. Procycle sent me an after pic of the cylinder, and it looks great. he said he wouldn't have a problem running it in his bike. For a guy running a buisness, he wasn't pushy at all about buying a new kit from him. He also gapped the rings (for the tutorial) so the kit is now plug and play. I will still go slow with the install and check over everything again, but I'm confident with my knowledge now to do it all correctly. I'm off on Tuesday and Wednesday this week, so I'll probably install it then.
As for the metal in the engine. I do not feel comfortable enough to tear open the engine, so I will just be doing many oil changes in the first 100 miles. If I continue to see metal towards the 100 mile mark, I'll man up and open the engine. I believe with constant oil changes and a mag drain plug, it will be alright. Again, if I run into problems down the road, its nobody's problem but mine. There was no metal flakes on the con-rod or in the gears towards the bottom and back of the case, so I believe the oil system is doing a good job of cleaning it.
planemanx15 screwed with this post 03-02-2013 at 08:46 PM
Old 03-02-2013, 10:00 AM   #175
canuckAME
canuckAME's Avatar
Oddometer: 726
You might want to try and back flush your oil cooler. The tubing in it can hold contaminents and by flushing it in the reverse flow direction you can get most out. Also blow out all your external oil lines with compressed air.
Lots of filter changes and remember your mag drain plug won't help with aluminium fragments.
If you pulled your clutch cover and leaned the bike over you could also try and flush out the bottom of the cases.
Good luck with it.
canuckAME is offline   Reply With Quote
Old 03-02-2013, 10:01 AM   #176
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
By all means flush out the oil cooler in a solvent tank and make sure the head and top end is clean. I would pull the clutch and rinse the plates too. Just about every nook and cranny is accessible without splitting cases or pulling the engine. Check the flywheel magnets too.
Hate gets you nowhere.
Old 03-02-2013, 11:18 AM   #177
planemanx15 OP
Oddometer: 1,009
Good luck with it.
Will do, Thanks for the advice guys!
Old 03-02-2013, 05:54 PM   #178
Süsser Tod
Süsser Tod's Avatar
Oddometer: 1,030
Magnetic drain plug won't help at all, what you have there are aluminum shavings and they are not magnetic.
Flush the engine thoroughly with kerosene and don't forget to flush the oil cooler too.
Süsser Tod is offline   Reply With Quote
Old 03-02-2013, 05:59 PM   #179
procycle
procycle's Avatar
Oddometer: 2,412
There won't be anything in the oil cooler unless it somehow got past the oil filter.
Old 03-03-2013, 08:58 PM   #180
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
I'm optimistic that the rest of the motor will be fine. If the filter plugged then the bypass valve would open and pump shavings
To the top end and gearset. Pop a valve cover and
Look for flecks that have settled in the valleys up top.
If it's clear, I'd feel pretty good about leaving bearings and stuff alone.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Times are GMT -7.   It's 07:25 PM.
