Old 03-17-2013, 09:27 PM   #226
planemanx15 OP
planemanx15's Avatar
Oddometer: 739
I haven't had time to ride, when I was off work, it got way cold and started to snow again... I think I have around 50 miles on this tank. I haven't been riding it too hard, or too soft. Just a normal pace.
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb.
1985 Yamaha CA50 - My Hot Rod
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 03-17-2013, 09:43 PM   #227
Dalmatino
Dalmatino's Avatar
Oddometer: 215
Just curious about vibration with the big piston?
DR is one of the smoothest big singles when stock and I hate the thought of loosing that.
Dalmatino is offline   Reply With Quote
Old 03-18-2013, 07:43 AM   #228
bkoz
bkoz's Avatar
Oddometer: 183
Originally Posted by wvdirtbiker
I would like to see this package of piston, rings and cylinder come with the rings set to the MINIMUM gap that would not cause damage to the engine.
Originally Posted by VooDooDaddy View Post
Christalmighty...!
If you are that much of a novice, then I highly, highly recommend you stay away from the inside of any motor. The ring end-gap is one of the most basic procedures of any engine build.
What's next, disclaimers about cylinder head torque, piston ring spacing, proper cam timing, RPM during new cam break-in, etcetera...?
Wow
Agreed!!
The ring end gap needs to be checked with an OEM piston and rings let alone a big bore upgrade.
If you are unsure about this procedure you should pay a pro to do it.
bkoz is offline   Reply With Quote
Old 03-18-2013, 07:49 AM   #229
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 199
2006 Suzuki DR 650 ADV
Rainier_runner is online now   Reply With Quote
Old 03-18-2013, 09:28 AM   #230
planemanx15 OP
Oddometer: 739
At first, I thought that it vibrated more, but that was because I went from riding my Piaggio which is smooth as silk to the DR. When comparing the two, it doesn't seem to vibrate more then it used to. Vibration was a big concern to me as well, and it worked out great.
Old 03-18-2013, 10:11 AM   #231
davesupreme
Oddometer: 299
Originally Posted by bkoz View Post
Agreed!!
after seeing all this, i think these dorks are trollin' just to get a rise....
davesupreme is offline   Reply With Quote
Old 03-18-2013, 02:12 PM   #232
MADurstewitz
MADMark
Oddometer: 128
Mine was noticeably smoother. By a lot.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 03-19-2013, 08:06 PM   #233
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,760
Not related to the build, but I was able to plasti dip my tank matte gray to try and match my plastics.. It's not too close, but better then black. I might do all the plastics in this color.
Plastic dip claims its chemical resistant, Ill see how it holds up to fumes.
Ive never seen any sealer applied to a plastic tank that didnt bubble up,the plastic is infused with gas fumes and they perk slowly through it,best of luck.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W.
Foot dragger is online now   Reply With Quote
Old 03-30-2013, 09:36 PM   #234
planemanx15 OP
Oddometer: 739
I did another oil change today. I think there is about 180 miles on this oil. It came out clean, with minimal flakes. The filter was really clean too. I didn't take any pictures of it, but it was noticeable clean.
Ill probably let this next oil change go for a while. The dr790 is alive and well!!
Old 03-30-2013, 09:48 PM   #235
procycle
procycle's Avatar
Oddometer: 1,607
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 04-01-2013, 09:38 AM   #236
vicster
Oddometer: 550
Thanks for taking the time to share this.
Any MPG figures yet?
vicster is offline   Reply With Quote
Old 04-01-2013, 06:30 PM   #237
planemanx15 OP
Oddometer: 739
Not yet I'm only about 120 miles on the tank
Old 04-01-2013, 08:27 PM   #238
planemanx15 OP
Oddometer: 739
Forgot to mention, I took my girlfriend out today. She loves the new set up. To paraphrase her words "the bike doesn't feel like its struggling when we are on the highway, and it just glides when we are accelerating. It feels much smoother, and doesn't vibrate nearly as much. I really like it, and can't wait to do a trip" I never thought I would hear those words from her mouth without me persuading her lol
We actually got home and she was bummed out and wanted to go out some more... I can tell this is going to be fun...
Old 04-01-2013, 10:41 PM   #239
Carbster
Carbster's Avatar
Oddometer: 58
Im getting ready to install my 790 kit, pending my piston coating and a quick dyno run and tune prior to the mod. Once a goodbaseline has been done, I will start the build.
Those fog lights look strangely familiar, SBLEDs? I added a set with a PC Hid. The Led lights are unreal in the shop. I cant wait to get it off the lift and on a dark road! Night riding on the DR was off limits for a while. It was like riding a looking through a key hole at night!
Im hoping my mpg doesnt force me to buy a 747 gas tank. the fcr carb didnt hurt too much but im a solid 45-50 now and frankly I could run it leaner I bet.
Dyno sniffer will tell me all I need to know!
Carbster is offline   Reply With Quote
Old 04-02-2013, 11:19 AM   #240
planemanx15 OP
Oddometer: 739
Those lights are basically cheap walmart housings, that came with bulbs. I think they were MR-16 bulbs. Then I went online and bought those bulbs in LED format. They are great. lots of lighting on the side, and the HID goes solid down the road.
With the upside-down triangle I got going, it catches a lot of peoples attention...which as we all know is a good thing. I ride with them on day and night.
Times are GMT -7.   It's 09:04 AM.
