Old 02-24-2013, 05:00 PM   #121
davesupreme
Oddometer: 299
Originally Posted by Xcuvator View Post
I agree.
To say that they aren't gaped because the owner should have the option of deciding how much gap to use is lame.
There should have been a bold notice in the directions.
sorry dude, but i bet you're a democrat....
it's all gotta be somebody else's fault....
davesupreme is offline   Reply With Quote
Old 02-24-2013, 05:06 PM   #122
barko1
barko1
barko1's Avatar
Oddometer: 2,512
Pro cycle is a parts supplier and not a machine shop. I think they should be sure to give the customer specs and instructions and provide support if there are questions but they can't be responsible for my learning errors. Hope the cylinder is good amd bikr runs great when complete!
Sent from my SCH-S720C using Tapatalk 2
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi
barko1 is offline   Reply With Quote
Old 02-24-2013, 05:08 PM   #123
neo1piv014
ADV in training
Oddometer: 610
It's not about it being someone else's fault. Sure, this is some pretty intense work inside the engine, so there should definitely be some reading up that needs to be done before attempting this kind of project, but just something that says "the piston rings need to be gapped before installing" would at least let people know that it needs to be done.
Having never done any work inside the working parts of an engine, I'd never have known that it needed to be done, same as the OP. Still, PC and the OP are working on making everything right, and I'm sure this will turn out fine in the end. It's been an educational thread to say the least.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 02-24-2013, 05:20 PM   #124
doug s.
Oddometer: 1,169
+1. and it CERTAINLY has NOTHING to do w/what political party you do or do not belong to.
doug s.
doug s. is offline   Reply With Quote
Old 02-24-2013, 05:24 PM   #125
davesupreme
Oddometer: 299
sorry, but this ain't really a specialized incident.... any piston rings inside of any engine need to be gapped... there's this thing that happens when metal gets heated, called expansion..... jr. high science class..... and in different applications/alloys, the gap is different.... you can't argue w/physics.....
Old 02-24-2013, 05:27 PM   #126
doug s.
Oddometer: 1,169
agreed 100%. but it is extremely possible - likely even - that someone inexperienced w/this type of endeavour, would not know that the rings they yust bought - w/matching cylinder and piston - would not be plug-n-play...
doug s.
Old 02-24-2013, 05:40 PM   #127
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,116
I can't believe my quart of oil doesn't say, " torque the drain plug before pouring into the engine."
Just for the DIY crowd
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 02-24-2013, 05:41 PM   #128
itsatdm
NoMoTDM still Gary
itsatdm's Avatar
Oddometer: 3,711
Ok all you he men. What is the gap for these rings? I wouldn't think you would find in your Suzuki manual. If the specs are provided, then maybe you got an argument. If not you are just argumentative.
Maybe you and a machinist might know the thermal expansion differences between a forged aluminum vs cast pistons vs steel or nikasil covered aluminum cylinders but not everyone does.
My situation was a little different. I got a forged piston and took it to a machinist to bore the cylinder. The piston came with cylinder/piston clearances along with end gap recommendations. His recommendations was pretty spot on. But one way or the other, you kind of need that.
I am not saying anyone is at fault. The OP spent $2,000 and got what sounds like a plug and play installation. The cylinder has been machined to fit the piston. I don't blame the OP for assuming the rings also fit. If procycle provided ring gaps, then that should be a heads up. I am just saying it cost Procycle a hell of lot less to point that out, then some customer spending the money and not doing it.
Everybody who has done a big bore, raise your hand.
itsatdm screwed with this post 02-24-2013 at 06:35 PM
Old 02-24-2013, 05:47 PM   #129
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 144
That's why I mentioned the ring gap on pg. 5. post #65.
VooDooDaddy is offline   Reply With Quote
Old 02-24-2013, 06:39 PM   #130
TinkerinWstuff
Take it apart
Oddometer: 1,116
If I buy a sparkplug from Procycle for my DR is it also his responsibility to gap it for me or include a note that says to check the gap?
Thanks Jeff for all you've done for so many here and for your continued help for this guy. You are a class act in my book.
1999 Suzuki DR650
Old 02-24-2013, 06:58 PM   #131
planemanx15 OP
planemanx15's Avatar
Oddometer: 737
Originally Posted by tinkerinwstuff View Post
thanks jeff for all you've done for so many here and for your continued help for this guy. You are a class act in my book.
+1
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb.
1985 Yamaha CA50 - My Hot Rod
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-24-2013, 07:01 PM   #132
doug s.
Oddometer: 1,169
ya, i am sure yust as many folks have installed new pistons/rings/cylinders as have installed new spark plugs.
btw, i also think procycle jeff is a class act. which is why i bet he now goes out of his way to offer ring gap services and more deliberately point out the necessity of doing this in the future, for those who don't want to have it done for them.
doug s.
Old 02-24-2013, 07:02 PM   #133
doug s.
Oddometer: 1,169
i can. but i am surprised it does not say "do not drink this."
doug s.
Old 02-24-2013, 07:08 PM   #134
SUNTZU
SUNTZU's Avatar
Oddometer: 43
I agree.
I'm a believer, that all bores are not created equal. The measured gap, in the rings is there to allow the ring to compress as it slides up and down, along the bore surface which could have slight irregularites.
I never expect the rings to be perfectly gaped from the manufacturer.
SUNTZU is offline   Reply With Quote
Old 02-24-2013, 07:44 PM   #135
TinkerinWstuff
Take it apart
Oddometer: 1,116
doug s.
You're probably right.
But checking ring gap is as day one basic as checking plug gap. (No offense intended to the OP, I've made my share of mistakes and expensive educational experiences) So the guy who directed the "lame" comment toward Jeff is way out of line.
1999 Suzuki DR650
Times are GMT -7.   It's 01:02 PM.
