Old 02-05-2013, 02:31 PM   #1
maigashi OP
maigashi's Avatar
Oddometer: 117
Powerlet socket replacement
Does someone know if there is a standard cigarette light socket that can fit the same hole on the fake tank as the powerlet or will i have to open it up a little? Just want a USB charger on the frame and don't want to pay 50$ for every tiny accessory you want.
maigashi is offline   Reply With Quote
Old 02-05-2013, 03:32 PM   #2
sarathmenon
Oddometer: 937
You could hook a cigarette lighter up directly to the battery. This has the benefit that you are not restricted to 5A like the powerlet socket. On the downside, there is no protection from the battery getting fully drained.
sarathmenon is online now   Reply With Quote
Old 02-05-2013, 07:38 PM   #3
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,766
Wire up an SAE plug to your battery so you can put a charger on it... and it will connect to almost anything you can think of. You can get 12V adapters, heated gear, usb chargers, etc.
EnderTheX is offline   Reply With Quote
Old 02-06-2013, 08:32 AM   #4
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,485
yeap that's the way to go!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 02-06-2013, 10:33 AM   #5
maigashi OP
maigashi's Avatar
Oddometer: 117
Was hoping there was someway to make it master switch controlled so I don't accidentally run my battery down. But I guess I could just throw in a relay. I like simple things better
Old 02-06-2013, 11:31 AM   #6
Bayner
Oddometer: 1,557
There's a knockout on the opposite side of the key from the powerlet plug. Then it can be wired to the connected that sits just under the cover which is ignition controlled (basically).
Bayner is offline   Reply With Quote
Old 02-06-2013, 01:21 PM   #7
shashankmittal
shashankmittal's Avatar
Oddometer: 91
In addition to the options others have suggested, you could also get an adapter like this: http://www.powerlet.com/product/rigi...et-adapter/427
Currently - 2013 Ducati Multistrada GT (for sale), '09 Daytona (track only)
Previously - '13 F800GS, '13 MV F3, '10 S1000RR, '04 Royal Enfield 500, '97 Yamaha RX135, '90 Yamaha RD350...and many more.
shashankmittal is offline   Reply With Quote
Old 02-06-2013, 02:04 PM   #8
Mtl_Biker
Mtl_Biker's Avatar
Oddometer: 585
Bayner, you're sure of that?
I haven't received my own F800GS (2013) yet so can't check, but I've been told there is no knockout on this model. I asked about it because my K1300GT had an accessory outlet and TWO additional knockouts. I used one of them for a new accessory outlet wired to my fuse block and would love to do the same with the F800GS. Because I was told (I hope erroneously) there was no knockout, I thought I'd have to find a place to drill a new one. I sure hope you're right!
Mtl_Biker is offline   Reply With Quote
Old 02-06-2013, 05:11 PM   #9
Bayner
Oddometer: 1,557
No actually I'm not certain. Knockout maybe isn't the correct wording - more like clearly indicated location is should be installed in. I had to drill the hole through it however.
Old 02-06-2013, 07:29 PM   #10
HighTechCoonass
Oddometer: 2,485
Laugh 5 dollar USB
I hate the old cigarette plugs...big and bulky.... they are absolute shit... you always have to wiggle the POS to keep it working.
I bought 5 of these added 2 to my FJ Cruiser glove box...
http://www.ebay.com/itm/251195111986...84.m1497.l2649
But my Iphone 5 don't like it.... i put my USB charger in series...
This is the way to go....this is what I have on my GS. Never tried the Iphone on it...
Burnsmoto
http://burnsmoto.com/usb-power-socket-weatherproof.php
see this linky....
Originally Posted by HighTechCoonass View Post
Here I show how to add "auto off" lights to your GS.
Also the invaluable battery tender power whip (SAE type connection) - also use to power my volt meter and USB power supply - I like this because I can isolate the volt meter and USB if need be. I usually leave connected at all times...
http://www.opto22.com/site/pr_detail...=3&item=DC60S5
here you can see the volt meter LCD (for daylight visibility) and the USB scocket next to the light switch.
NAPA has these....
http://burnsmoto.com/usb-power-socket-weatherproof.php]
HighTechCoonass screwed with this post 02-06-2013 at 07:39 PM
Times are GMT -7.   It's 08:43 AM.
