02-06-2013, 10:55 AM
#1 | ||
Oddometer: 268
What's The Best Way To Break-In A New Engine ??
Has anyone try this method? What do you think about it? I have to break-in my bike and do not know if I should follow the manual or otherwise.
http://www.mototuneusa.com/break_in_secrets.htm What's The Best Way To Break-In A New Engine ?? The Short Answer: Run it Hard !
02-06-2013, 10:57 AM
#2 |
V-Stromer
205
02-06-2013, 11:11 AM
#3 |
Oddometer: 82
I did and overhaul on my cherished 82 GS850G last March and used MotoMan's recommendations in addition to the attached link.
http://www.calsci.com/motorcycleinfo...e.html#BreakIn I now have about 8k on the engine and everything is great, compressions are all in the 160+ range, the engine uses anywhere between 8 and 12 oz. of oil between changes and she is a strong runner. I use Rotella in this engine and change it every 2k. Good Luck
Speed doesn't kill, It's always the sudden stop that gets ya... ![]() 1982 Suzuki GS850G The "Zook" 2000 BMW R1100RT |
02-06-2013, 11:18 AM
#4 |
Oddometer: 218
I did this on my new BMW 1200 GSA. Left the dealership with 3 miles on the speedo. Hit the interstate and rode it 125 miles in forth and sometimes 5th gear. Ran the "piss" out of it. Bike now has about 35K on it. Runs like a top. Typical BMW oil usage when new was at a minimum. While I do change the oil & filter about every 3-4000 miles, I have not seen any oil usage since about break-in. Mechanic at dealership says it is one of the smoothest running boxers he has ever seen. And it runs like crazy.
'09 BMW 1200GS Adventure, '09 Vstar 950 '09 Honda Rebel, '77 CB750A, new garage (in planning) Need more room for more bikes. |
02-06-2013, 11:20 AM
#5 |
Gnarly Infantry
Oddometer: 872
ride it...
02-06-2013, 11:23 AM
#6 |
Oddometer: 218
I better add that my wife followed behind me on the interstate to help protect me from other drivers with the sudden decelerations. I would drop it down in speed and then get back hard on the the throttle. Back and forth and back and forth. I will admit that sometimes I hit 100 MPH and one time 105. But I mostly kept it down around normal highway speed limits which is 65. Slow downs were dropped to about 40, depending on how much traffic was near me.
Don't do this without someone following you who is aware of the process and who will keep a watchful eye on you and the traffic around you.
02-06-2013, 11:36 AM
#7 |
Oddometer: 268
02-06-2013, 11:44 AM
#8 | |
Oddometer: 268
02-06-2013, 11:53 AM
#9 | |
Oddometer: 268
02-06-2013, 01:03 PM
#10 |
Oddometer: 82
You gotta nice ride there, Enjoy
02-06-2013, 11:13 PM
#11 |
Oddometer: 267
FWIW,,, I support several race cars, one with a Cosworth twin cam.. Turns about 10,500 at full song on track..
We used to do the 15 minutes of idle then a half hour at about 1/2 throttle etc.. We had a race and ended up with a cracked piston.. We had to replace the pistons and rings and hone it.. But had a race that day, no time for break in.. We ran 125 laps that weekend and the engine NEVER had made that good of compression and leakdown before.. And the thing ran sweet all season and not near as much methanol in the oil.. Drive em like ya stole them... ! Porsche used to do a 60 minute 6500 rpm dyno run before installing a engine in their cars.. (Good old days...) Mercedes did a test back when the 190's came out (I was told this by a factory rep) that they pulled 100 engines off the line. Ran them all over 9000 rpm on the dyno.. then installed them in cars that were going to commercial fleet customers.. They thought it was going to show up as shortened life, turned out a high percentage went more miles than normal wihtout any bottom end problems.. (Of course the 190 motor was one of MB's high points, despite the cars electrical issues.. :) ) Good stuff.. Dave |
02-06-2013, 11:50 PM
#12 |
Andrew to most
Oddometer: 1,111
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost |
02-07-2013, 03:30 AM
#13 |
Team slo ass
Oddometer: 1,665
Seems to be waffling about rings alot, but the bearings and gears are'nt mentioned. These are important load bearing surfaces that marry up to each other over time , breakin time helps this .I rekon follow your manual, and use the recommended oil.
Give it WOT. |
02-07-2013, 06:27 AM
#14 |
Oddometer: 310
For what it's worth (and granted - you'll get no fewer than 1000 opinions on the subject), for me, break-in is all about avoiding a constant engine rpm and load. Vary your throttle input and keep moving through the gears. Mix up highway versus city and ride the shit out of it. KTM does a hell of job building these engines - the LC8 is a well developed and refined engine. It just simply works...
By the way, for servicing, if you're planning to take it to GP Bikes (noticed that's where you bought it), ask for their lead KTM tech Peter. He's fantastic and meticulous.
Alon Toronto, Canada 2012 KTM 990 Adv-R: the last new 990R in Canada. If Darth Vader rode an adventure bike, this would be it. |
02-07-2013, 06:29 AM
#15 |
Oddometer: 310
Oh...and if you decide that you need more engine/throttle smoothness and power, Z1 Cycletech is an outstanding tuner with his own Dyno. He's in Thornhill on Green Lane...
