Old 02-07-2013, 06:47 AM   #16
kirb
should be out riding
kirb's Avatar
Oddometer: 1,325
Can we merge this into a Break-in, oil, and tire thread?
'13 Moto Guzzi Stelvio NTX, '07 Moto Guzzi Griso, '08 KTM adventure, '00 EH Super X, '48 Indian Chief (in resto)
kirb is online now   Reply With Quote
Old 02-07-2013, 06:58 AM   #17
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 495
Send a message via Skype™ to RedRupert
Please, can you help re my high oil consumption?
Thank you Northyork, the info is interesting.
I wonder if you can help diagnose my high(?) oil consumption.
My bike is a 2004 950 with 90,000 km (about 56,000 miles).
During it's early life, oil consumption was acceptable - I mean, it needed topping up with <1 litre between 6-7000 km oil changes. So about 2 litres per 14,000 km (8700 mile) season. (0.14 litres/1000 km).
Over time the oil consumption became worse: 4 litres over 12,000 km, so 1 litre/3000 km (0.34 litres/1000 km).
At 74,000 km, I had to strip the engine in order to replace the selector drum. While the engine was apart I replaced the (serviceable) piston rings and honed the bores lightly. After honing the ring end-gaps were all around <0.30 mm (limit 0.5 mm). I did not have the correct tools to measure the bore and piston accurately.
I also changed the oil seal in the ignition casing (the balancer shaft oil seal).
I ran-in on semi-synthetic oil for over 1500 km on twisty roads not being too gentle - using plenty of acceleration and engine breaking - but oil consumption remains hight.
16,000 km after the rebuild, I measured compression and found 16.5 BAR (240 PSI). And carried out a leak-down test and found around 30% leakage, front and rear.
KTM state:
0.3 - 0.6 litres/1000 km: normal.
>1.0 litres/1000 km: there MUST be a serious technical defect!
My bike is ridden hard, but 0.34 litres/1000 km does seem a bit steep! Is it, despite what KTM say?
Looking at the leak-down and compression test results, could it be that the bore/piston/rings are at fault, or should I be look for another reason for the oil loss?
Any info will be gratefully received.
Thank you.
KTM 950 Adventure (2004)
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 02-07-2013, 05:09 PM   #18
Northyork OP
Oddometer: 268
Originally Posted by alongat View Post
For what it's worth (and granted - you'll get no fewer than 1000 opinions on the subject), for me, break-in is all about avoiding a constant engine rpm and load. Vary your throttle input and keep moving through the gears. Mix up highway versus city and ride the shit out of it. KTM does a hell of job building these engines - the LC8 is a well developed and refined engine. It just simply works...
By the way, for servicing, if you're planning to take it to GP Bikes (noticed that's where you bought it), ask for their lead KTM tech Peter. He's fantastic and meticulous.
Yeap, GP is where I bought it. Thanks for the tip.
Northyork is offline   Reply With Quote
Old 02-07-2013, 05:11 PM   #19
Northyork OP
Oddometer: 268
KTM state:
Thank you.
Sorry Rupert, I do not know enough about engines or this bike in particular to help you out
Old 02-07-2013, 07:20 PM   #20
TheNaker
El Vagabondo
TheNaker's Avatar
Oddometer: 90
[QUOTE=Northyork;20663819]Can't wait to ride it, I am just waiting for the streets to be clear of snow and salt. It was delivered around 3 weeks
ago. The odometer still reads 0KM.
Nice Bike! Congrats. I'm waiting to pick up my new Blue 2012 from the boys at Apex Cycle in Kitchener. Should be in a week or two. I'm in the same boat trying to decide on break-in.
Sean
2012 KTM 990 Adventure
TheNaker is offline   Reply With Quote
Old 02-07-2013, 07:49 PM   #21
DirtJack
DirtJack's Avatar
Oddometer: 334
After seeing the YouTube videos of KTM engine assembly and chassis assembly with dyno runs after each of those steps, I'm thinking the rings are likely already seated when you get a new bike. Change the oil and ride it.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 02-07-2013, 09:20 PM   #22
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 164
Wait: There's oil in the engine?
HeatXfer is online now   Reply With Quote
Old 02-07-2013, 09:34 PM   #23
Katoom72
Katoom72's Avatar
Oddometer: 388
'What's The Best Way To Break-In A New Engine ??'
Ride it like u stole it. Just heat it up first.
Katoom72 is online now   Reply With Quote
Old 02-08-2013, 04:41 AM   #24
Northyork OP
Oddometer: 268
Findings after oil change
A bit of background on the bike
Bike is new, odometer reads 0.7Km
Engine was most likely run at the dealer during PDI
The day I received the bike it was -14C, still I could not resist and rode the bike to the corner and back.
Engine has not been run since
Yesterday I changed the oil in order to follow mototune and others break-in advice (Castrol Grand Prix 4 stroke 10W40)
In the picture that follows you can see a load of metal shavings that had settled to the bottom of the oil drain pan (oil drain pan was cleaned with water and soap before starting the oil change)
This proves to me that waiting 1000Km to do the first oil change is nuts.
I will be doing another oil change before the bikes hits 75Km
Northyork screwed with this post 02-08-2013 at 08:40 AM
Times are GMT -7.   It's 07:54 PM.
