Old 02-07-2013, 10:44 PM   #16
max2
max2's Avatar
Oddometer: 218
For the graphics...Windex or soapy water, both work fine. Use a credit card or bondo scraper to work air bubbles and liquid out. Work from inside to outside, be careful not to scrape or scratch the graphics. If there are some curves or bends, slightly warm up the graphics with a heat gun or hair dryer and work the graphics into the correct form. Let everything dry overnight before you go ripping done the freeway.
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 screwed with this post 02-08-2013 at 07:54 AM
max2 is offline   Reply With Quote
Old 02-08-2013, 04:48 AM   #17
charlie264
charlie264's Avatar
Oddometer: 8,273
Nice Brents, welcome to the SE club. Good to hear ya lifes kinda getting back to normal-ish. Im shite at graphics also; only thing I can add is clean the area with alcohol to remove any grease.
Old 02-08-2013, 01:02 PM   #18
Dan950ser
NW Shredder
Oddometer: 418
Just curious how much better the 320 is than stock and what you used to do it. Thanks and great looking SE.
2007 KTM 990 SuperDuperEnduroR
2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 02-08-2013, 04:26 PM   #19
Grinderman
Grinderman's Avatar
Oddometer: 146
Brent. Pm me when you can. Let's get this show going. I have ideas also. Be interested to see yours and look at the trip timing. By the way I also have a cabin reserved in steamboat
Grinderman is offline   Reply With Quote
Old 02-08-2013, 07:52 PM   #20
brents347 OP
Trusting my Cape...
brents347's Avatar
Oddometer: 3,740
All the details for how I did it are in the tail end of this thread.
http://advrider.com/forums/showthread.php?t=774162
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 02-08-2013, 07:58 PM   #21
brents347 OP
Trusting my Cape...
brents347's Avatar
Oddometer: 3,740
Grinderman, I'll drop you a note. Are you confirmed in for this Ryan?
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 02-08-2013, 09:58 PM   #22
Chico Ryan
noslo1
Chico Ryan's Avatar
Oddometer: 10
Im in for the trip
Chico Ryan is offline   Reply With Quote
Old 02-09-2013, 08:22 AM   #23
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
Hello all,
So what is the secret? A slight soap and water pre-spray? Do the graphics still stick well after that? Any suggestions welcome.
Brent
Brent-
Hardline Products makes a Sticker On & Sticker Off spray that makes EASY work of applying graphics. Ofcourse, there are probably a hundered home brew versions to make your own spray, but I like using this spray because its easy; pre-mixed in the right proportions. There's no hassle of getting the home brew mixture just right which makes a difference with adhesion. Remove old graphics- clean residue on plastics with Sticker Off, wipe clean, clean your hands, spray Sticker On and apply graphics, move into place as you like, squeegee the spray out- let set for a couple of hours- (overnight is best) go ride!
Good luck
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-08-2013, 06:08 PM   #24
brents347 OP
Trusting my Cape...
brents347's Avatar
Oddometer: 3,740
Well, the transformation is finally done. I got my SM wheels mounted with tires and rotors and got them on the bike today. Just had to do a little customizing to one of the spacers and everything went together really well.
[IMG][/IMG]
When I did this to my last 2 adventures, the steering geometery was a little weird and the forks had to be raised in the triples clamps quite a bit to make it feel right but this SE rides just perfectly as is with the 17's on it. I am very happy!
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 03-08-2013, 06:18 PM   #25
Nytro
Nytro's Avatar
Oddometer: 108
Looks good. Interested to hear how the 320 performs.
Nytro is offline   Reply With Quote
Old 03-08-2013, 10:20 PM   #26
brents347 OP
Trusting my Cape...
brents347's Avatar
Oddometer: 3,740
The tank bag DOES interfere with the tank vent on the safari tank. I haven'y worked out a solution for that yet, Good spotting though!
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 03-15-2013, 10:23 AM   #27
midfat
wholesome dirtiness
midfat's Avatar
Location: Socal, between the mountains, desert and ocean
Oddometer: 205
Brent, I also have the Safari and and tank bag. Solution for me was a 29 cent part from the hardware store. Just go get a little 90* plastic elbow, cut the vent host about 1" above the tank cap, insert elbow. Problem solved. I just pull the hose off the cap when I fuel up. Been like that for two years now and it's been flawless.
midfat is offline   Reply With Quote
Old 03-15-2013, 12:09 PM   #28
Balsta
Oddometer: 400
Well, the transformation is finally done. I got my SM wheels mounted with tires and rotors and got them on the bike today. Just had to do a little customizing to one of the spacers and everything went together really well. When I did this to my last 2 adventures, the steering geometery was a little weird and the forks had to be raised in the triples clamps quite a bit to make it feel right but this SE rides just perfectly as is with the 17's on it. I am very happy!
I am still however suspicious about too low front with 17/17. Would it make sense and is it possible to replace the rear spring by one that is 1" shorter?
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 03-15-2013, 11:14 PM   #29
midfat
wholesome dirtiness
midfat's Avatar
Oddometer: 205
Here's the mod to retrofit the tank vent for a tank bag. (Apologies for very dirty bike. I try to keep my 950 clean, but it tries harder to keep me dirty.)
Old 03-16-2013, 12:19 AM   #30
mousitsas
mousitsas's Avatar
Oddometer: 2,752
For street only use you can replace the rear shock with one from 990SD (not R). It fits like a glove and drops the rear almost by an inch. It actually works offroad too, if it is smooth enough. Another option is a shock from 950/990 SM but in this case the rear drops more.
Times are GMT -7.   It's 07:54 PM.
