02-09-2013, 12:26 AM
#16 | |
dry weather rider
It thought it was a chicken. Feathers got caught in the chain. Never again.
02-09-2013, 12:30 AM
#17 |
will think for food
Oddometer: 4,554
02-09-2013, 12:46 AM
#18 | |
CRASHING BORE
Oddometer: 2,673
Forget it mate ...already been done...Italian Army tanks ..WW2..
.. I fixt it...my way....gjr |
02-09-2013, 12:52 AM
#19 |
Slow and Steady
Oddometer: 1,820
trying to be helpful
found this on the www
DIY Magnetic Oil Drain Plug Yeah, before you start to flame all over the place let me first make clear that this is quite possibly the easiest little project to complete. I'd also like to say that you can probably buy a Magnetic Plug on eBay or something for $5. I made my own because I am cheap, I like using power tools, and I like making things myself instead of paying for them. So, you'll need: - A regular Honda oil drain plug - A Neodymium magnet (strong as ****) - Drill press (or a hand drill if you're feeling frisky) - Some kind of adhesive (ex. JB weld) - Vice/C-Clamp - Drill bits - Micrometer (or just a ruler) So, you have your drain plug. You'll first want to clean it up real good. Next, you'll want to punch a mark right in the middle for your drill bit to center itself in. VVV ![]() Next, grab your magnets. The ones I used are somewhat small. They came in a pack of 10 for about $5. VVV ![]() I used a micrometer to measure the diameter of the magnet, you can use a ruler if you like. These magnets came out to .3155". VVV ![]() Next, find a drill bit that is about the same size or slightly smaller. I found a 5/16" bit that was about .0045" smaller than the magnet. I figured this size difference wouldn't matter once the drill press started vibrating anyways. VVV ![]() Next, set up your drill press (or hand drill) with your 5/16" bit. You'll want to really clamp it solid so you can get your hole as close to the middle as possible. VVV ![]() PUT ON SOME EYE PROTECTION! Drill away! You'll want your hole to be roughly the thickness of the magnet. This part isn't crucial, you can have your magnet sticking out of the plug slightly, or even sunken in a bit. I figure it's best to have it flush, or sticking out a bit. If the occasion ever arises for you to clear the metal debris off of the magnet, you'll want to be able to do it easily. VVV ![]() Blow off all of the metal shavings from your newly drilled hole. Before I continue, these magnets are probably strong enough to hold themselves in the bolt, however it's never a bad thing to be too careful. IF YOU WANT TO USE ADHESIVE, DO NOT TEST FIT YOUR MAGNET IN THE HOLE! YOU'LL NEVER GET IT OUT! Next, grab your adhesive of choice. I used a marine-grade adhesive that is very resistant to heat, moisture, and frigid temperatures. You can use JB Weld, or a similiar product. VVV ![]() Mix some up! Equal parts of both. VVV ![]() Cram some in your hole. Too much is not a bad thing, the excess will come out when you press the magnet in. VVV ![]() It's time to place the magnet in the hole. My hole turned out to be a bit too small for the magnet to slip in under it's own power, so I used a small vice to squeeze it in. If you don't have a vice, you can use a C-Clamp.VVV ![]() DONE! Not too bad for 10 minutes. VVV ![]() STRONG AS BULL! VVV
02-09-2013, 01:09 AM
#20 |
broooommmm brooommm
Oddometer: 2,767
---------------------------------------------- iam just not ready to be an adult |
02-09-2013, 01:12 AM
#21 |
Road Hog
Oddometer: 2,934
I never seen any mention of filling in a JSEA or doing a start card let alone a permit to work before starting this task. No gloves either. |
02-09-2013, 01:14 AM
#22 |
broooommmm brooommm
Oddometer: 2,767
thats why it only took 20 mins and not 2 days
02-09-2013, 01:16 AM
#23 |
Road Hog
Oddometer: 2,934
02-09-2013, 01:20 AM
#24 |
Kicker Brother
Oddometer: 3,120
Earth magnets ....$6.00
Drill bit ....$18.55 Drill press ....$143.00 JB Weld ....$12.95 Price of an Xrr Bottom End when JB weld Fails .....Priceless |
02-09-2013, 01:23 AM
#25 |
Road Hog
Oddometer: 2,934
02-09-2013, 01:25 AM
#26 | |
110 POWER
Oddometer: 1,691
noted
Take the green pill or the red pill- the choice is yours;This is your last chance. After this, there is no turning back. You take the blue pill - the story ends, you wake up in your bed and believe whatever you want to believe. You take the red pill - you stay in Wonderland and I show you how deep the rabbit-hole goes. |
02-09-2013, 01:27 AM
#27 |
Kicker Brother
Oddometer: 3,120
nobody calls em splif's no more .... there doobie's
02-09-2013, 01:46 AM
#28 | |
broooommmm brooommm
Oddometer: 2,767
but apart from that, geez your a pesimistic bastard
02-09-2013, 10:56 PM
#29 |
Oddometer: 315
02-10-2013, 02:01 AM
#30 | |
Oddometer: 458
02 R1150GS Adv,Moto Guzzi MK5 Le Mans Moto Guzzi Mk3 Le Mans,Moto Guzzi Sp3 1000 Moto Guzzi v65TT,Moto Guzzi NTX650 Ducati 907ie.83 TT600 KTM 640 Adventure Etz 250 Guzzi Quota 1000 |
