Old 02-08-2013, 09:41 AM   #1
bmwhacker OP
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,384
Anyone using a Odyssey PC925L Battery?
I've been using an Odyssey PC 680 Battery for 4 years and it's apparantly getting "tired". Would like to go with a larger battery. The PC680 is the smaller battery. I'm cranking a R100S motor and running a couple accessories.
My bike has the large battery box (1974 R90/6 Frame) so the larger PC925L Battery should fit. The "L" designation apparently is for a reversed pole arrangement. I take that this means that the battery can be laid over to fit in the BMW battery mounting frame, with the terminals towards the front. The PC925 is heavy...25 lbs. Looks to me like it will be a very tight fit getting it in there. Anyone around here installed this battery with the "reversed" arrangement?
Can a guy "shoe horn" it in there without disassembling the bike?
http://jupiterhack.blogspot.com
Living proof you shouldn't play with matches
Old 02-08-2013, 09:46 AM   #2
batoutoflahonda
Oddometer: 1,246
How did it crank when the battery was new? If it was fine I wouldn't bother with a bigger bat. Other things to look at are worn starter. Throwing more cranking power at it might be masking another issue.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 02-08-2013, 10:06 AM   #3
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 2,946
got to get it on the good foot
camgregus is offline   Reply With Quote
Old 02-08-2013, 10:07 AM   #4
bmwhacker OP
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,384
I thought maybe I had a starter issue to begin with. I removed the starter and took it down to the bare bones. Lubed all bushings, cleaned and carefully dressed up the commutator surfaces. The brushes looked good.
I cleaned all connections involved with the starting circuit. I'm fairly certain that the starter / charging circuits are OK.
The battery just doesn't seem to want to hold a 100% charge.
bmwhacker screwed with this post 02-08-2013 at 10:14 AM
Old 02-08-2013, 11:34 AM   #5
_cy_
Oddometer: 2,543
to test battery ...
1. charge at least overnight with preferably a std size automotive battery charger. some batt tenders charge so slow, it may take several days.
2. allow fully charged battery to rest overnight to bleed off surface charge
3. use a known to be correct meter ... 12.85v shows a fully charged flooded PB at rest, 13v for AGM
4. next is a load test.. no problems if you don't have a load tester... your starter will draw about 150amp, then drop to about 95 amps. if your battery cranks strong with a verified full charge, then it passes the load test.
5. your charging system should put out at mid-rpm range.. 13.8v to 14.2v measured at battery. intermittent charging issues are the worst...
6. test for parasitic drain... set meter to measure amp in series ... connect meter in series to neg side between battery and ground. depending on what's running with everything shut down, a tiny drain may be ok... like a clock
_cy_ screwed with this post 02-10-2013 at 10:52 AM
Old 02-08-2013, 01:27 PM   #6
supershaft
because I can
Oddometer: 6,082
There are guru websites that say your airhead should be charging at least 14 volts. I have tested a lot of airhead charging systems and I have never seen a stock setup charge over 13.9 volts at the battery. They will charge over 14 with the police regulator but . . . . Over 14 will cook wet cells dry. F650's charge around 14.2 volts like some say airheads should charge and they very often have a bone dry battery in 6000 miles. 13.7 to 13.9 is real good for our airheads.
Static battery voltage is almost useless info. How much does it drop with a load on it? Dropping below around 10 volts is suspect and below 9 or 8 is no good. If you are using a load tester, it all depends on the tester and how much it loads the battery. Use the smaller 'motorcycle' testers. Don't test them too much! It's a super drain on even a good battery.
Surface charge? You don't want to over heat a battery charging it or draining it. Other than that you don't need to wait. I let wet cells self charge for an hour or two after filling them. They will over heat if you charge them right after putting the acid in.
supershaft screwed with this post 02-08-2013 at 01:32 PM
Old 02-08-2013, 02:00 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,872
Before you discount the Odissey, do you have a proper three stages charger for it? I had to leave mine on float for quite a few days to get it back to 13.1x Volts and Odissey does have specs for the minimal float Voltage. Some of that is in the Owner's manual but more in the technical manual online on their site.
Mine is on a K-bike with better charging, 14.3 not a problem but still was only getting 12.8-12.9 out of it after long rides and time to remove the surface charges. Long float brought it back up and still there 2-3 weeks later, just checked it today.
But our "sort of local" Odissey dealer would also do a health check and proper charging. I may have paid a little more than online but should include some service. Was worth it anyway if just to talk to the knowledgeable sales guy and get some info I wanted.
Have tools, will travel!
H96669 is online now   Reply With Quote
Old 02-09-2013, 10:47 AM   #8
Rucksta
Chronic Noob
Rucksta's Avatar
Oddometer: 2,293
I had a 680 that did 4 years service then sat on the bench 4 years waitinng for the 320 replacement to get tired.
Hard starting due to lack of choke and no accelerator pumps then running at low speed with the lights on is what killed the 320.
The 680 stepped up and has done another years work with no sign of reduced capacity from the 4 year hiatus.
The Odyssey AGM is not a deep cycle house battery; it is optimsed as a starting battey and needs to be kept at a float level higher than a lead acid battery.
A normal charger will do to get by for a flat battery event.
For continued maintance a 3 stage floar charger is required or better again ride the bike at least once a month.
Maybe you have a charging or a starting problem rather than a battery problem.
If the Earth is flat why are my tyres round?
Rucksta is offline   Reply With Quote
Old 02-09-2013, 12:39 PM   #9
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 600
I've used a PC-925L in both an 83 RT and a 93 GS, and it's a fine battery.
If you rule out a parasitic drain or bad charging issue as mentioned above and still want a larger capacity battery, the 925L is great (if you're not weight conscious).
In both bikes I've used one, I did have the motoelekt.com VR, which helps keep it charged.
Current: 93 R100GS, 04 XR650L
Prior: 73 CB350, 77 R100/7, 83 R100RT
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 02-09-2013, 12:49 PM   #10
Les_Garten
Les_Garten's Avatar
Oddometer: 683
I've got a PC-925L in my '92 RT. Fits fine. Gotta fiddle a little with the connectors.
When it's not in the RT, It sometimes moonlights in a Porsche 930.
Les_Garten is online now   Reply With Quote
Old 02-09-2013, 02:34 PM   #11
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
If you don't do this, you cut battery life by a huge amount--it doesn't matter how much care you take from this point forward.
If your gonna be dumb, you gotta be tough
When you get knocked down you gotta get back up,
I ain't the sharpest knife in the drawer but I know enough, to know,
chollo9 is offline   Reply With Quote
Old 02-09-2013, 07:50 PM   #12
apt13
Oddometer: 391
been using this battery in my 78 r80/7 for multiple years. no problems whatsoever. but it is a pain to remove/install. it's too big to just pop in through the top. I have to take apart the airbox and jimmy it in through that area.
'78 R80/7
'74 CB360
Airhead Tshirts!
apt13 is offline   Reply With Quote
Old 02-09-2013, 09:02 PM   #13
bmwhacker OP
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,384
I thought that might be the case.
Looking at the given dimensions I thought it might be a pain to get it in there,
Old 02-09-2013, 09:09 PM   #14
Les_Garten
Les_Garten's Avatar
Oddometer: 683
Mine dropped in from the top on my '92 RT, snug but it goes in.
Old 02-10-2013, 04:57 AM   #15
AntonLargiader
AntonLargiader's Avatar
Oddometer: 3,462
Too heavy. If your bike won''t start with a PC680, it might not start with the 925 either. Better strap a second one on the rear rack. Maybe a third one somewhere else, if you can find space.
AntonLargiader is online now   Reply With Quote
Times are GMT -7.   It's 09:09 AM.
