Old 02-08-2013, 06:42 PM   #1
honkytonking OP
Oddometer: 8
R100/7 cleaning up the wireing
So dont know excately how to go about this but reading a bit here and there i have been getting a bit more concerned about this rebuild lets here the experts and what have yous tell me whats up. I want to eliminate every piece of wireing and relays possible plan on only running rear lights headlight turn singles in the rear only. Im concerned about the charging system and its relay being needed to feed back to the gen any help would be great. i gotta put some pic on here soon im in the process of tearing down the motor for a complete rebuild powder coating the motor can any one say murder that bitch out !!!!!
honkytonking is offline   Reply With Quote
Old 02-08-2013, 06:50 PM   #2
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,529
Do not compute....are you saying you want to remove all of the wiring except rear lights and headlights because you are worried about the charging system???? If that is a correct statement....my friend you've got bigger fish to fry......... 280 w is PLENTY of power for all lights and a little extra....the starter aint no power sippin' slouch neither. 'memeber when you told your mama...."mama, it hurts when I poke my eye" memeber what she said..."well, get yer damn finger out your eye."
Seriously, don't remove wiring to solve a problem that doesn't exist. if you're doing it for simplicity sake, it isn't simple. Fix the charging problem if you have one, and leave the harness alone. Oh, we don't have a generator....well not really, we have an alternator which produces AC current.
hardwaregrrl is online now   Reply With Quote
Old 02-08-2013, 08:28 PM   #3
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I am with hardwaregrrl on this.
BUT, I have assisted a few people that have done major cafe jobs on their bikes, and a part of the process was a total re-wire job. Basically we blew up the stock wiring diagram to poster size and stuck it to the wall of the garage. Then traced thru what we needed and eliminated what was not needed. We did not use stock gauges nor charging system. Everything was custom. Ended up with about 1/2 the wires and still kept the same amount of lights and stuff running. Even added a few extras like heated grips. A good part of the wires eliminated were extra grounds.
DaveBall is offline   Reply With Quote
Old 02-09-2013, 05:17 AM   #4
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,602
Originally Posted by hardwaregrrl View Post
"mama, it hurts when I poke my eye" member what she said..."well, get yer damn finger out your eye."
1. If'n you want to ask fer advice, a little clearer language would help--you know, punctuation and such.
2. Recently been there and done this--it's simpler in the end, but quite complicated in the process, be prepared for a lot of work. And I recommend a complete plan up front, before ANY work.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 02-10-2013, 04:30 PM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,577
These may or may not be useful to you if you're redoing your looms...
ElektraLink Sealed Solder Butt Splices are an excellent choice for professional electricians that require high quality electrical connections. These butt splices provide that much needed connection. Each splice has just the right amount of solder to create a secure connection and an adhesive lined heat shrink tubing to seal it and provide protection against the elements.
I've used them recently to repair the loom from the instruments. Worked a treat and very tidy result. They're a little expensive for what they are but the job done appears very good.
boxerboy81 is offline   Reply With Quote
Old 02-10-2013, 09:12 PM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,719
"ElektraLink Sealed Solder Butt Splices are an excellent choice for professional electricians that require high quality electrical connections. These butt splices provide that much needed connection. Each splice has just the right amount of solder to create a secure connection and an adhesive lined heat shrink tubing to seal it and provide protection against the elements. "
If there is solder on the inside and heat shrink wrapping on the outside how do you melt the solder and not burn off the heat shrink? A heat gun for the heat shrink is not going to melt the solder.
---Albert Einstein
disston is online now   Reply With Quote
Old 02-11-2013, 05:55 PM   #7
Kai Ju
Kai Ju's Avatar
Oddometer: 1,891
The solder melts at a much lower temperature than conventional solder.
If they weren't so expensive I'd use them. Until they get cheaper I'll stick with heatshrink tubing.
Kai Ju is offline   Reply With Quote
Old 02-11-2013, 07:38 PM   #8
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,577
The idiot lights on my 11/1981 R100RS haven't worked correctly for ages. The OIL & GEN lights have always worked thankfully, but lately they've become temperamental and very sensitive to the position of the plug. Time for action.
I planned to substitute the instrument plug and 8inches of wiring for one in better condition. I believed the wiring was the culprit, not the plug.
Assembled the stuff required.
1. Connectors with solder within them.
2. Scissors
3. Crimper/wire stripper.
4. Heat shrink tubing.
5. Stiff outer protective sheath.
6. New (used) plug and wiring.
Opened up the old cover, exposing the old wiring.
Cut the old wiring. The point of no return. Committed.
With a small degree of staggering, I connected the 10 wires via these butt connectors that have solder internally. The finishing heat shrink was over the loom ready to move into position and the connectors were placed onto one wire before they were connected, to be slid over the connection when ready.
The wire width on the new bits were a smaller gauge than the original loom. The wires were stripped and the ends carefully interlocked before the connector was moved into position. Note the different sizes of the wiring.
When all 10 were done, the heat gun was used to melt the solder...despite this next picture, the wires were held horizontal for that exercise to enable an even spread of the solder melt.
The new outer heat shrink was moved into place...
...then I tested the lights before the final shrink.
They all worked...
Now I'll be able to see the instruments at night.
This was quick and easy. Eventually I'll replace the whole loom, so this repair doesn't need to last forever
Old 02-15-2013, 05:13 PM   #9
honkytonking OP
Oddometer: 8
ok so daveball thats the direction i wanted to go. I love how the topic of conversation goes stray in fourms but regardless i like the idea to blow up the wireing diagram. cause its a bear to read in the book. Well any way a litttle more info about the bike the stock gauges have to go i dont need the netural light nor the oil light nor a any of the shit on that looks like ....... well ya know not what im going for. I understand that i might be getting a bit over my head but i dont ever give up on what i want. Daveball you say you used a different charging system i currently do not have any isue with it now why did you switch over. not doing heated grips btw
Old 02-15-2013, 07:22 PM   #10
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I changed charging system as diode board was shot and I wanted to be able to run more powerful lights. I run a headlight with an upgraded H4 bulb that is 80/100 watt made by Phillips. Don't know if they are still available. And add to that a set of 100 watt Bosch driving lights. That kind of maxed out the stock system real fast. So put in the Enduralast system. Works perfectly.
I took a really good high resolution scan of the wiring diagram to a friend that has a big plotter. He blew it up and sharpened it a lot. Then printed it out at a bit larger than poster size. It really made things a lot easier to figure out what we really really needed, vs what was superfluous. As we created our wiring, and laid it up on the bike, routing to different spots, we used a lot of twist ties to hold things together in mock up. Once completed, we shrink tubed most of it, and taped up a few small spots that needed tighter bends. We soldered every connector and joint to ensure good contact.
Over all, I think we saved a lot of wire and eliminated a lot of possible connector issues. That bike has done about 30,000 miles since and so far, no issues.
Old 02-15-2013, 09:55 PM   #11
honkytonking OP
Oddometer: 8
A
Awesome I'm going to do the blow up map thing most def solder and heat wrap only way to go
Times are GMT -7.   It's 10:46 AM.
