Old 02-12-2013, 02:04 PM   #31
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,529
Originally Posted by chasbmw View Post
these are pictures of Bluethumb's stand, it looks like a 81 on stand. lots of wear on the part that fits onto the frame and the hole looks if it might be a little oval
Charles,
The early 80's stands I have have had have a pressed steel drop down lever instead of the bar on yours. I thought the bar appeared later. Is yours definitely an early 80's?
Rob Farmer is online now   Reply With Quote
Old 02-12-2013, 02:13 PM   #32
chasbmw
Oddometer: 2,119
The stand in the photos is blue thumbs......
Charles
1971 Commando Fastback
chasbmw is online now   Reply With Quote
Old 02-12-2013, 02:52 PM   #33
chasbmw
Oddometer: 2,119
A cut and paste from airheads list
I'd run dual-crossover systems on all of my bikes, if the centerstand
location did not make that so difficult. You can see from BMW's
struggle with the 1981-84 centerstands that even a team of brilliant
BMW engineers were somewhat stymied by the problem of raising a 500-lb
motorcycle with half the lever length that they had before. I've
probably doodled a hundred ideas for fixing that issue, including
hydraulic and pneumatic methods. None were viable market-wise.
The electric centerstand system fitted to the bottom of a K1200LT
weighs about the same as an R65.
Tom Cutter
Yardley, PA
"Depend on the rabbit's foot if you will, but remember it didn't work
for the rabbit." -?R. E. Shay
Charles
Old 02-12-2013, 05:49 PM   #34
coppertop
occasional meanderthal
Oddometer: 245
And here I thought it was just me...
'82 R100S. Always been a bit of a bastard to get onto the centerstand. It has the stamped steel deployment tang, and the textured, sort-of-square, steel foot placement pad. The stock sidestand became worn enough to be a concern, so I replaced that with a Brown's side stand. I pretty much only use the centerstand when I'm doing maintenance on the bike.
coppertop is offline   Reply With Quote
Old 02-12-2013, 10:24 PM   #35
Bluethumb OP
Oddometer: 126
Originally Posted by Rob Farmer View Post
Charles,
As far as I know that is the stock stand, but that's why I asked Charles to post those pictures for me. The R100 is new to me but everything appears original.
Bluethumb is offline   Reply With Quote
Old 02-13-2013, 01:02 AM   #36
chasbmw
Oddometer: 2,119
I think that the earlier stands have 2 crosspieces, I don't know about post 84 stands.
Charles
Old 02-13-2013, 06:36 AM   #37
kadesean
eyesuck
kadesean's Avatar
Oddometer: 981
blue,
If you don't already know Mikey, http://martindalemotorcycleworks.com/A55A76/home.nsf, he's a good guy to know for parts and service. Close to the TX Hill Country near San Marcos.
Good Riding
steve-0
kadesean is online now   Reply With Quote
Old 02-13-2013, 12:11 PM   #38
ME 109
ME 109's Avatar
Oddometer: 2,572
Single cross piece on my 81 centre stand.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 02-13-2013, 12:48 PM   #39
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,455
Same with my 83 R80 and it's a bastard to get on to the centrestand, I will look at rewelding the stops (mine are worn) but the bushings and pivots are in good order. It is a nasty design and the one thing I dislike about the bike.
Yet again, lots of good advice here, thanks to all of you!
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 02-13-2013, 12:50 PM   #40
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,529
Hi Blue,
Just trying to figure out what the 81 machines had as standard. I know my mates worked a treat with the original stand since it was fitted with a new replacement is now so awkward to pull on the stand he doesn't use it any more. Motobins list a different spring for the 81 machines so there must be difference, they don't have any stands though --> http://www.motobins.co.uk/displayfin...RTS&model=R100
I gave PYCymru a stand with the tang and the chequered foot and it cured his problems with getting his RS on it's stand.
I'd love to know what's supposed to go on each year.
Rob Farmer screwed with this post 02-13-2013 at 01:03 PM
Old 02-13-2013, 03:18 PM   #41
chasbmw
Oddometer: 2,119
My 75 has 2 cross pieces and is a delight to use. The stand on my 82 is a recent replacement (3 years ago) , it's ok on a bare bike and better than the original stand.
So did Bmw revise the design of the 81-84 stand. They did so with the side stand.
Charles
Old 02-13-2013, 10:43 PM   #42
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,529
My 78 100/7 has two crosspieces and as yours is very easy to use.
I've recently bought an 81 that has a stand with a single crosspiece, a checked plate on the left hand foot of the stand for pressing it down with and a folded steel tang for dropping the stand down. I have an 83 R80TIC with a single crosspiece, no chequered plate and a straight steel bar coming out of the side for dropping the stand, very similar to Blues stand in your photograph but without the bend in the side bar.
The 81 also has shorter springs than the later stand.
Be nice to get to the bottom of this. I suspect that many of the 81/early 82 machines are fitted with the wrong stands.
Old 02-14-2013, 12:20 AM   #43
ME 109
ME 109's Avatar
Oddometer: 2,572
Oh no! That puts my bike right on the epicentre
(September 81 build)
If the stand mounting bracket (welded to the frame) is the same, and in the same position on bikes of the surrounding year or so, it can only come down to how long the stand is? Which would come down to how high the front wheel comes off the ground when the bike is on the c/stand?
On a level surface, my front wheel is about 70mm off the ground.
Old 02-14-2013, 05:15 AM   #44
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,418
This centre stand fits my 11/1981 R100RS. Single crosspiece.
It's essentially identical to the one I have on the bike.
However, modifications have made them different, but it's minor.
This is the one I have on the bike. Notice the extra bits added to the ground contact area. The foot lowering tang is modified..beefier and more curved to the underside of the exhaust.
The spare is essentially unused, but I suspect it was removed from its original home when the tang snapped. The repair is a little rough.
Hey Jeff, would a little anti-rust paint control that corrosion?
boxerboy81 is offline   Reply With Quote
Old 08-26-2014, 08:49 PM   #45
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Bump.
Too bad the pictures linked above are no longer available.
I finally decided to deal with the centerstand on my '82 R100.
I did the welding job on the tops of the legs on mine.
I wonder about those bushings. Mine were installed with the flanged ends out. Some of the pictures I've seen also show them that way.
Seems like the wider surface on those ought to bear against the frame.
Anyone know for sure?
The bushings on my bike were worn, one way more than the other. It has a spiral groove in it from that side of the stand shifting outward as the stand is deployed.
Why are the bushings so much longer than they need to be?
I decided to make up some shims to put on the bushings to fill the extra space.
With the bike supported so the centerstand can be removed or manipulated easily, I measured the amount of bushing that protudes beyond the tops of the stand legs and made brass washers that are just shy of that thickness.
After installing them, I found that once the stand is deployed and the weight of the bike is applied, the top of the stand springs outward and applies so much pressure outward that the whole aasembly is stuck together to the point where the whole thing, bolts and all rotates with the stand. Once the stand is folded up, the wahers I made loosen up.
I had to cut them down to half the original thickness before they would renain free with the stand deployed.
This wasn't a problem if the bike was raised up on a stand so that no weight was place on the stand.
I've currently got my centerstand working the way it should, but I'm curious to know if anyone else has noticed this weird phenomenon?
caponerd is offline   Reply With Quote
Times are GMT -7.   It's 10:08 AM.
