| View Results: What is the horrible noise? | |||
| Cam chain tensioner |
2 | 5.13% |
| Camshaft rockers / bearings |
10 | 25.64% |
| Big end |
10 | 25.64% |
| Gearbox main shaft bearing |
3 | 7.69% |
| Crankshaft bearings |
8 | 20.51% |
| Other? |
6 | 15.38% |
| Voters: 39. You may not vote on this poll | |||
03-03-2013, 02:23 AM
#61 |
Nob.
Oddometer: 122
http://www.wossnerpistons.com/tech/piston-installation
I'm guessing by this I just go by my smallest average measurement? Bore gauges are at work so I'll get it done tomorrow
AR50,TS125X,DTR125,MTX125,KDX200,KL250,DR400S,DRZ4 00S,XJ400N,XR400R,CBR600F,DR650,XS650,GSX750F all helped me whittle myself down to a KTM640E perfect bike!
03-03-2013, 04:26 AM
#62 |
Red Clay Halo
Oddometer: 11,158
What kind of play? Axial? Radial?
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
03-03-2013, 04:46 AM
#63 |
Nob.
Oddometer: 122
Plenty of axial, not much radial. I'll make a video when I'm out of the bath
03-03-2013, 05:43 AM
#64 |
Nob.
Oddometer: 122
http://www.youtube.com/watch?v=Cf81Z...ature=youtu.be thoughts anyone?
moto_psycho screwed with this post 03-03-2013 at 06:18 AM |
03-03-2013, 06:19 AM
#65 | |
Red Clay Halo
Oddometer: 11,158
Radial: 0.05mm (0.0019") Axial: 1.00mm (0.04") My mark 1 eyeball says your axial play is within spec. EDIT Just went back and listened to your original video. What noise was it that was giving you worry? The loudest to me is a whirring from the left side. Mine makes a similar whirring when the motor is hot and the clutch is released. The noise goes away then the clutch is pulled.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... Boon Booni screwed with this post 03-03-2013 at 06:25 AM |
03-03-2013, 08:14 AM
#66 |
Nob.
Oddometer: 122
More the "donk donk donk donk donk donk" noise, far more harsh when warmed up, and loudest at the front left of the engine, not really noticable when completely cold. Clutch nut was tight, and no change to the noise when clutch pulled in. 1st picture shows loads of swarf on sump plug, there was plenty on the oil change before that as well. Haven't actually seen anything with that much wear on it yet...
sounded exactly the same as this video, http://www.youtube.com/watch?v=Cyq5_rYbeIo
03-03-2013, 09:34 AM
#67 |
Nob.
Oddometer: 122
Locked the crank and felt again, can't get any up/down play, even when just holding the piston. Now going to upload a video of play in the rockers etc... I honestly cannot find anything capable of making that racket!!! Piston slap perhaps?
03-03-2013, 09:35 AM
#68 | |
I.Hopp.
Oddometer: 3,075
Your piston and cylinder still look servicable going by the pictures... You can pull the piston rings and push them up in the cylinder to measure the ring end gap, I am sure they will still be within spec but you may want to replace them anyways... The rub marks on the piston do not look excessive so it should be good to go unless you find defects around the crown after carbon removal... The cases split quite easily on these engines as the tight crank races remain with the crank... Because you have had a con rod bearing failure I would also recommend you also replace the 2 crank end bearings as well because of the debris that has been washing around the crank chamber... You can take the bearing #s to a bearing supply shop and they should be able to fetch you a set at a more reasonable price... You will need a race puller to change them or better yet take your crank into a dealer and have them pull the races for a small {hopefully} service fee...
640 A x 2 |
03-03-2013, 09:38 AM
#69 |
Nob.
Oddometer: 122
03-03-2013, 09:41 AM
#70 |
I.Hopp.
Oddometer: 3,075
That noise may be all due to conrod slap but I still think your left side crank end bearing may also be shot and part of the cause, you'll know better when you split the cases... What you could do now is remove the piston and spin the crank by hand and listen for a gravelly grating noise coming from that bearing...
640 A x 2 gunnerbuck screwed with this post 03-03-2013 at 09:49 AM |
03-03-2013, 09:45 AM
#71 | |
I.Hopp.
Oddometer: 3,075
Your rockers look fine, even the rollers look OK, but really check the smaller one for any up and down wiggle...
640 A x 2 |
03-03-2013, 09:49 AM
#72 |
Nob.
Oddometer: 122
Do you know the part numbers for the crank bearings? Are they a pain in the arse to change at all?
03-03-2013, 09:51 AM
#73 | |
Red Clay Halo
Oddometer: 11,158
I had an old XS Eleven that had a bad exhaust seal, which sounded just like a bad conrod. Once I got a new seal and torqued the header down properly it quieted right up. Exhaust leaks can sound just like mechanical knocking.
03-03-2013, 09:53 AM
#74 | |
I.Hopp.
Oddometer: 3,075
left side nj306c3 Right side nj207ecp The bearings are not difficult to change it is the race removal from the cranks and re shimming to spec that are more of a problem... This page gives an outline: http://advrider.com/forums/showthrea...=632893&page=4
640 A x 2 |
03-03-2013, 09:57 AM
#75 | |
Red Clay Halo
Oddometer: 11,158
IMHO it's hard to tell just from looking at it. Gunner has a great thread showing how to change the crank bearings, and how to correctly shim them.
