Old 02-09-2013, 12:08 PM   #1
MightyManfred OP
MightyManfred's Avatar
Oddometer: 42
Right side lights failed
I upgraded the turn signals on my '87 R80RT to use dual filament bulbs, using them as running lights. This was done 2 or 3 years ago and all was fine until a week ago. The turn signal idiot light now stays on; left turn signals & running lights work; right running lights and turn signals do not. Bulbs are fine - all work in the left side. Turn signal switch appears to function fine - the flasher is clicking the right side when no bulbs are in place. The front running lights share a common power as do the rear running lights. The stock front running/parking light and taillight (which provide the power to the auxiliary running lights).
Would a bad ground do this? Is the flasher suspect - but would it keep the always-on running lights from working?
1987 BMW R80RT - "Lucy!"
http://reformedbaptistlibrary.tk/
There is therefore now no condemnation to them which are in Christ Jesus. (Romans 8:1)
MightyManfred screwed with this post 02-13-2013 at 11:48 AM
MightyManfred is offline   Reply With Quote
Old 02-09-2013, 12:31 PM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,597
I'm not sure about the side running lights but if it's just the indicator playing up My battery earth came adrift a few months ago and zapped the indicator relay giving a similar thing to yours. I replaced the blown transistors in mine for less than 1 so if you don't mind getting the soldering Iron out it can be a cheap fix.
Rob Farmer is offline   Reply With Quote
Old 02-11-2013, 02:06 PM   #3
MightyManfred OP
Oddometer: 42
Thanks for your post, Rob. I enhanced the ground/earth from my battery a year ago, adding a second strap to the frame near the coils. The relay appears to be working fine - but no light on the right side.
It's a bit dreary here today - will wait for slightly better weather and seek out ground wires from the front and see where it goes and what condition it's in.
Old 02-11-2013, 05:58 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,353
The only thing that is side specific would be the wiring or the switch. I suspect wiring. Can't say why exactly. Try switching something so the switch works backwards if you can and see if the problem follows the switch or the wires?
---Albert Einstein
disston is online now   Reply With Quote
Old 02-11-2013, 06:01 PM   #5
MightyManfred OP
Oddometer: 42
That's a good idea. I will work on it maybe tomorrow, Wed for sure.
Einstein was right - don't memorize what you know how to find in a book.
Old 02-12-2013, 01:48 PM   #6
MightyManfred OP
Oddometer: 42
Update.
A.) Can't figure out how to get the plastic cover inside the turn signal switch off so I can see the wires and try swapping out left for right.
B.) With both right side bulbs out, the flasher makes noise and the idiot light flashes off and on when I push the turn signal to the right.
C.) Both running lights on each end of the bike (front and back) share a power line that comes off the parking light (front) or taillight (rear).
D.) All lights on the front share a ground as do all lights in the rear.
E.) I measure just under 12 volts on the running light tab inside the socket on the left side when ignition switch is on, less than 1 volt on the right side (front and back).
I am more confused than when I started, yet I know it is something very simple. What that simple thing is escapes me at the moment.
sigh
Old 02-12-2013, 02:15 PM   #7
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,630
I upgraded the turn signals on my '87 R80RT to use dual filament bulbs, using then as running lights. This was done 2 or 3 years ago and all was fine until a week ago.
What did you do to upgrade the turn signals to add running lights? The "running light" part of the circuit should be separate from and independent of the turn signal circuit (except for a common ground).
--Bill
'73 R60/5 Toaster
Old 02-12-2013, 02:17 PM   #8
MightyManfred OP
Oddometer: 42
--Bill
Bill,
I enlarged the hole in the plastic a little and installed dual bulb sockets. Ran a power line from the tail light (rear) and parking light (front) to extra tab to provide power to the lower amp filament. Bottom line - it as you said: common ground, separate power.
Old 02-12-2013, 04:14 PM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,353
Dual filament bulbs use a different socket. You can't just add a wire to the single filament socket. Well? That's what it sounds like you said.
And another thing you should know. BMWs are European standard machines. They use European bulbs in the turn signals and such. I forget the numbers at the moment but they are not the 1156 & 1157 bulbs we use in the West.
---Albert Einstein
Old 02-12-2013, 04:19 PM   #10
MightyManfred OP
Oddometer: 42
No - I removed the standard socket, made the hole in the plastic a wee bit larger, inserted the dual tab socket and added the secondary power line for the running light filament. Using normal US dual filament bulbs.
Old 02-13-2013, 12:49 PM   #11
MightyManfred OP
Oddometer: 42
Solved!
Simple. And easy to overlook. The common ground on each end of the bike terminates at each device. There ends the common part of the ground wire. When I installed the dual element sockets, I had to attached the ground wires to them differently than the stock sockets (I forget what the stock sockets look like so I cannot describe that difference). The ground wire attachment at both right side sockets had failed. Simple fatigue and an invisible open that I discovered on the front while simply poking around while trying to think.
All lit up know - the bike, that is.
Many thanks to those who volunteered some input here.
Old 02-13-2013, 05:48 PM   #12
Bill Harris
Oddometer: 7,630
The stock turn signal sockets do not have ground wires as such-- the ground to the chassis through the reflector/turn signal assy. Adding a two-contact socket to that reflector, you could either hope for good metal-to-metal contact (iffy) or solder a ground wire to the new socket shell (best).
Glad it is solved...
--Bill
'73 R60/5 Toaster
Old 02-13-2013, 05:51 PM   #13
MightyManfred OP
Oddometer: 42
--Bill
Methinks the RT signals do not ground directly - for sure not in front, where all is plastic.
At any rate - great thanks to have this mystery put to bed!
Old 02-13-2013, 09:10 PM   #14
Bill Harris
Oddometer: 7,630
Ah, I was thinking in /5-land, where the turnsignal housings and all are metal.
"Nevermind"
--Bill
'73 R60/5 Toaster
Old 02-13-2013, 09:12 PM   #15
MightyManfred OP
Oddometer: 42
"Nevermind"
--Bill
I know it's hard to keep all the details of all the airheads straight - look what it did to Snowbum!
Times are GMT -7.   It's 05:09 PM.
