Old 02-09-2013, 04:37 PM   #1
BigChris99 OP
BigChris99's Avatar
Oddometer: 272
Gerbings hook up to Battery Tender plug?
I'm thinking of getting a new Gerbings vest to replace my old Aerostich vest. Will a Gerbings vest hook up to a Battery Tender plug? Do they, or someone make an adapter? I have three bikes, all with Battery Tender plugs already installed. I really don't want to go through all the hassle and expense of buying and adding another connector to all three bikes if at all possible.
4on3off
IBA#7849
1997 Honda Valkyrie, 1998 Kawasaki KLR 650
BigChris99 is offline   Reply With Quote
Old 02-09-2013, 04:44 PM   #2
eddie98
Oddometer: 639
Different connectors. You might be able to find an adapter like this one COAX to ASE
http://www.revzilla.com/motorcycle/g...roller-adaptor
09 DL 650,08 WR250R
09 KLX250S(gone), 03 R6 (gone)
04 WR 450(gone), 01 EX 250(gone),
06 DL 650(gone) , 89 KLR 650(gone)
eddie98 is offline   Reply With Quote
Old 02-09-2013, 04:50 PM   #3
BigChris99 OP
BigChris99's Avatar
Oddometer: 272
Exactly what I need. Thanks. The only problem is that RevZilla is out of them right now. I put my email address on the waiting list.
4on3off
IBA#7849
Old 02-09-2013, 05:07 PM   #4
BigChris99 OP
BigChris99's Avatar
Oddometer: 272
I'm reading some older threads, I don't know if Gerbings still makes that connector. Something about people buying it and using it with competitors brands of electric gear.... WTF is that all about? A sale is a sale. Who cares what the customer does with it after the sale? Why does this need to be so complicated?
4on3off
IBA#7849
Old 02-09-2013, 05:42 PM   #5
Garp
Garp's Avatar
Oddometer: 2,445
Here you go:
http://www.powerlet.com/product/sae-...emale-cable/55
Garp is offline   Reply With Quote
Old 02-09-2013, 06:21 PM   #6
BigChris99 OP
BigChris99's Avatar
Oddometer: 272
Ahhhh. Better. Thank you. Heading out to the movies with the family now. I'll order one when we get home.
4on3off
IBA#7849
Old 02-09-2013, 06:33 PM   #7
HAYVIATOR
Don't be me dude.
HAYVIATOR's Avatar
Oddometer: 306
Yes and yes. I needed that adapter also, found plenty of them at the local Harley shop as HD heated gear is actually rebranded Gerbings. About $6
HAYVIATOR is offline   Reply With Quote
Old 02-09-2013, 09:53 PM   #8
BigChris99 OP
BigChris99's Avatar
Oddometer: 272
Really. I'll have to check Victorville Harley. Thanks for that heads-up. Getting some good intel here.
4on3off
IBA#7849
Old 02-10-2013, 09:16 AM   #9
the_gr8t_waldo
Oddometer: 2,150
if you control, by way of an simple on/off switch you'll NOT need an adapter. it's the electronic controlers that are polarity sensitive
the_gr8t_waldo is online now   Reply With Quote
Old 02-10-2013, 11:26 AM   #10
fast4d
Oddometer: 2,456
if you use the battery tender cable to the battery make sure you upgrade the fuse
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 02-10-2013, 05:15 PM   #11
bmac
Oddometer: 406
Gerbings deliberately used a different connector due to different power requirements of their garments versus those of the battery tender. I use battery tenders on all my batteries but I would not use an adapter due to this. You will either blow a fuse or take a chance on doing some damage.
Gerbing's SAE to Coax Adaptor Cord
SAE plug on one end and a coax male plug on the other end
This plug can connect pre-2003 clothing from Gerbing's, which used SAE plugs, to the new coax temperature controllers
Cannot be used to power heated clothing from a Battery Tender plug
bmac screwed with this post 02-10-2013 at 05:21 PM
bmac is online now   Reply With Quote
Old 02-10-2013, 06:32 PM   #12
Elmer
Elmer's Avatar
Oddometer: 174
Works well. Did it for three years on a Duc ST2 that I commuted on up and down I-95 to DC. Ran jacket, pants and gloves through a dual controller. No issues.
Ooh Rah!
Ducati 900SS / Yamaha YZ250F / KTM 450 XCW Six Days / KTM 950 Adventure / Polaris 500 EFI
Elmer is offline   Reply With Quote
Old 02-10-2013, 07:37 PM   #13
BigChris99 OP
BigChris99's Avatar
Oddometer: 272
So, Even if I upgrade the fuse in my BT cables, I still shouldn't use them with an adapter? Why not? It's only going to be
a vest with an on/off switch. No gloves, pants or heated undies. Please tell me why I can't do this, cuz I'm getting confused
here. The least capable charging system I have is on my 1st generation KLR. Next is the stock Valkyrie and after that is
my Wing with a CompuFire alternator. The C- Fire puts out plenty of juice to run a vest.
4on3off
IBA#7849
Old 02-10-2013, 07:41 PM   #14
TALLGUY
TALLGUY's Avatar
Oddometer: 492
Maybe I have an old jacket or maybe I am just confused but my Gerbings runs off the same connector that I use to hook the battery tender to the battery. I have done that for years on at least 4 different bikes.
Who are you, Ernest Hemingway?- Campari
Nobody pretends to be from Iowa.- WaterWheel
TALLGUY is offline   Reply With Quote
Old 02-10-2013, 07:44 PM   #15
Multiplicity
Oddometer: 172
Yes, it will
Multiplicity is offline   Reply With Quote
Times are GMT -7.   It's 01:37 PM.
