Old 02-10-2013, 04:34 AM   #1
late-apex OP
XR650L
late-apex's Avatar
Oddometer: 71
xr650l and effing mud
The stock tires totally suck in mud. Go too fast and the front end washes out go too slow and gets stuck. What tire do you guys recommend for those conditions, I also ride on the streets and would like to get some mileage out of the tire. I also was wondering if you guys keep the front sprocket cover on cause mine is totally stuffed with mud or dirt on my trail rides.
late-apex is offline   Reply With Quote
Old 02-10-2013, 05:30 AM   #2
JALnSC
JALnSC's Avatar
Oddometer: 1,034
I run d606 on my XRL. I have about 3 k on them and still look good. Only adjustment made I'd changing air pressure depending on riding surface. 20 on street 10-12 on sand and mud.
Go ahead and have them put rim locks on while changing tires. It will save the tubes and don't skimp on the tubes get the heaviest you can. Screw in stems are a must or else you are getting cruser bike tubes.
You think chicks dig guys looking like road-grimed power-rangers with cool scars?
You must be smoking rope, Boy!
JALnSC is offline   Reply With Quote
Old 02-10-2013, 08:09 AM   #3
late-apex OP
XR650L
late-apex's Avatar
Oddometer: 71
How about the sprocket cover? Mine continously fills with dirt when off roading.
Old 02-10-2013, 10:08 AM   #4
Big Augie
Transient
Oddometer: 1,065
I run a XR's Only sprocket cover on mine, 606 Dunlops also work well.
My doctor said I wouldn't have so many nosebleeds if I kept my finger outta there.
Ralph Wiggum
Big Augie is offline   Reply With Quote
Old 02-10-2013, 01:19 PM   #5
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,284
That sprocket cover is also a case saver. I wouldn't recommend you run with out it, or an aftermarket substitute. If you do you risk breaking your case if you loose a chain.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 02-11-2013, 07:32 PM   #6
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,944
Hurricane Bob is offline   Reply With Quote
Times are GMT -7.   It's 01:05 AM.
