Old 02-10-2013, 08:18 AM   #1
1050rat OP
Oddometer: 36
990 Rear Shock Lower Mount Refitting
Hi,
I'm trying to refit my rear shock following a service. The top bolt is in place but for the life of me I can't get the lower mount back into the swingarm. The bush sits very slightly proud of the swing arm and can't be prised over it no matter what?
Any advice on tips or tricks welcome
Cheers
1050rat
1050rat is offline   Reply With Quote
Old 02-10-2013, 08:47 AM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,155
Originally Posted by 1050rat View Post
Hi,
Cheers
1050rat
You need to tap it (the lower end of the shock absorber) into place with a rubber mallet (preferably) and don't hit the spring like i did.
page 10-9 of the repair manual.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 02-10-2013, 08:53 AM   #3
DirtyADV
DirtyADV's Avatar
Oddometer: 2,322
What he said, I usually lift the swing arm up so you hit the lower mount from the rear and force it forward, try not to go to far but if to far it can be pryed out a little with a big screwdriver from the front of the mount.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 02-10-2013, 09:15 AM   #4
1050rat OP
Oddometer: 36
I've tried lifting the swingarm and "gently tapping" but the bush mounting will not clear the collar on the swingarm. It's just bouncing off it and not remotely thinking of wedging itself into place?
Went back out into my garage after a break and like a sign from above a little piece of sandpaper fell to the floor. So, off came the shock followed by a bit of light buffing coupled with some light dremel work with a wire brush (the bush was starting to show signs of mild abuse). Popped her back in with plenty of grease and this time the light tap with a dead blow hammer worked hoorah!!
1050rat screwed with this post 02-10-2013 at 12:31 PM
Old 02-18-2013, 08:44 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,056
Just to finish off this thread. You can take a brass punch and tap the insert in the swing arm over to get more room to fit the shock back in. When you tighten the bolt it will just move over again to be tight on the shock again.
"Son, you can't do both"
Old 02-19-2013, 04:15 AM   #6
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,155
Didn't know about this little trick.
Old 02-27-2013, 12:54 PM   #7
1050rat OP
Oddometer: 36
Hi Zuber sounds like a neat idea have you got any pictures of this technique ?
I like pictures :-)
Cheers
Times are GMT -7.   It's 02:38 AM.
