Old 04-02-2012, 06:26 AM   #1
r1200gs_chris OP
r1200gs_chris's Avatar
Oddometer: 132
Funky rear wheel stud threads
I changed the rear wheel flange on my '05 this weekend and was really surprised at how simple the whole job was. As I was reassembling 1 of the rear wheel studs on the replacement flange was being stubborn and needing some talking to before it would thread in. I could not thread it in with my fingers and confirmed that it was the threads in the flange and not the bolt by swapping another stud in. I did get it to thread and torque properly but next time it's out it will give me problems. So, I am planning on using a M10 x 1.25 thread chaser next time I'm working in there to clean up the threads. Worst case scenario would be a thread insert or replace the flange (again) . Will using a thread insert throw off the balance on the rear wheel? Has anyone else done this?
r1200gs_chris is offline   Reply With Quote
Old 04-02-2012, 06:37 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,371
Likely there is a burr in the threads that will clean with a chase. I recommend you use new bolts as well.
I wouldn't like to tap and install an insert on just one of them, though it would probably be OK.
Jim
JimVonBaden is online now   Reply With Quote
Old 04-02-2012, 09:26 AM   #3
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 593
I've done this on Fidanza flywheels for the 300ZX, they are aluminium and tend to strip out the threads after a few times of install and removal, you won't have anything noticeably out of balance. Your tire wearing down and possibly changing the way it's balanced will have more effect than a heli-coil or time-sert
Kai
2008 BMW GSA
2000 Kawasaki Super Sherpa
SkiFly01 is offline   Reply With Quote
Old 04-02-2012, 11:15 AM   #4
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,235
I'd just start with a thread chaser. If it threads in easily until the burr, then you won't have affected the strength.
How far in was the problem?
Old 04-02-2012, 11:19 AM   #5
r1200gs_chris OP
Oddometer: 132
Started after a few threads, say 5mm.
Old 02-16-2013, 01:42 PM   #6
r1200gs_chris OP
Oddometer: 132
It was a balmy -6 today so I decided to pull the rear-wheel and checkout the threads. I ran the 10 x 1.25 thread chaser thru no problem, good as new! Thanks for the advice.
- Chris
Old 02-16-2013, 03:23 PM   #7
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,014
Good to know about this. Will bring a stud along when/if I pick one up at the parts counter for an on-the-spot initial check. Some incentive here, then, to have the dealer install it.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 02-17-2013, 07:27 PM   #8
r1200gs_chris OP
Oddometer: 132
That's a good thing deal to bring a stud along. It takes about. And hour to replace this part. Remove the wheel, rear caliper, and speed sensor. Remove the retaining clip and attach a gear puller, using a plate across the axle (I had a cap machined to sit inside the axel). Start heating the flange with a torch, rotating slowly and putting pressure on it with the gear puller. You will hear the splines release after a few minutes and it will pull off by hand. Heat up the new flange with the torch for a few minutes and quickly and slide it back onto the axel. Make sure it seats in and replace the c-clip. Have beer and pat yourself on the back. While you have it all apart go ahead and change your gear oil while you are at it.
Good luck!
Times are GMT -7.   It's 02:00 PM.
