Old 02-10-2013, 01:21 PM   #1
dwj - Donnie OP
dwj - Donnie's Avatar
Oddometer: 10,930
Moto down in Guatemala - Need Advise (1100GS)
Hi!
My normally very reliable 1996 R1100GS has had a few issues on this 6 weeks of a three month tour. First it was the Halls Sensor and now, I believe the fuel pump has went bad. You can hear it come on when the key is turned on, but it acts like it is not getting fuel. One problem that has been found during the past few days is that the screen before the fuel pump has come apart and the red lining that BMW put inside the tank is flacking off and stopping up the screen from the inside. Is there alternative fuel pumps for this moto. I am in San Juan Ostuncalco, Guatemala. Thanks!
Donnie
Donnie - Retired & Riding - 2007 KTM 990ADV 20,250 Miles
Return to Mexico 2012: http://www.advrider.com/forums/showthread.php?t=802682
Mexico & Central America Solo 2012: http://www.advrider.com/forums/showthread.php?t=767492
6,700 Miles to Baja, MX Solo 2011: http://www.advrider.com/forums/showthread.php?t=750875
dwj - Donnie is offline   Reply With Quote
Old 02-10-2013, 01:48 PM   #2
dwj - Donnie OP
Oddometer: 10,930
I just found where I had Book Marked a Thread on a replacement pump. Now if I can find one here and hope that it it actually the problem!
Another question. I looked for a replacement fuel filter this morning and all I could find was a clear plastic unit with a paper filer inside. Will this function correctly inside the tank. It seems to me if the gas from the inside don't hurt it, gas from the outside won't. But, will it contain the fuel pressure of the pump?
Old 02-10-2013, 02:07 PM   #3
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,425
You will probably have to get as much of that liner out as possible if its coming loose, it will clog the input filter again I think
here is my thread, with a part number or 2
http://www.advrider.com/forums/showthread.php?t=812985
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is online now   Reply With Quote
Old 02-10-2013, 03:52 PM   #4
MC_Collector
Riding Again!
MC_Collector's Avatar
Oddometer: 79
Fuel Filter
Hi Donnie,
If you find a fuel filter made for fuel injection it might work. Fuel pumps for engines with carbs operate at pressures typically <= ~ 5psi, while every fuel injection system I've looked at operates between 40-50 psi. Generally FI Fuel filters have metal housings to withstand the higher pressure. You probably wouldn't want to be riding the thing if it ruptured from overpressure. I've read about cleaning out tanks by putting stuff in it and shaking it a long time like maybe bb's, a few handfuls of metal nuts, or gravel might even work so long as you could get it all out. Sort of a manual bead blasting....
I still have the pressure gauge for your old Corvette. If you can get one in the discharge side of the pump, it would tell you if it's making enough pressure. Generally > 40 psi is reguired to make it run right. The caveat here is the only ones I've had any issue with are on GM car engines.
The flaking material would make me suspect the filter first
Dusty Evans
MC_Collector is offline   Reply With Quote
Old 02-10-2013, 04:32 PM   #5
vintagerider
vintagerider's Avatar
Oddometer: 1,744
You've seen crackhead's thread? If you can not locate that Bosh kit in Guatemala then have someone over-night it to you. It's pretty light. I would pressure wash the inside of the tank. By-pass the in-tank filter with a suitable jumper such as a piece of steel brake tube. Fit Wix 33323 externally to the rear abs line mount hole using the supplied clamp.
Time required to take r-r pump plate and clean tank is just a couple of hours if you have the parts. I have new in-box spares if you need them.
Use posi-lok red barrels inside tank if you don't have a soldering iron.
IMO there isn't a good substitution for the filter inside the tank. PP use one that is not rated for injection and doing so can lead to plugged injectors. The Wix is 10 micron and has plenty of spare capacity. You can also mount it to the rear, under the rear porter. The forward facing pump plate nipple is your pump output. That goes to the external filter then on to the black nylon fuel distributor inlet. Pump outlet pressure should be capable of 100 lph at 50 psi. The air box mounted regulator is pre- set to 43 1/2 psi. Lots of pumps can supply this but only a few mount well to the 11xx pump plate.
Jot down the do's, don'ts and common mistakes before you begin such as not busting off tank studs or using only submersible rated hose inside the tank and you will be fine.
for sale: 1968 R 69 S-us original condition
vintagerider screwed with this post 02-10-2013 at 04:57 PM
vintagerider is offline   Reply With Quote
Old 02-10-2013, 05:53 PM   #6
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,478
There is supposed to be a good BMW mechanic in Antigua, Guatemala, if that is any use too you. I know you would rather fix it yourself.
Below is a link to the thread where he was used, post 7
http://www.advrider.com/forums/showthread.php?t=856765
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 02-11-2013, 08:58 AM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 3,004
Darn that liner, had enough problems with that years ago. Removing the rest can be a real pita if you don't have access to the right products.
Down there, I'd look up a radiator shop, they may be able to help you if just to clean the tank.
DIY and not tested by myself, apparently good old vinegar will work altough it may take a few days and you may have to toss a few screws in there and shake.Better maybe if you can find cleaning/stripping vinegar, it has a higher acetic acid content.
I sure shaked a tank a lot back then, even drove around with it in the back of the car for days letting the accell/decell move the weighted "Kurly Kates" I had stuck in there.
The filter sock, that's not all that much good at filtering, you may have plugged the pump itself but if it still runs I'd look at cleaning/flushing it first and some bench testing. Plugged fuel filter well....just removed one such from a BMW at half the recommended milleage.Not that good for the pump and now I am worried.
Anyway, quite a lot of info on the net as how to deal with the "Redcoat", lots on here:
https://www.google.ca/search?source=....1.iZNILDkj-dI
Have tools, will travel!
Old 02-12-2013, 05:41 AM   #8
dwj - Donnie OP
Oddometer: 10,930
Eh?
The pump and filter have been replaced. That was not the problem! A mechanic is going to look at it this morning, plus I have a person lined up to haul it to the BMW Store in Guatemala City. Guatemala City is only 110 miles from my location.
Old 02-12-2013, 05:43 AM   #9
dwj - Donnie OP
Oddometer: 10,930
But in the mean time, I am staying in a fairly nice hotel for $10 per day. Three good meals per day, including steak cost $7, so all is good!
Old 02-12-2013, 05:46 AM   #10
dwj - Donnie OP
Oddometer: 10,930
It seems to me to only run a bit on one cylinder, but I don't know which one. Every now and then for a split second it will hit on both. If you try to give it throttle, it dies instantly.
Old 02-12-2013, 05:46 AM   #11
mouthfulloflake
Not afraid
Oddometer: 11,425
verify fuel flow, Roger_04 s method is likely the easiest to do where you are.
maybe this will help
http://bmwsporttouring.com/ubbthread...010#Post790010
[img]http://www.streamlineleaders.com/images/fuelfix10.JPG[/img
quote from Robert at the above link:
I ran the motorcycle for 60 seconds and collected 3 lbs. 13 oz. of fuel which equates to 0.64 gallons (6 lbs. per gallon), which translates to 145 liters per hour. Much better than the pump spec of 110 l/h and easily 3 times the amount required to produce full power. Every 10 minutes the pump runs 5 gallons of fuel through the system.
Thinking back on the failure of my system and the multiple cracks in the hose. I suspect that my system was running fine with some leaks but then one opened to the point where there was little to no fuel pressure. If I'd been measuring pressure and volume once a year I might have caught this long ago.
The 145 l/h will serve as a baseline for future measurement to assess the health of the fuel delivery system including pump, filter and internal hose condition.
As a side note, the new pump is noticeably quieter than the old one. Also the engine is noticeably smoother (am I imagining this?) Which I believe is due to the better injector matching (< 2%) after cleaning.
LINK TO HIS ORIGINAL POST
http://www.advrider.com/forums/showthread.php?t=806681
Old 02-12-2013, 06:18 AM   #12
Dan Căta
Dan Căta's Avatar
Oddometer: 1,467
Send a message via Yahoo to Dan Căta
Donnie,
I have already been where you are now with your bike. It was the same, a 1100 gs. I have tried everything and all should be OK, but the bike ran like crap. It would idle fine and when twisting the throttle, it would die.
The problem was the fuel filter. The owner had some paint on the inside of the tank. It was as if someone put in there 1 liter of paind and twist the tank on all sides so that it would get covered on the inside. Needless to say that the paint came off.
He said the he already replaced the fuel filter, so I left that one alone. After a while, I opened the tank again and cleaned ALL the paint on the inside and put in a new filter. The bike then ran as new :)
Dan.
Dan Căta is offline   Reply With Quote
Old 02-12-2013, 07:43 AM   #13
dwj - Donnie OP
Oddometer: 10,930
Originally Posted by Dan Căta View Post
Donnie,
Dan.
I have pretty much gotten all of the loose paint out of the tank and then installed a new fuel pump, including the pre-filter and a new fuel filter. It changed nothing.
Old 02-12-2013, 08:03 AM   #14
mouthfulloflake
Not afraid
Oddometer: 11,425
If you are confident in the tank internal parts, then maybe some tank liner got lodged in an injector?
try to hook a 9volt battery to an injector and open it, and then spray cleaner or compressed air through it.
maybe that will fix it?
Old 02-12-2013, 10:08 AM   #15
Dan Căta
Dan Căta's Avatar
Oddometer: 1,467
Yes, my bad.
Forgot to add that I also cleaned the injectors in a ultrasound cleaning shop.
Dan.
Times are GMT -7.   It's 02:52 PM.
