Old 02-10-2013, 04:25 PM   #1
dirtdadx OP
Noob ad Infinitum
dirtdadx's Avatar
Oddometer: 480
Canbus reset necessary after blown low beam?
1) Low beam burned out, hi beam ok
2) LAMP error in the display all the time
3) Inspected old low beam, filament was melted. High beam bulb looks fine
4) Got replacement bulb, installed good high and low beam
5) Lamp error is gone, but still no low beam
6) New bulbs works as high beam
7) If I put a bad bulb in the high beam, I only get a LAMP error when I turn on the high beam
Normally I would say blown fuse, but not on a Canbus system.
If this was a bad wiring connection it would still show a LAMP error even with a good bulb, right? And the original bulb did fail. Do I have do maybe do some kind of Canbus reset, and how? What else could be wrong?
dirtdadx is offline   Reply With Quote
Old 02-10-2013, 04:30 PM   #2
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,694
strange problem. When I changed my bulps I never had that kind of problem and everything was alright.
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 02-10-2013, 05:36 PM   #3
Garp
Garp's Avatar
Oddometer: 2,446
Did you start the bike?
Pretty sure the low beam doesn't illuminate until the engine is running
Garp is offline   Reply With Quote
Old 02-10-2013, 06:05 PM   #4
It'sNotTheBike
Oddometer: 704
The new bulb could be defective.
Sometimes it is the simple things which turn out to be the culprit while we
are agonizing over all the complex stuff which "might" be the cause.
There is an old story about a toy train not working on Christmas morning. The Dad is
checking everything, using a test meter, looking at the transformer, checking the track, etc .
And then Mom walks past and plugs the power cord into the wall receptacle and the train works
It'sNotTheBike is offline   Reply With Quote
Old 02-10-2013, 06:55 PM   #5
dirtdadx OP
Noob ad Infinitum
dirtdadx's Avatar
Oddometer: 480
We have a winnah! I always have the high beam on, and that does come on without starting the engine, I never noticed that the low beam only joins it after starting the bike. Doh!
Old 02-10-2013, 07:47 PM   #6
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,444
Originally Posted by It'sNotTheBike View Post
There is an old story about a toy train not working on Christmas morning. The Dad ischecking everything, using a test meter, looking at the transformer, checking the track, etc .
And then Mom walks past and plugs the power cord into the wall receptacle and the train works .
Just like me trying to troubleshoot my buddies outside light after he tried to fix it for an hour. I tightened the bulb another 2 degrees!
I don't believe you will get a LAMP caution when the high beam is burnt. Should be obvious. Then again, it wasn't designed to have the high beam as a running light. But you say you did so I'll take your word. Wish I had that problem. Snow sucks.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Old 02-11-2013, 02:07 PM   #7
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,694
sorry but
Old 02-11-2013, 02:17 PM   #8
Garp
Garp's Avatar
Oddometer: 2,446
It's a lesson that I learned the hard way, and more than a few others have as well.
Times are GMT -7.   It's 10:24 PM.
