Old 02-10-2013, 06:12 PM   #1
chilly_moose OP
Oddometer: 35
Finally got my KTM 450 EXC
So i finally saved up a few bucks to buy my first enduro bike.
It's a 2004 KTM 450 EXC.
If any body can give me some insight on this bike i would greatly appreciate it.
http://www.bikepics.com/pictures/2514121/
chilly_moose is offline   Reply With Quote
Old 02-10-2013, 08:31 PM   #2
It'sNotTheBike
Oddometer: 704
It is more honorable ( and less lazy ) to search for yourself rather than ask to be spoon-fed by
people who probably have better things to do than do your homework for you.
Click on the link below and you will be able to learn virtually everything you could
ever possibly want or need to know about the bike you just bought. There are 36,600
search results. That ought to keep you busy for a few hours.
http://www.google.com/search?hl=en&a...pe=&as_rights=
It'sNotTheBike is offline   Reply With Quote
Old 02-10-2013, 08:53 PM   #3
Oshiat
Oddometer: 157
I have an 05, they are great bikes. Buy a decent set of wrap-around radiator guards and go ride.
Oshiat is offline   Reply With Quote
Old 02-11-2013, 01:44 AM   #4
chilly_moose OP
Oddometer: 35
Thanks it's not the Bike...
I appreciate your help. But i have already googled about the bike...
I was just looking for a more indepth look than what is posted on the search engines.
maybe some owners feed back of things they like and dislike about it.
But you already knew that since you know i'm lazy. and thanks for not having anything else better to do than reply to my post you dumb ass
Old 02-11-2013, 01:45 AM   #5
chilly_moose OP
Oddometer: 35
Thank you Oshiat
people like you make these forums enjoyable.
Old 02-11-2013, 05:39 AM   #6
loosesprocket
loosesprocket's Avatar
Oddometer: 110
Join ktmtalk.com and go to the Big Bike Forum, RFS-Racing Four Strokes and you will find an endless amount of information. When you first open that forum look at the pinned: Evolution of the RFS motor and chassis. I have an 07 450 XC and love it.
loosesprocket is offline   Reply With Quote
Old 02-11-2013, 05:52 AM   #7
400psi
Cropdusting
400psi's Avatar
Oddometer: 502
Great bike.
couple of basics that you will find or need to check out.
1. dont idle the bike for any extended period of time. It will over heat.
2. Jd jet kit works wonders.
3. change the lower screen bolt to the aftermarket bolt that allows a socket to be used. Best $13 spent or whatever they cost
4. set sag. 04's have a top out spring so correct preload is important. google "golden rule of sag"
5. Chain tension. Take off shock. place swing arm in line with countershaft. allow for slight slack in chain. set axle blocks. put shock back on. this is your chain tension. too tight will cause wear to countershaft and csseal. It will look loose.
6. Use 1.2 ltrs oil when filters replaced. 1 ltr when just changing oil
7. put header guard by exhaust otherwise you'll hve a lot of holes in your pants
These are a couple of high points to help search for. as mentioned ktm talk is great for all this info as well as adv. There is tons of info about this bike. hopefully this will help get you looking in the right direction
Enjoy
I'm so far behind I think I'm in first
400psi is offline   Reply With Quote
Old 02-11-2013, 05:53 AM   #8
400psi
Cropdusting
400psi's Avatar
Oddometer: 502
never mind about exhaust guard. I just looked at you pics
Old 02-11-2013, 07:04 AM   #9
buddoggin
buddoggin's Avatar
Oddometer: 310
Current bikes:
2012 Triumph Tiger 800
2010 KTM 690 Enduro R
buddoggin is offline   Reply With Quote
Old 02-11-2013, 11:07 AM   #10
GrizGirl
Oddometer: 1,457
Go to Google. Copy this as your search: site:advrider.com ktm 450 exc advrider.
Enjoy reading the information posted in the correct forums of ADV for this type of question. Pics, pics, pics (which, surprisingly, is a forum dedicated to PICTURES) is NOT the right place for this question and you will not find a whole lot of useful information here because you posted your question in the wrong place.
You're welcome.
GrizGirl is offline   Reply With Quote
Old 02-11-2013, 11:44 AM   #11
Crazy_Dave
Back'in it in
Crazy_Dave's Avatar
Oddometer: 582
Locking lever update
It’s easier to apologize then it is to ask permission.
01 R1-01 CBR929-08 WR250R-92 DR650 (24-7 365)-07 F650GS-05 200 EXC-03 450EXC
Crazy_Dave is offline   Reply With Quote
Old 02-11-2013, 04:12 PM   #12
GB
Mod Squad
GB's Avatar
Oddometer: 56,741
Not in the Pics forum... off to Thumpers.
Old 02-11-2013, 04:40 PM   #13
chilly_moose OP
Oddometer: 35
Awesome... You are the man! Thanks
Old 02-11-2013, 04:42 PM   #14
chilly_moose OP
Oddometer: 35
Originally Posted by 400psi View Post
Great bike.
Enjoy
Wow... Good stuff here! Thanks a bunch!!!
Also thank u Grizgirl and crazy dave!
Old 02-11-2013, 07:44 PM   #15
StolenFant
Oddometer: 244
Oshiat,
Can you elaborate on "decent" pair of wrap around radiator guards? I too picked up title for new to me 05 450EXC, and just removed tank. They are on there rather flimsily. Plenty of "billet", and ton's of other variations, Do any of them provide real protection to rad's? Once price gets close to $100, I can easily fab much more substantial guards WITH bracing.
StolenFant is offline   Reply With Quote
Times are GMT -7.   It's 07:27 PM.
