Old 02-11-2013, 01:02 PM   #1
BruceDeuce OP
BruceDeuce's Avatar
Oddometer: 20
Noise in top end?
I recently bought a 1986 KLR 600 for $500.00. The bike was sitting for a year and a half. It starts right up but will only run on full choke. I can fix that by cleaning the carb! The other thing is a clicking noise from the top end. Could that be the Cam Chain Tensioner? Any input would be appreciated!
BruceDeuce is offline   Reply With Quote
Old 02-11-2013, 01:58 PM   #2
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,850
Always make sure the valves are in spec before you go diving into anything else (carb, cam chain tensioner, etc). If the valves are out of spec, even a perfectly-tuned carb won't make the bike run right.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 02-11-2013, 03:12 PM   #3
BruceDeuce OP
BruceDeuce's Avatar
Oddometer: 20
Thanks for the response! Could the valves be out of adjustment due to sitting for over a year.
Old 02-11-2013, 03:34 PM   #4
Dan in Grand Rapids
Dan in Grand Rapids's Avatar
Oddometer: 56
The valves could have been out of adjustment before it sat. I agree with Stretch. Check the valves and then clean the carb. It will probably make it run a lot more smoothly and quietly.
Dan in Grand Rapids is offline   Reply With Quote
Old 02-11-2013, 04:14 PM   #5
BruceDeuce OP
BruceDeuce's Avatar
Oddometer: 20
ok I will do that, thank you! Anything I should look out for when doing the valves I do have a manual and will follow their instruction.
Times are GMT -7.   It's 03:26 AM.
