Old 02-15-2013, 07:05 AM   #1
okiebandit1 OP
okiebandit1's Avatar
Oddometer: 112
Question 2010 Adventure fuel pickup?
Looking to gain some of the vast knowledge in this forum. I ran my 2010 GSA fuel down to about .5 gallon left in the tank. I parked on the side stand and went in to get some parts came back out and bike hit once but did not start. Tried on center stand then again on side stand trying to get fuel to the pickup tube. No luck. Got about a quart of fuel from parts store and finally got it to fire. Question is, what side is the fuelpump pickup and is there a procedure to get the last bit of fuel. Just needed to get a couple of blocks to the station. I have seen a fellow adv has built a jumper for the fuel pump, would this help in this situation? Thanks for any assistance in my quest for knowledge.
"Life is good when on a motorcycle."
500 xc-w
XR650L
2010 R1200 GSA
okiebandit1 is offline   Reply With Quote
Old 02-15-2013, 03:22 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,469
On the GSA there is a pickup on the left, and a sucking jet pump on the right to transfer fuel to the pump side.
That said, if you can lean your bike over on the left pretty far you can pick up a few ounces.
Jim
Old 02-15-2013, 04:42 PM   #3
LaurelPerryOnLand
Oddometer: 3,481
Jim,
Does the same hold true for the GS?
Leaning to the LEFT side will get you the last few ounces...in case of an emergency?
If you use this procedure...do you have to rename your bike "ILENE"?
LaurelPerryOnLand screwed with this post 02-15-2013 at 07:58 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 02-15-2013, 04:46 PM   #4
JimVonBaden
"Cool" Aid!
Oddometer: 53,469
Originally Posted by LaurelPerryOnLand View Post
Jim,
It should. The early ones had the return on the right, and the later ones on top. Either way, the pick-up is on the left.
Jim
Old 02-15-2013, 07:45 PM   #5
okiebandit1 OP
Oddometer: 112
Thanks Jim. Do you need to let it lean over more than just the side stand?
500 xc-w
XR650L
2010 R1200 GSA
Old 02-15-2013, 08:54 PM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 53,469
Much more unfortunately.
Jim
Old 02-16-2013, 08:49 AM   #7
Amania
Amania's Avatar
Oddometer: 106
Jim
Yes ... Almost upside down
Amania is online now   Reply With Quote
Old 02-17-2013, 05:04 AM   #8
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 976
Not really. My plumbing in the right lobe got dislodged. It would cut out about 8km after the fuel level warning light would light up. I would stop on the shoulder, put it on the side stand and then pull it over smartly to the left over the sidestand. Got enough fuel in left lobe for 35km. 2010 GSA
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 02-17-2013, 09:26 AM   #9
Amania
Amania's Avatar
Oddometer: 106
My post was for a 12GS not GSA....And to get every last ounce
Lay it on its side and lift the wheels up
Times are GMT -7.   It's 08:58 AM.
