Old 02-15-2013, 09:30 AM   #1
tinkerz OP
Sloroad Rambler
Oddometer: 11
GS in a Tacoma
With any luck at all I will be picking up my new to me 2001 1150gs tomorrow. Has any one tried to stuff one into the 6' bed of a Tacoma pickup? There is supposed to be a loading ramp available for use at a local cycle dealer so getting it in won"t be a problem and I have a way to unload safely at my shop.
tinkerz is offline   Reply With Quote
Old 02-15-2013, 09:32 AM   #2
LaurelPerryOnLand
Oddometer: 3,478
100 THREADS all GS/GSA owners should read.
15 HOW DO I TIE DOWN MY BIKE FOR TRANSPORTING?
http://www.grassrootsbmw.com/uploads/Tiedown2.pdf
http://advrider.com/forums/showthread.php?t=853572
Might want to review BEFORE transporting.
LaurelPerryOnLand is offline   Reply With Quote
Old 02-15-2013, 09:33 AM   #3
jeanyves
Oddometer: 15
it will probably be on the very edge of the tailgate,i use to fit my katana 750 sideways and barely close the gate
jeanyves is offline   Reply With Quote
Old 02-15-2013, 09:42 AM   #4
officerleroy
officerleroy's Avatar
Oddometer: 126
I've loaded my 800GS (which has a longer wheelbase) in my short bed frontier and it just sits on the gate. You shouldn't have any problems.
officerleroy is offline   Reply With Quote
Old 02-15-2013, 10:32 AM   #5
jachard
Oddometer: 603
I have put my 1150 and my 1200 in my 2006 Tacoma many times. The only issue for me is the height( I have the 4X4 TRD edition). As a result, I have one ramp for the bike and one ramp for me. I keep the bike on and just drive it up, no problem. You won't be able to close the tailgate but it fits in fine.
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
http://octaneworks.wordpress.com/
jachard is offline   Reply With Quote
Old 02-15-2013, 10:42 AM   #6
GrizzLee
RubiKon Adventures
GrizzLee's Avatar
Oddometer: 528
Just be careful when loading your tailgate. I'd take it off if you can.
One of my beefs is the lack of good support on these newer trucks. The tailgate is rated for 200 pounds. The cables can break at anytime. Mine broke last year from fatigue when I loaded an ice chest on it. My brothers Tacoma cables (same as my truck) broke during loading a bike up a bike ramp. Trust me, you may be able to load more than 200 lbs on the tailgate at any given time, but over time the cable fatigues and eventually breaks. I miss my old Toy truck which had a 4 bar mechanism in there instead of the whimpy cables.
BTW: See this link... http://www.tacomaworld.com/forum/2nd...ght-limit.html
Take Care, -GrizzLee
"Nature Sets the Boundaries; We choose to cross"
Blog: RubiKonAdventures
RR: Destination Nuxalk Nation
RR: Our Life Behind Bars
GrizzLee screwed with this post 02-15-2013 at 10:47 AM
GrizzLee is offline   Reply With Quote
Old 02-15-2013, 11:24 AM   #7
tinkerz OP
Sloroad Rambler
Oddometer: 11
Thanks to all. It is a 5.5 hr drive one way to pick up the bike so I want to make sure I have bases covered. I have decided to use a 2x12 plank that extends from the front of the box out over the tailgate. When the bike is strapped in place the weight on the front end will hold the plank in place and if the rear wheel extends out onto the tailgate it will take some of the weight off from the end gate. Sounds like I won't need it, but just in case.
Old 02-15-2013, 02:52 PM   #8
Gregster
Gregster's Avatar
Oddometer: 979
I have an '05 Tacoma with the 6' box. They do have weak tailgates so you probably don't want the rear wheel of a 400+ lb. bike sitting directly on there. I would use a ratchet strap or something to go through the spokes in the wheel and around the 2x12 to keep it from shifting around if you are going to be travelling on a bumpy road. You shouldn't have any problems with the Taco aside from concerns with the tailgate.
Gregster is offline   Reply With Quote
Old 02-15-2013, 04:57 PM   #9
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,385
Really one of the only reasons I didn't buy a Tacoma. Yeah, be sure to put the weight of the bike on a plank rather than the tailgate wholly.
As far as unloading, any chance you have a nice deep culvert/ditch near your home or at a neighbor's home? Back into that and you should be able to roll the bike off easily, then pull the truck away. My favorite way of loading and unloading bikes.
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 02-15-2013, 06:10 PM   #10
Steve G.
Steve G.'s Avatar
Oddometer: 6,870
I've taken my 1200GS all over the place in thr 6' box of my '08 Ranger. The tail gate will have to stay down, I would not worry about the back of the bike sitting on the tail gate while you travel. Honestly, if the tailgate can take the weight of the ramp hanging off of it, with the bike on the ramp, it can take less than 1/2 the weight of the bike on it.
Two things you need to be aware of:
1] Be aware that you will have to travel with the tailgate folded down, but the bike will be too long to remove the tailgate during the transport. Be aware that there's a small chance of rocks flying up off the rear tires and impacting/scratching the tail gate.
2] Be aware that the front of the box bulkhead on newer pickup trucks are not made like they used to be. When you offer the front tire of your bike up against the bulkhead, it is VERY easy to bend the bulkhead, sometimes bending the bulkhead enough to hit the back of the cab when tightening the tiedown straps [which are best tied to the handlebars, not the frame of the bike, the higher the better] . I would make use of a 4x4 by a foot or two that the front tire will roll against, so that the pressure against the bulkhead is down low by the welded part of the box floor rather than the weaker metal at the upper portion of the box.
Steve G. is offline   Reply With Quote
Old 02-15-2013, 07:01 PM   #11
UtahSooner
awagnon
UtahSooner's Avatar
Oddometer: 83
Toyota openly admits their pickup truck tailgates "should be thought of as a door and not a cargo carrying device". Essentially their words after multiple tailgates bent from people just sitting on them or loading ATV's with a ramp.
I picked up an F650 in Calif and hauled it home to Utah in the back of my Tundra. Went to a local IFA and used their loading dock, which was level with my truck-bed, to off-load the bike.
Al
Ogden, Utah
2012 R1200RT
Boxer bikes, boxer dogs, and letterboxing.
UtahSooner is offline   Reply With Quote
Old 02-16-2013, 03:06 AM   #12
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,385
I realize this is a GS thread, on a motorcycle forum, but this is just BS. I am such a Toyota fan, but damn a tailgate is not a "door." It's a loading platform.
Old 02-16-2013, 03:20 AM   #13
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 625
Yes, those tailgates are weak and if you ride up on it with all the weight on the center it will bend. I sold ours for that and other reasons, the truck didn't live up to my expectations with all it's issues...
Just to note, the Tacoma bed is 6'6" not 6'...
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 02-16-2013, 03:38 AM   #14
Spoke
semi-feral teen
Spoke's Avatar
Oddometer: 783
You can do it. Done it a bunch of times with a '99 extended cab. Don't ride it up, be gentle, use a ramp and push it up. The gate is the weakest point but the rear tire just sits right at the hing point of the gate. If you are worried then use something to help distribute the load like a 24" wide X 80" long X 3/4" thick piece of plywood that the entire bike sits on and zero issues. Maybe a bit getto but works fine.
Rich
It entered my blood in 1970 on a Honda QA50
Spoke is offline   Reply With Quote
Old 02-16-2013, 11:04 AM   #15
Callisto224
Callisto224's Avatar
Oddometer: 975
Originally Posted by Steve G. View Post
When you offer the front tire of your bike up against the bulkhead, it is VERY easy to bend the bulkhead, sometimes bending the bulkhead enough to hit the back of the cab when tightening the tiedown straps [which are best tied to the handlebars, not the frame of the bike, the higher the better].
I'm not sure about a 2001 1150 but on a 1200GS NEVER use tie down straps on the handlebars, you will bend them. I would guess that the 1150 is the same. Like LaurelPerryOnLand already mentioned, visit these links to properly tie down your bike.
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Times are GMT -7.   It's 07:53 AM.
