Old 02-17-2013, 06:58 AM   #1
rdwalker OP
Oddometer: 2,542
Loose front end? How to troubleshoot?
Hi, all,
on my '09 R1200GS, I feel a distinct "click" in the front, when rocking the bike back-and-forth, with the front brake applied.
What is the best method of determining where the lash exists?
I was rocking the bike while holding my fingers by the steering head bearings, but felt no movement. Neither, when touching the ball-joint on the Telelever swing arm.
Also, I jacked up the engine to lift the front and tugged on the wheel - needles to say, felt no movement, either.
Is this a valid test? How to approach the diagnostics? What else could be loose beyond head bearings and the ball joint?
TIA. Robert.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker screwed with this post 02-17-2013 at 07:04 AM
rdwalker is offline   Reply With Quote
Old 02-17-2013, 07:18 AM   #2
10Cup
10Cup's Avatar
Oddometer: 2,645
Originally Posted by rdwalker View Post
Hi, all,
TIA. Robert.
This is just movement from the brake rotors, my new 2012 triple black does the same thing. Nothing to worry about they have to float the rotors because the calipers are fixed. Designed that way.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 02-17-2013, 09:02 AM   #3
rdwalker OP
Oddometer: 2,542
Brilliant! I forgot about that! You, sir, just made my day.
I am used to the round-button style rotor mounts on my '06 GS and all my older K and R bikes; that explains why I did not feel the "click" on those bikes. The '09 is my first one with the rubber-suspended rotors.
Thanks.
Old 02-17-2013, 09:02 AM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,004
Hi Robert,
As mentioned, it could just be your rotors moving. I would take a torque wrench to all the bolts on your front end, skip the ball joint, and make sure they are all tight. Also, check your caliper bolts as well.
Jim
JimVonBaden is online now   Reply With Quote
Old 02-17-2013, 09:19 AM   #5
rdwalker OP
Oddometer: 2,542
Originally Posted by JimVonBaden View Post
Hi Robert,
Jim
Thanks! I've done the calipers previously - but will go through everything else with my trusty torque wrenches. I just found here in the forum a mention of someone reporting that the fork tube clamp bolts loosened up.
Personally, of course, I like the theory of the rubber-cushioned rotor buttons the best.
Regards, Robert.
Old 02-17-2013, 12:45 PM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 53,004
The fork tube clamp bolts are an old, but very valid issue that I have no heard in a while. Seems they would loosen up and the forks would twist.
Jim
Old 02-17-2013, 04:16 PM   #7
Yellow Iron
Yellow Iron's Avatar
Oddometer: 3,073
I have the same click. Checked the front end. Found the bar mounts loose tighten them still didn't go away.
Time to do some more checking.
Bigger Better Faster More----4 non blondes
Feel the Power of the Wheel
Yellow Iron is offline   Reply With Quote
Times are GMT -7.   It's 08:27 PM.
