Old 02-16-2013, 06:03 AM   #1
PHOTON PHIL OP
THe REAL poser
PHOTON PHIL's Avatar
Oddometer: 259
Too cold to set valves???
I was going to set the valves on my oilhead and then I thought that maybe is was too cold ,20 degrees, in my garage. If I set the valves when the temp is in the 20's will they be too loose at operating temp? And yes ,I'm bored and just need something on the bike to do.
Out on the road somewhere
2013 Vstrom 650
If loud pipes save lives, just imagine what learning to ride that thing could do.
PHOTON PHIL is offline   Reply With Quote
Old 02-16-2013, 06:54 AM   #2
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,401
No it will be fine.
Your hands and fingers might have some problems in those temps though!
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 02-16-2013, 07:03 AM   #3
baloneyskin daddy
bikaholic
Oddometer: 2,161
You must really be bored if you can't think of anything better to do than adjust valves in a 20degree garage.
baloneyskin daddy is offline   Reply With Quote
Old 02-16-2013, 07:50 AM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,922
Better too loose than too tight.
Wait
We're still talking about valves, right?
Actually, I'd think that if you did it when it's REALLY cold, like zero F or below, you could end up with tight and eventually burned valves.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 02-16-2013, 09:13 AM   #5
LuciferMutt
Oddometer: 11,401
It'd have to be more than 100*F below zero before it actually mattered.
Old 02-16-2013, 04:12 PM   #6
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 5,191
The garage temp won't change your readings. Its just going to be a cold mofo to work in.
Something that might make a difference is if you have to use any sealers. On my Honda, it needs a smear of sealer on the two corners of the half moon shaped parts of the valve cover gasket. Sealers may not set up properly in that cold of temperature.
Wasser is offline   Reply With Quote
Old 02-16-2013, 04:18 PM   #7
markjenn
Oddometer: 10,483
I'm with the rest; for this, "cold" means "ambient" or "not hot", rather than a specific temperature. A couple of mfgs do publish a guideline ambient temp, but I my judgment would be that you'd have to be incredibly anal to worry about this. But then, I think the whole idea of setting oilhead valve clearances super-precisely with four feeler gauges, calibrated pull, etc. to be completely and utterly ridiculous.
- Mark
Old 02-17-2013, 02:48 PM   #8
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 983
- Mark
BIG +1 on those comments. I've set valves on dozens of oilheads, and once had the misfortune to sit thru
an oilhead valve-setting seminar at a BMW rally; put the A in annal. Turning such a simple 20 minute
process inside out was just sad.
CycleDoc59 is offline   Reply With Quote
Old 02-17-2013, 09:37 PM   #9
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
I can picture that...
Flashmo is offline   Reply With Quote
Times are GMT -7.   It's 07:37 PM.
