Old 02-16-2013, 07:12 AM   #1
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
Which Way Does Your Fan Blow?
Meaning your refrigerator's freezer section, that is. Does it blow forward over the food or backwards over the cooling plates/fins?
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 02-16-2013, 07:21 AM   #2
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,993
You able to access your fan without pulling the inner housing/trim panels from your freezer? Both my refrigerators have the fan inside the housing and I have no idea which side of the evaporator unit the fan is on. Sorry.
That said, it seems like it would make sense to pull air through the evaporator. At least it does in my mind's design section. Atmosphere side of the evap is wide open, freezer side is "plumbed" similar to a shroud/radiator in an older auto engine bay.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 02-16-2013, 07:46 AM   #3
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
On this old Hotpoint, the alum. fan blades are visible. Unfortunately the fan motor must have burned out, when the guys in my lab. let ice fill up the whole freezer area, which stopped the fan from spinning--for a few years while I was in Italy.
Agree with the heat flow idea, but I'd like a few confirmations. It doesn't look easy to replace the fan, and the minute I do the compressor will die.
Old 02-16-2013, 07:59 AM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,917
Which side of the fan blade edge shows the contamination that would indicate it is the leading edge of rotation?
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 02-16-2013, 08:56 AM   #5
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,993
Can you get some CPU cooling fans in the same vicinity? Not sure about the voltage issues, but you're a pretty smart feller and I'm sure it can't be that difficult to sort out. Myself, I'd just start a thread here and ask for someone else to figure it out for me.
Old 02-16-2013, 09:23 AM   #6
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
I have a small fan that would work. Have to use thin flat wire and run it over the door gasket. But it would only work well if the airflow is from the freezer to the cooling plate (blowing past the old fan).
Hoping someone will go open their freezer door and see which way the wind blows.
Old 02-17-2013, 12:40 PM   #7
HeavyMetal
Oddometer: 58
On my old Hotpoint the fan blows out over the food. Hope that helps!
HeavyMetal is offline   Reply With Quote
Old 02-17-2013, 06:00 PM   #8
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
Thanks. After looking at the shape of the fan blades, I came to the same conclusion.
Thread Tools
Times are GMT -7.   It's 02:26 AM.
