02-16-2013, 10:49 AM
#1 |
Oddometer: 975
Xchallenge exhaust lug bent
Ok just changed rxhaust gasket as was wrecked
Saw thay wheb put all together the end can doesnt line up great. Looked down and looks like exhaust lug is bent out and out of shape Whats best was straighten this as i dont like heating alu
women are like clouds....... once they fuck off it is a really nice day.......
02-16-2013, 11:59 AM
#2 | |
Two-wheelin' Fool
Oddometer: 2,571
If you can shield the gas tank from the heat, use a propane torch to heat the bent area of the lug. To see if the temperature is hot enough to bend, scribble on a part of the lug with a permanent marker. Make sure that you don't apply the flame to this part. When the marker looks like it has disappeared, it is hot enough. Put a big pair of channel locks on it and bend it back straight. Try not to pound it back with a hammer. |
02-16-2013, 01:57 PM
#3 |
Oddometer: 975
Like the idea of marker as i hate heatn alu as raeely works out well
I have hight heat resistant tape from furnace that shoul help
02-16-2013, 07:34 PM
#4 |
Two-wheelin' Fool
Oddometer: 2,571
It really isn't that hard to take off the rear subframe. Since you crashed hard enough to bend the lug, you may as well see if you broke the subframe anywhere.
02-17-2013, 01:04 AM
#5 |
Oddometer: 975
Looks like previous owner damage as the exhaust pretty beaten up. May still look take it off. Cut lug off and get welder in work Tig back on
