02-18-2013, 04:57 AM
#16 | |
Oddometer: 1,019
They're much brighter than the hyperlites and don't require soldering. |
02-18-2013, 06:54 AM
#17 |
Freak of Unnature
Oddometer: 124
Thanks for the input.
'12 R1200 GSA |
02-18-2013, 08:18 AM
#18 | |
Dirt(y) Neophyte
I have the P3s on the back and photonblasters on the front (orange) an they are worth their weight in gold on I95 in NJ. I know they work because my GSA has them and my S doesn't and I see the way traffic behaves around me. And lest you think the difference is a two wheeled hummer baring down on them, I haven't had time to install them on my new GSA and I see the difference. The oscillating is why my brother calls them 'annoying lights', because they always catch your eye.
_ 12 R1200 GSA Sand Rover ("Sandy") 09 R1200 GSA (Totaled) Superstorm Sandy you Bit$% ![]() 06 Husky TE450 04 R1100s BCR |
#19 | |
ATAC Kfir Hack
Oddometer: 450
At $170 with the wire harness its pricey, but works great. As for an additional "supplemental" brake light there are dozens of other options and you need not worry about the CANBUS as it's a load sensor withing the ZFE that triggers the LAMP Out error and that is already set to LED on 2008 and newer models.
Good Judgment Comes From Experience, Experience Comes From Bad Judgment. |
02-18-2013, 08:41 AM
#20 | |
noobie allover again
Oddometer: 344
I've had various HyperLight setups on my bikes for the last 10+ yrs., never had an issue with them. This will be the first CANBus install though.
Bill '05 R1200GS for now...... |
02-18-2013, 10:09 AM
#21 |
Dog Rancher
Oddometer: 4,181
You said you didn't want soldering or canabus issues but I've been stuck behind the school bus in my neighborhood. They stop at every driveway and have super bright and noticeable red LEDs. Anyway I've been thinking about something like them on my 08 GSA some how.
http://www.slclighting.com/7-RED-LED...744-96-010.htm ![]()
02-18-2013, 10:28 AM
#22 |
Oddometer: 2,418
And then there are these...LOTS of choices.
http://www.whelen.com/_AUTOMOTIVE/lightheads.php
![]() Used the 600-series light head for some additional visibility on the RT. http://www.whelen.com/_AUTOMOTIVE/de...74&prod_id=126 Works like a charm...no CANBUS issues. Want to ride up on my tail? Didn't think so!
LaurelPerryOnLand screwed with this post 02-18-2013 at 10:34 AM |
02-19-2013, 03:56 AM
#23 |
Oddometer: 488
I have a fuzeblock with relay built in and ability to use both switched and straight battery power. If you monkey with the electrics on these frickin' CAN-Bus bikes it sure makes things a lot easier. I have yet to see ANYTHING positive about CAN-Bus. Last comment on omelets, if you expect to have plug and play, then don't expect to get three things: 1. What you really want. 2. The best item for the job. 3. Something you don't have to worry about CAN-Bus compatibility.
Old, but not Dead |
02-19-2013, 07:55 AM
#24 | |
Dog Rancher
Oddometer: 4,181
![]() ![]() $2500How did you trigger it to come on with the brakes. Relay? One on each can and one in the middle. ONLY a texter would hit you.
scooteraug02 screwed with this post 02-19-2013 at 04:06 PM |
02-22-2013, 09:49 PM
#25 |
SHED (Shit Head)
Oddometer: 225
I'm on my 3rd replacement BMW supplemental LED light. They suck. Although they do come with a 2 year warranty. Maybe it's the vibration from the off roading that kills them?
03-01-2013, 08:00 AM
#26 | |
Plunger Boy
Oddometer: 654
Just run a double row of yellow LEDs down each arm, so when you signal you can point your flashing arm in the direction you intend to move. And maybe a sheath of LEDs for each middle finger. |
