Old 02-17-2013, 03:34 PM   #1
Milehi OP
Milehi's Avatar
Oddometer: 168
Clutch fluid change help.
Any Idea why I cannot push fluid from the slave bleeder up to the master? I am using a Magura kit and the syringe wont budge the fluid, Cap off and bleeder open....I tried it with the slave mounted and with it off...... Ideas? Thanks.
Milehi is offline   Reply With Quote
Old 02-17-2013, 03:38 PM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,664
Adjust the lever to give it more play.
Peanuts is offline   Reply With Quote
Old 02-17-2013, 04:38 PM   #3
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
By cap off, I assume you mean the top of the brake master has been removed. Other than that it is a straight shot up so try pumping your lever a couple of times. It doesn't matter whether the clutch slave is mounted or not, better mounted for final bleed.
DeepInIt is offline   Reply With Quote
Old 02-17-2013, 05:22 PM   #4
Milehi OP
Milehi's Avatar
Oddometer: 168
Lever freeplay
That was it !!! A slightly bent lever and handguard holding the lever in a bit will not allow fluid to pass....
Old 02-18-2013, 12:24 AM   #5
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
This is a NO NO!
If clutch slave is not mounted, DO NOT pump the clutch lever or you blow the slave cyl. Hope I got you in time!
Times are GMT -7.   It's 02:44 PM.
