02-19-2013, 05:53 AM
#1 |
Oddometer: 66
Airhead GS Which Fork Dampens
On an Airhead GS (1994), which fork leg does the rebound damping and which fork leg does the compression damping?
Is it appropriate to use different weight fork oils on either side to tune the compression and |
02-19-2013, 06:46 AM
#2 | |
More tacos than you
Oddometer: 5,123
Yes, the only reason they separated the functions between legs is so that you can adjust compression and rebound independently by using different oil weights.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 02-19-2013 at 06:52 AM |
02-19-2013, 03:25 PM
#3 | |
because I can
Oddometer: 6,082
02-19-2013, 03:35 PM
#4 |
More tacos than you
Oddometer: 5,123
I got satisfactory results by using 10w for compression and 15w for rebound. That was my first try and it was good enough, so I didn't go back and experiment with it though I probably should have. Fork oil isn't cheap.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
02-19-2013, 06:16 PM
#5 |
+/- V TDSPP
Oddometer: 19,939
When I had stock internals, I used a heavier weight on the compression side. Roughly 15-20w on the compression side, and 10 or so on the rebound. I got the preload right about correct for me, something like 25-30% with an inch and a half long PVC spacer at the top, then mucked about with the oil.
What to do... What to do... |
